Some soap bubbles, rendered with a complete re-design of the iridescence
feature.
Download 'test.png' (335 KB)
Preview of image 'test.png'
... and two pearls.
Download 'test.png' (139 KB)
A bearing ball with a thin coat of I-have-no-idea-what.
Download 'test.png' (187 KB)
> feature.
Oh! Very nice! Will this fix make it into 3.7?
> feature.
Excellent! A little treat for Jim's shells... ;-)
Am 01.12.2011 07:39, schrieb waggy:
>> feature.
I think so. It will break scenes relying on the crappy(*) existing
iridescence, so it's better to introduce it with the transition from 3.6
to 3.7, rather than 3.7.0 to 3.7.1 or something.
(*For starters, the existing implementation doesn't respect a light
source's color, or even brightness for that matter.)
Am 01.12.2011 04:23, schrieb clipka:
> .... and two pearls.
now with blurred reflection.
Download 'test.png' (201 KB)
Am 01.12.2011 09:23, schrieb Thomas de Groot:
>> feature.
Yup.
> feature.
Outstanding ... I'll keep an eye on revision control. I'm anxious to get
it a test drive. Since, it would seem, that my sea shell attempt at
using iridescence is what inspired you to dig into this, I have a
question about the aoi pattern that was mentioned as an alternative ...
you wouldn't expect it (aoi) to respond to other pattern modifiers
correct, as it doesn't appear to. However when I read the doc passage,
"It gives a value proportional to the angle between the ray and the
surface" it makes me think that's correct behavior. If this is true
enough, perhaps I should make a slight addition to that passage to clarify.
Jim
>> feature.
> Thomas
don't you just love good news first thing in the morning!
