POV-Ray : Newsgroups : povray.binaries.images : Tovolume: Sam found ridiculously easy way to create shapes. Server Time
26 Oct 2025 23:35:07 EDT (-0400)
  Tovolume: Sam found ridiculously easy way to create shapes. (Message 1 to 10 of 10)
Subject: Tovolume: Sam found ridiculously easy way to create shapes.
Date: 21 Oct 2013 09:55:52
Message: <52653268@news.povray.org>
Off work today and playing with Sam's Tovolume code when it hit me, what
he has discovered is an incredibly easy way to create silhouette based
isosurface shapes.
The blur.png file was drawn freehand in gimp with a solid brush after
which a Gaussian blur was applied - the blur is what Sam's proximity
pattern is doing in Tovolume. This single image is then used to create
the isosurfaces with the following code:
//------------------- Cut here --------------------------
global_settings {
     assumed_gamma 1.00
     ambient_light srgb <1.00,1.00,1.00>
#declare Grey35 = srgbft <0.35,0.35,0.35,0.00,0.00>;
background { color Grey35 }
#declare Camera00 = camera {
     perspective
     location <2.00,2.00,-2.00>
     sky <0.00,1.00,0.00>
     angle 35.00
     right x*(image_width/image_height)
     look_at <0.00,0.00,0.00>
#declare White = srgbft <1.00,1.00,1.00,0.00,0.00>;
#declare Light00 = light_source { <50.00,50.00,5.00>, White }
#declare Red = srgbft <1.00,0.00,0.00,0.00,0.00>;
#declare CylinderX = cylinder {
     <-1.10,0.00,0.00>, <1.10,0.00,0.00>, 0.01
     pigment { color Red }
#declare Green = srgbft <0.00,1.00,0.00,0.00,0.00>;
#declare CylinderY = cylinder {
     <0.00,-1.10,0.00>, <0.00,1.10,0.00>, 0.01
     pigment { color Green }
#declare Blue = srgbft <0.00,0.00,1.00,0.00,0.00>;
#declare CylinderZ = cylinder {
     <0.00,0.00,-1.10>, <0.00,0.00,1.10>, 0.01
     pigment { color Blue }
#include "functions.inc"
#declare Fnct00 = function {
     pigment{image_map {"blur.png" gamma 1.0 once map_type 0 interpolate
3 }}
#declare Fnct01 = function (x,y,z) { Fnct00(x,y,0).red-0.95 }
#declare Fnct02 = function (x,y,z) { Fnct01(f_r(x,0,z),y,f_th(x,0,z)) }
#declare Fnct03 = function (x,y,z) {
     // Fnct02(x,y,z)+(f_noise3d(x*29.0,y*29.0,z*29.0)*0.900)
        Fnct02(x,y,z)+(f_agate(x*9.0,y*9.0,z*9.0)*0.900)
     // Fnct02(x,y,z)+(f_bozo(x*29.0,y*29.0,z*29.0)*0.900)
     // Fnct02(x,y,z)+(f_ripples(x*29.0,y*29.0,z*29.0)*0.900)
     // Fnct02(x,y,z)+(f_wrinkles(x*29.0,y*29.0,z*29.0)*0.900)
     // Fnct02(x,y,z)+(f_crackle(x*29.0,y*29.0,z*29.0)*0.900)
     // Fnct02(x,y,z)+(f_granite(x*2.0,y*2.0,z*2.0)*0.900)
     // Fnct02(x,y,z)+(f_leopard(x*49.0,y*49.0,z*49.0)*0.900)
     // Fnct02(x,y,z)+(f_wood(x*49.0,z*49.0,y*49.0)*0.900)
#declare Magenta = srgbft <1.00,0.00,1.00,0.00,0.00>;
#declare Iso00 = isosurface {
     function { Fnct03(x,y,z) }
     contained_by { box { <-0.68,0.02,-0.68>,<0.68,0.98,0.68> } }
     threshold 0.00
     accuracy  0.001
     max_gradient 160.00
     max_trace 1
     pigment { color Magenta }
camera { Camera00 }
light_source { Light00 }
object { Iso00 }
object { CylinderX }
object { CylinderY }
object { CylinderZ }
The three magenta vase show the shapes from the three internal functions
above.
The solid silhouette and Gaussian blur technique can be replaced in
gimp, photoshop with a blurred paintbrush. I been have fun just drawing
whatever freehand and watching shapes appear...
Notes:
1) As in Sam's Tovolume code, the blur depth from white to black sets
the limit for how much other functions can displace the surface.
2) The inverse blur image (white blurry lines on black) & base iso
function didn't work because povray seems to be returning 1.0 for out of
range values from the image_map.
