Toying around with SSLT and the "Stanford Lucy" model, I didn't aim for
this - it just happened to me. Now ain't she a beauty?
Download 'stanford_lucy.png' (501 KB)
Preview of image 'stanford_lucy.png'
Hey cool ... how about a little summary of the settings you used, I
could use a little sanity check. I'm guessing/hoping you were playing
with mm_per_unit?
Am 05.03.2012 22:23, schrieb James Holsenback:
> with mm_per_unit?
The Lucy model is ~1.5 POV-Ray units in height.
mm_per_unit is set to 100, so Lucy is ~15 cm in height.
Material must have been something like this:
material {
marble
warp { turbulence 1.0 }
color_map {
[0.0 color rgb <0.5,0.7,0.5>]
[1.0 color rgb <0.5,1.0,0.5>]
finish { subsurface { translucency 20 } }
scale 0.1
interior { ior 1.5 }
The translucency setting means that a photon can travel an average of 20
mm within the material before it is either scattered or absorbed.
>> with mm_per_unit?
> material {
> texture {
> pigment {
> marble
> color_map {
> scale 0.1
Ah ... then I'm on the right track. BTW: the last sentence really ties
it all together for me, so ... thanks!!!
