POV-Ray : Newsgroups : povray.binaries.images : Heightfield to isosurface - how to constrain the pigment function to a certain coordinate range? Server Time
27 Oct 2025 06:20:44 EDT (-0400)
  Heightfield to isosurface - how to constrain the pigment function to a certain coordinate range? (Message 1 to 4 of 4)
Subject: Heightfield to isosurface - how to constrain the pigment function to a certain coordinate range?
Date: 3 Jul 2013 19:42:28
Message: <51d4b6e4$1@news.povray.org>
Hi(gh)!
Apart from mesh2s at close view generally looking angular and thus
non-realistic, I probably also won't get rid of the notorious gaps
between the triangles if I stick to mesh2s.
So I started to look up Christoph Hormann's earth_simple_free.pov
(http://www.imagico.de/pov/earth_scene.php), well aware that this script
is intended for global renderings at a small scale rather than
high-scale close ups like my Tristan da Cunha scenes.
In earth_simple_free.pov, Christoph turns an image_map mapped around a
sphere into a pigment function, which then is modified further:
#local fn_DEM=
	function {
			image_map {
				ImageFile_Auto(IMG_Topo)
				map_type 0
				interpolate 3
				once
#local fn_DEM_Height=function { (fn_DEM(x, y, 0).red - 0.5)*2 * 32.767 }
#local fn_Shape=function { f_sphere(x, y, z, Earth_Radius)  }
#local fn_Pattern=
	function {
		fn_DEM_Height(1-(f_th(x,z,y)+pi)/(2*pi), f_ph(x,-z,y)/pi, 0)
#local fn_Iso=
	function {
		fn_Shape(x,y,z)-
		fn_Pattern(x,y,z)*Height_Exaggerate
isosurface{
	function { fn_Iso(x,y,z) }
	max_gradient 1.2
	accuracy 0.001
	contained_by{ sphere{ <0,0,0>
Earth_Radius+Max_Mountain*Height_Exaggerate } }
			Pig_Relief
		finish {
			ambient Terrain_Ambient
			diffuse 0.5*Terrain_Brightness
	hollow on
// end of code
But as ASTER DEMs are 3601 by 3601 data points per square degree and
probably noone of us is able to handle one single giant DEM of the
entire Earth at this resolution, I now would like to know whether it is
possible to constrain the DEM (with my script: heightfield) pigment
function to a certain range of geographical coordinate (with the Tristan
See you in Khyberspace!
Yadgar
Subject: Re: Heightfield to isosurface - how to constrain the pigment functionto a certain coordinate range?
Date: 4 Jul 2013 04:38:10
Message: <51d53472$1@news.povray.org>
Just a guess, and I don't know how to do it, but the contained_by{} code
of the isosurface seems indicated. Probably a box with the geographical
coordinates transposed into xz coordinates and y determined by your
intended height?
Subject: Re: Heightfield to isosurface - how to constrain the pigment functiontoa certain coordinate range?
Date: 4 Jul 2013 04:57:13
Message: <51d538e9$1@news.povray.org>
Hi(gh)!
> intended height?
Probably not, as the heightfield image is projected onto an entire
sphere already in the very first function... this would only work if I
used a GIANT heightfield (and by "giant", I mean 3600 x 360 by 3600 x
180 pixels, which would add up to about 839 GB...)!
Yadgar
Subject: Re: Heightfield to isosurface - how to constrain the pigment functiontoacertain coordinate range?
Date: 4 Jul 2013 05:00:37
Message: <51d539b5$1@news.povray.org>
Hi(gh)!
...if it was 8-bit, but it is 24-bit, so it would be even about 2.5 TB!
What PC can handle several terabytes of RAM? Perhaps around 2030...
Yadgar
Now playing: Psychopoly (Zara-Thustra)