3) The image_map interpolation with black on the png image edges causes
noise on the opposite edge despite using "once". Shrink the contained_by
range on that edge a little to avoid it. Sam did something similar in
his code which had me puzzled until I saw the edge interpolation, wrap
noise.
Have fun & thanks Sam for the image map with blurred image to isosurface
find!
Bill P.
Download 'blur.png' (38 KB) Download 'fnct03.jpg' (61 KB) Download 'fnct02.jpg' (49 KB) Download 'fnct01.jpg' (66 KB)
Preview of image 'blur.png'
Preview of image 'fnct03.jpg'
Preview of image 'fnct02.jpg'
Preview of image 'fnct01.jpg'
Subject: Re: Tovolume: Sam found ridiculously easy way to create shapes.
Date: 21 Oct 2013 11:24:28
Message: <5265472c@news.povray.org>
> isosurface shapes.
A very interesting application of Sam's code, full of paths to explore!
Paolo
Date: 21 Oct 2013 11:53:16
Message: <52654dec$1@news.povray.org>
> isosurface shapes.
...which only goes to show how productive you can be when freed from the
constraints of making a living.
Excellent work, Bill
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 21 Oct 2013 13:46:20
Message: <5265686c@news.povray.org>
> John
Indeed & thanks - though this trick is very much built on Sam's find.
Attached is a more artistic image using Sam's plane and two colored,
adaptive area lights. Area lights, alas, with areas that are somewhat
too small. In anycase an ugly vase it is. :-)
1hr 9 minutes on i7 920 overclocked to 3.4Ghz.
Bill P.
Download 'uglyvase.jpg' (157 KB)
Preview of image 'uglyvase.jpg'
Date: 22 Oct 2013 02:55:51
Message: <52662177$1@news.povray.org>
That's a very interesting application, full of potentials indeed. This
vase clearly proves it. Well done.
[opens ToDo volume 2, page 134]
Date: 26 Oct 2013 20:09:51
Message: <526c59cf$1@news.povray.org>
> isosurface shapes.
>      threshold 0.00
>      accuracy  0.001
>      max_gradient 160.00
>      max_trace 1
I have'nt tryed the third version, but I got very good renders, much
faster after some little changes to your code.
First, max_gradient 160 if huge overkill.
Using max_gradient 1.5 resulted in a nice render without any message
about max_gradient been to small or to large.
Next, I used:
#declare MinFact = 0.6;
evaluate 1.5*MinFact, sqrt(1/MinFact), 0.7
and got a slightly faster render.
Next, I reduced the contained_by object as follow:
box {<-0.34,0.02,-0.34><0.34,0.908,0.34> }
It's now much tighter and large enough to contain the whole isosurface.
This got me another performance increase.
Date: 27 Oct 2013 10:15:53
Message: <526d2019$1@news.povray.org>
> Next, I used:
> Alain
Yes, good suggestions. I didn't tighten up my scribble and render set up
before posting and I've never gotten my head to understand the evaluate
option of isosurfaces.
Your post reminded me of one note I forgot to mention. On reading the
image file, it is possible to play with the gamma option - even outside
the range of common gamma values. You can get interesting scalloping
effects. Especially true where the image is used for flat surface
displacements.
Bill P.
Date: 27 Oct 2013 17:50:46
Message: <526d8ab6$1@news.povray.org>
>> Next, I used:
>> Alain
Relatively simple:
You first do a render using the default max_gratient value and get the
reported max_gradient in the message.
Next, you just plug that value in the first parameter. The two others
are normaly correct using sqrt(1/MinFact) and 0.7 with MinFact set to
the proposed value of 0.6.
This information on how to use the feature was prety obscure in the
documentation for version 3.6, it now much clearer in version 3.7.
The main advantage is that it allow faster renderings.
You don't need to understand it to use it.
> displacements.
> Bill P.
Isosurface tip: Always make the containing shape as tight as possible.
Date: 27 Aug 2014 16:55:01
Message: <web.53fe45105ac41c3b5e7df57c0@news.povray.org>
I'm playing with this set of files, the problem is that when I get to the
Slice.pov step, it's not creating any files that I can see.
I started off with the initial command line parameters:
+fng -f +a0.3 +am2 +r2 +w81 +h68 +kff32
and then added:
But sadly, that did not seem to work.
Date: 27 Aug 2014 17:15:00
Message: <web.53fe4a4e5ac41c3b5e7df57c0@news.povray.org>
Sorry - it was an RTFM thing.  I guess I should have started F1'ing the command
line options from the beginning, not the end.  :\
Also needed to redefine size to
#declare Size = <81, 68, 32>;
in IsoRender to have it work with the 'default' output files.
This is wicked cool.  :)
