POV-Ray : Newsgroups : povray.binaries.images : Nov 29 2020 povr doodle Server Time
14 Jun 2024 12:02:05 EDT (-0400)
  Nov 29 2020 povr doodle (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Nov 29 2020 povr doodle
Date: 1 Dec 2020 02:28:25
Message: <5fc5f099$1@news.povray.org>
Op 30/11/2020 om 11:28 schreef William F Pokorny:
> On 11/30/20 2:28 AM, Thomas de Groot wrote:
>> Op 29/11/2020 om 13:51 schreef William F Pokorny:
>>> A doodle using povr tweaks on top of v3.8.
>>> Bill P.
>> Intriguing... Basically, a sphere_sweep?
> One could get the same (or better) "loose ball of wires" with a
> spheresweep, but here it's an isosurface.
"petje af", which translates from Dutch as something like "I drop my cap
to you". I am impressed indeed.
Date: 1 Dec 2020 08:17:42
Message: <5fc64276$1@news.povray.org>
On 11/30/20 10:42 AM, Mr wrote:
> William F Pokorny <ano### [at] anonymousorg> wrote:
> ... It's definitely one of the most powerful and
> versatile POV feature... is it not?
Yes, I'd put it near the top of the list in terms of shape/surface
formation. It's ability to represent very complex shapes in great detail
- very concisely - is, I believe, unmatched.
However, it's not the easiest to use and it's difficult to diversely
texture. There is no easy way to "paint" what surface materials you want
in a uv map sort of way(1).
The more complex a shape gets in terms of major forms; the slower it is
to render and the harder it is to assemble the functions. Meaning, there
are practical specification and compute limits on what it can do in theory.
(1) - I'm playing with functionality in the povr branch which helps.
Bill P.
Date: 1 Dec 2020 08:20:59
Message: <5fc6433b$1@news.povray.org>
On 11/30/20 6:12 PM, Cousin Ricky wrote:
> On 2020-11-30 11:42 AM (-4), Mr wrote:
> If it exists or can be conceived by the human imagination, Bill can make
> an isosurface of it.
:-) Your elliptical torus has me stumped!
Date: 1 Dec 2020 13:25:00
Message: <web.5fc6898482247dc21f9dae300@news.povray.org>
As difficult as it was for me, I held my tongue.  ;)
Date: 1 Dec 2020 16:55:00
Message: <web.5fc6bb4f82247dc26adeaecb0@news.povray.org>
> Bill P.
Sorry for what may sound like a very basic question : Apart from their names I'm
not sure to fully grasp the distinction between an isosurface and a
parametric... Could you clarify the difference? the paradigms for when to best
use one over the other? is it that one is a surface and the other a volume?
Date: 1 Dec 2020 18:35:00
Message: <web.5fc6d2ce82247dc21f9dae300@news.povray.org>
I would say that primarily, from an implementation perspective, the difference
is that an isosurface evaluates an implicit function - an ordinary function with
terms in x, y, and z - and it's a surface where that equation equals the
threshold value.
A parametric evaluates the x, y, and z coordinates as functions of the
parameters u and v, and is a surface as well.
They are both slow, or can be, depending on the settings, and the complexity of
the equations.
So generally, it's a matter of how you conceive of the math(s) involved, and/or
whether or not it's even possible to (efficiently) express the desired shape in
either implicit or parametric form.
A good exercise would be to make a sphere object, using small sphere{}
primitives to "plot" the points on its surface.
Do it "the isosurface way" using r=sqrt(pow(x,2)+pow(y,2)+pow(z,2)),
and "the parametric way" using
x = cos (u) * sin (v)
y = sin (u) * sin (v)
z = cos (v)
Where u goes from 0 to tau, and v goes from 0 to pi
Date: 2 Dec 2020 03:32:40
Message: <5fc75128$1@news.povray.org>
> threshold value.
> the equations.
> z = cos (v)
I'll add:
@Mr, you are correct that parametrics don't support an inside, a volume,
while isosurfaces do.
