POV-Ray : Newsgroups : povray.binaries.images : RSoCP by UberPOV Server Time
27 Mar 2026 05:20:41 EDT (-0400)
  RSoCP by UberPOV (Message 1 to 10 of 59)
Subject: RSoCP by UberPOV
Date: 25 Jun 2015 10:44:41
Message: <558c13d9@news.povray.org>
Following the discussion in povray.off-topic on Physically Based
Rendering (PBR)
http://news.povray.org/povray.off-topic/thread/%3Cop.x0kk32qvufxv4h%40xena%3E/
and the /rules/ given by Clipka, this is an RSoCP following the said
rules and rendered with UberPOV.
Scene file can be found in povray.binaries.scene-files.
Download 'rsocp_uber.png' (273 KB)
Preview of image 'rsocp_uber.png'
Subject: Re: RSoCP by UberPOV
Date: 25 Jun 2015 16:38:36
Message: <558c66cc$1@news.povray.org>
Am 25.06.2015 um 16:44 schrieb Thomas de Groot:
> Rendering (PBR)
I think you're doing /something/ wrong there.
Date: 25 Jun 2015 16:50:44
Message: <558c69a4$1@news.povray.org>
> Rendering (PBR)
Um... you're /not/ following the rules /at all/:
	sphere {
	  <0,0,0>, 1.00
	    pigment {srgb <0.8, 0.7, 0.7>*0.5 }
	    finish {
	      diffuse albedo 0.8
	      brilliance 3, 3
	      reflection {
	        0.0, 1.0
	        //roughness 0.001
	        //fresnel on
	        //metallic on
	      fresnel on
	      metallic on
	  interior { ior 1.5 }
	  scale <1,1,1>  rotate <0,0,0>  translate <0,1.35,0>
You're using "metallic on" in the entire finish block, but not in the
reflection block. That's bad bractice. /Very/ bad practice.
Also, "fresnel on" has no effect (or at least shouldn't have) when used
together with "metallic on". And as I'm already at it, always use
"fresnel on" in the reflection block when you use it in the entire
finish block. It doesn't carry through to the reflection automatically.
Furthermore, I'll probably need to add more rules:
- Do not use "diffuse" for metallic materials (or, more specifically,
use "diffuse 0.0" to override the non-zero default). Use specular
reflection with a very high roughness instead. To also add crisper
highlights to the mix, use complex textures.
Date: 26 Jun 2015 03:03:40
Message: <558cf94c$1@news.povray.org>
Why am I not surprised? ;-)
Date: 26 Jun 2015 03:40:59
Message: <558d020b@news.povray.org>
>> Rendering (PBR)
>      sphere {
>        <0,0,0>, 1.00
>        texture {
>          finish {
>            diffuse albedo 0.8
>            brilliance 3, 3
>            reflection {
>              0.0, 1.0
>              //roughness 0.001
>              //fresnel on
>              //metallic on
>            fresnel on
>            metallic on
Ah! Yes, I don't know why I switched it off. I had a reason initially
which I have forgotten now :-/
I had not paid enough attention to the (mutual) exclusion of fresnel and
metallic (RTFRules!). Forgot also to add conserve_energy.
Good one about diffuse and complex textures. My scene is simple because
I wanted to start from the 'basic scene' in the Insert Menu.
Four images are attached with variations in the parameter use (see their
corresponding titles).
sphere {
   <0,0,0>, 1.00
     finish {
       diffuse albedo 0.0
       specular albedo 0.5
       roughness 0.001
       brilliance 3, 3
       reflection {
         0.0, 1.0
         roughness 0.001
         fresnel on
         metallic off
       fresnel on
       metallic off
Download 'rsocp_uber_fresnel.png' (327 KB) Download 'rsocp_uber_fresnel+specular.png' (317 KB) Download 'rsocp_uber_metallic.png' (308 KB) Download 'rsocp_uber_metallic+specular.png' (316 KB)
Preview of image 'rsocp_uber_fresnel.png'
Preview of image 'rsocp_uber_fresnel+specular.png'
Preview of image 'rsocp_uber_metallic.png'
Preview of image 'rsocp_uber_metallic+specular.png'
Date: 26 Jun 2015 08:43:20
Message: <558d48e8$1@news.povray.org>
Am 26.06.2015 um 09:40 schrieb Thomas de Groot:
Don't worry, that's only relevant for transparent objects.
>        specular albedo 0.5
>        roughness 0.001
>        brilliance 3, 3
>        reflection {
>          0.0, 1.0
Now what did I say about the specular and reflection brightness settings?!
Use "specular albedo N" where N is the same as the maximum reflection.
That's what I said.
Need a hearing aid, hm? :P
Date: 26 Jun 2015 10:36:09
Message: <558d6359$1@news.povray.org>
>>        specular albedo 0.5
>>        roughness 0.001
>>        brilliance 3, 3
>>        reflection {
>>          0.0, 1.0
> That's what I said.
What did you say? I don't hear you! ;-)
The thing is, I read what you write and it just doesn't impact where it
should: "Use "specular albedo N" where N is the maximum reflection
intensity"; clear enough one should say, except for me of course.
Oh, well...
Date: 26 Jun 2015 11:33:55
Message: <558d70e3$1@news.povray.org>
Am 26.06.2015 um 16:36 schrieb Thomas de Groot:
>> settings?!
>> That's what I said.
> Oh, well...
I'm pondering adding a mode where POV-Ray will automatically issue a
warning whenever it finds inconsistencies in the settings.
I guess I'll start every such warning message with "Thomas, I told
you..." :P
Date: 27 Jun 2015 08:12:30
Message: <558e932e@news.povray.org>
>>> settings?!
>>> That's what I said.
>> Oh, well...
> you..." :P
Good idea! ;-)
I have a problem reading from screen. Reason I never use e-books for
example.
Date: 27 Jun 2015 10:19:06
Message: <558eb0da$1@news.povray.org>
Am 27.06.2015 um 14:12 schrieb Thomas de Groot:
>> you..." :P
> Good idea! ;-)
> example.
Then I'll have to make it an audible warning? :P
