POV-Ray : Newsgroups : povray.binaries.images : Nov 29 2020 povr doodle Server Time
28 Mar 2026 12:28:38 EDT (-0400)
  Nov 29 2020 povr doodle (Message 1 to 10 of 17)
Subject: Nov 29 2020 povr doodle
Date: 29 Nov 2020 07:51:54
Message: <5fc3996a@news.povray.org>
A doodle using povr tweaks on top of v3.8.
Bill P.
Download 'povrdoodle_29nov2020.jpg' (121 KB)
Preview of image 'povrdoodle_29nov2020.jpg'
Subject: Re: Nov 29 2020 povr doodle
Date: 30 Nov 2020 02:28:32
Message: <5fc49f20$1@news.povray.org>
Op 29/11/2020 om 13:51 schreef William F Pokorny:
> Bill P.
Intriguing... Basically, a sphere_sweep?
Date: 30 Nov 2020 05:28:44
Message: <5fc4c95c$1@news.povray.org>
>> Bill P.
One could get the same (or better) "loose ball of wires" with a
spheresweep, but here it's an isosurface.
//--- code below written for povr branch of POV-Ray.
#declare Fn00 = function (x,y,z,xn,zn) {
    f_planar(
        f_sphere(x+f_noise3d(xn+pi,y-pi,zn,2)*0.3,
                 y,
                 z+f_noise3d(xn,y+pi,zn-pi,2)*0.3,0.7),
        0.002,1
#declare Fn01 = function { f_planar(f_ph(x,abs(y),z)/pi-0.2,0.002,1) }
#declare Fn02 = function { f_planar(f_ph(x,abs(y),z)/pi-0.4,0.002,1) }
#declare Fn03 = function { min(Fn01(x,y,z),Fn02(x,y,z)) }
#declare Fn04 = function { min(Fn03(x,y,z),Fn03(y,x,z),Fn03(x,z,y)) }
#declare Fn98 = function { max(Fn04(x,y,z),Fn00(x,y,z,x*4,z*4)) }
#declare Iso99 = isosurface {
     function { Fn98(x,y,z) }
     jitter on
Let's see. In povr:
f_planar is an inbuilt function with an "f_shell" functionality. If the
value argument is x,y,z or any f_gradient() instead of f_sphere(), or
whatever, it's very similar to the planar pattern in result excepting
for not being clamped to a 0-1 value range - so I kept the naming.
f_noise3d has an extra parameter for the noise generator as do all
in-built functions using noise generators directly. In POV-Ray you
always get generator 2 excepting for one special noise function allowing
the selection (I cannot recall the name - it's unnecessary and gone in
povr).
In the isosurface itself, I used povr's "jitter on."
In this case, used mode 2 AA with "bigger (+j7)" truly random jitter and
the +a0.0 internal optimizations avoiding the internal AA gamma
calculations and color channel difference calculations. The truly random
jitter is better at picking up the small wires (with the shadow of the
wires more of a resolution problem). In the end, I increased the wire
size to something less a hint of something - which was my original aim.
The povr AA changes probably not strictly needed for the image as posted.
Bill P.
Date: 30 Nov 2020 08:48:07
Message: <5fc4f817@news.povray.org>
William F Pokorny wrote on 29/11/2020 13:51:
> Bill P.
Very interesting!
Paolo
Date: 30 Nov 2020 10:45:01
Message: <web.5fc512f082247dc26adeaecb0@news.povray.org>
> Bill P.
WOW an Isosurface can do that?! It's definitely one of the most powerful and
versatile POV feature... is it not?
Date: 30 Nov 2020 18:12:12
Message: <5fc57c4c$1@news.povray.org>
>> Bill P.
If it exists or can be conceived by the human imagination, Bill can make
an isosurface of it.
Date: 30 Nov 2020 20:09:17
Message: <5fc597bd$1@news.povray.org>
>>> Bill P.
>> powerful and
indeed... respect
Date: 1 Dec 2020 02:28:25
Message: <5fc5f099$1@news.povray.org>
Op 30/11/2020 om 11:28 schreef William F Pokorny:
>>> Bill P.
"petje af", which translates from Dutch as something like "I drop my cap
to you". I am impressed indeed.
Date: 1 Dec 2020 08:17:42
Message: <5fc64276$1@news.povray.org>
> ... It's definitely one of the most powerful and
Yes, I'd put it near the top of the list in terms of shape/surface
formation. It's ability to represent very complex shapes in great detail
- very concisely - is, I believe, unmatched.
However, it's not the easiest to use and it's difficult to diversely
texture. There is no easy way to "paint" what surface materials you want
in a uv map sort of way(1).
The more complex a shape gets in terms of major forms; the slower it is
to render and the harder it is to assemble the functions. Meaning, there
are practical specification and compute limits on what it can do in theory.
(1) - I'm playing with functionality in the povr branch which helps.
Bill P.
Date: 1 Dec 2020 08:20:59
Message: <5fc6433b$1@news.povray.org>
:-) Your elliptical torus has me stumped!