To get acceptable performance with parametrics, you almost always need
to use the precompute option and this takes quite a bit of storage; On
the order of a fine mesh for the same surface(1) where the surfaces are
relatively simple. With the isosurface, both the SDL and internal
representations are compact.
The parametric as implemented today returns only one surface
intersection per ray (probably to keep performance reasonable). This is
sometimes an issue for shadows, csg and ???. IIRC Jerome has a github
issue or two open on this.
(1) Jerome - not too long ago - added to hgpovray38 an ability to create
meshes on the fly from parametrics. This is what most other tooling does
with parametric implementations and the feature should make the renders
quite fast. However, there will be parametrics where a mesh would be
prohibitive due size. For example, if using a pattern for very detailed
surface displacement via the parametric functions, the mesh would need
to be large to get the representation close to the actual surface. It's
on my list to play with this new hgpovray38 option, but it has yet to
bubble to the top.
Bill P.
Date: 2 Dec 2020 11:55:00
Message: <web.5fc7c6a682247dc26adeaecb0@news.povray.org>
> > threshold value.
> > the equations.
> > z = cos (v)
> I'll add:
> bubble to the top.
> Bill P.
Interesting... Does that mean than any shape rendered as a parametric could find
an equivalent isosurface? ...But not the other way around...?
Date: 3 Dec 2020 07:30:07
Message: <5fc8da4f$1@news.povray.org>
:-) Unsure how your mind walked to that question from anything we wrote
- but it's a good question.
 From everything I've read, the parametric to implicit conversion
("called implicitization") is always possible, but perhaps not always
tractable/managable(1).
The implicit to parametric conversion ("called parameterization") in
practice I think mostly can work.
As to whether it's always possible... I've seen statements out and about
that the answer is yes; Bald Eagle's draft bicubic patch paper makes
this statement.
I've also see statements parameterization is sometimes impossible. In
Jules Bloomenthal's introduction to the book "Introduction to Implicit
Surfaces" he writes:
"Parameterization is not always possible, however; for example, implicit
surfaces that are defined by certain polynomials of fourth or higher
degree cannot be parameterized by rational functions [Salmon 1914]."
(1) - Always possible is not the same thing as saying the converted
parametric -> "implicit equation" is usable in an isosurface object.
Bill P.
Date: 3 Dec 2020 13:50:00
Message: <web.5fc932de82247dc21f9dae300@news.povray.org>
I think I might have implied it in my response.
> this statement.
That bit that I included (mostly as a prompt to explore further reading) was
based upon a number of different search results that I came up with, and largely
paraphrased from
Algebraic Methods for Computer Aided Geometric Design (2002)
[* vide infra]
So, perhaps if you're inclined to get some more details, you could contact the
primary author and see if he has something that you can work with.
Thomas W. Sederberg
tom### [at] csbyuedu
I know that another source explained things in a bit more detail, pointing out
that although it's _possible_, for some conversions, you could run into
equations with zillions of terms and pow(x, 138) + .... etc.
This, in my mind, is somewhat reminiscent of Tupper's Self-Referential Formula.
https://www.popularmechanics.com/science/math/a16593584/tuppers-self-referential-equation-produces-a-graph-of-itself/
So although it's possible, in theory, in practice, it's likely to be anything
but efficient.
"Implicitization, Parametrization and Intersection
 For any parametric curve, an implicit polynomial equation exists that describes
exactly the same curve. Likewise, for any parametric surface, there exists an
implicit equation that describes exactly the same surface. The process of
finding the implicit equation of a parametric curve or surface is called
implicitization.
 An inversion formula for a parametric curve can be derived using polynomials.
If the parametrization of a curve is a general one-to-one map between parameter
values and points on the curve, the inversion formula returns the parameter
value t corresponding to a point (x, y) that lies on the curve.
 Algebraic methods also can facilitate the design of algorithms for computing
intersections between curves and surfaces."
