hi,
Thomas de Groot <tho### [at] degrootorg> wrote:
> alright. Getting tired after a day of tweaking.
glad you did though, "Flanders Gray (tm)" looks ready for turning into kitchen
worktops. :-) (am interested to see it being used other than in a
demo/reference image)
regards, jr.
> Second, overhauled, StepNoise version. Several things learned:
> - to be careful with the /scale/ of the grains. This is as good as I
> dare to go. Larger minerals become increasingly unbelievable, so one
> needs to find the balance (as with the turbulated cells obviously, but
> StepNoise does a much better, although not perfect, job).
> - the mask for the pigment_pattern needs a /very/ careful adjustment.
> The present one is good but could probably be improved further. Good
> enough for now.
> - white grains are present but hardly visible. In the first version they
> were placed at the wrong place within the colour_map, rendering rings
> instead of mineral grains. Corrected that but need now to be enhanced a bit.
> - sslt would probably increase realism, even in the frosted version. I
> am going to look into that.
> Thomas
I am embarrassed to say that I can't see anything from that far. With respect to
that 10cm grid measures, I feel like you are no longer representing the same
rock? Did you work on it like that or with a closer camera? I do feel like
nothing is wrong with what little I see, though ! I have faith in you ! :-)
Op 29-4-2021 om 19:21 schreef Mr:
The 'problem' with changing patterns or pattern modifiers, is that
scales get changed too. In a sense, you are right: it is not the same
rock indeed and you need to readjust your frame of reference. Don't let
it fool you: that 10cm grid does not represent anything real; I have
always bee troubled by those quasi-real measurements (I am going to take
out those cm-values and replace them by Martian Claw Units). My believe
is that size/dimensions in POV-Ray are dimensionless as it were and only
meaningful in relation to recognisable objects.
I attach a version with the material scaled by two. Still looking good,
imo, and much better than the cells pattern.
Download 'dakotagrains_sn_test3.jpg' (91 KB)
Preview of image 'dakotagrains_sn_test3.jpg'
scaled by four; starting to break down I think, but still believable.
Download 'dakotagrains_sn_test4.jpg' (84 KB)
Preview of image 'dakotagrains_sn_test4.jpg'
Have you tried doing a sequence of objects, with changing smooth-step thresholds
to see what effect that has? There's also the amount of turbulence applied
which will affect how the underlying pattern looks.
Op 30/04/2021 om 19:57 schreef Bald Eagle:
Not yet, but good suggestion. Had something like that on my ToDo list.
Want also to try sslt... and object-scale vs landscape-scale use... Too
many balls in the air atm.
Op 29/04/2021 om 17:56 schreef jr:
> hi,
I certainly agree with that. something is planned in that way.
hi,
> > ... (am interested to see it being used other than in a
personally, I'd love something .. surreal/"strange". like a space station, or
perhaps that natty pre-war flatbed truck you used before, modelled in various
granites. :-)
regards, jr.
Op 1-5-2021 om 09:40 schreef jr:
> hi,
> granites. :-)
Oh lol! That last one would be interesting! I shall see what I can do.
I was thinking, among other things, about the El Capitan half dome...
https://en.wikipedia.org/wiki/El_Capitan
Note that granitic landscapes/formations look rather featureless as far
as textures are concerned. They have no/little internal layering, and
weathering is mostly 'rounding' the rocks.
hi,
incongruous rather than strange.
> > granites. :-)
uh, nice.
had not heard of 'El Capitan' before. 900+ metres of sheer cliff, just .. wow.
cannot really imagine, but feel one would feel distinctly ant-sized standing at
its base. (America, huh? _everything_ is big in America! :-))
regards, jr.
