POV-Ray : Newsgroups : povray.binaries.images : SSLT Dragon Server Time
29 Jul 2026 00:33:45 EDT (-0400)
  SSLT Dragon (Message 26 to 35 of 105)
Subject: Re: SSLT Dragon
Date: 2 Mar 2011 06:16:50
Message: <4d6e2722$1@news.povray.org>
On 02/03/2011 9:19 AM, Bill Pragnell wrote:
> Stephen<mcavoys_at@aoldotcom>  wrote:
>> Nice but use aa it makes a difference.
> But does it? I thought aa was wasted on otherwise supersampled features like
> area lights, focal blur, media etc? The edges of lucy's self-shadows are lovely,
> it's just the floor shadow and her horizon that show aliasing. I'll do some aa
> tests tonight.
I did a test without aa and there are more artefacts in the non-aa
rendering.
>> Your image looks more like marble what settings did you you use?
> Excellent, I was shooting for a very translucent marble.
> mm_per_unit = 80 (the model is about 1 unit high)
> samples 1000, 100 (only way I could get rid of bright point artifacts)
> subsurface { 5*colour, 0.5*(1-colour) } (IIRC!)
So your model is about 80 mm (3 inches) why pick that value?
This is something I'm having difficulty getting my head around. :-(
Regards
Date: 2 Mar 2011 07:00:00
Message: <web.4d6e3131d81bd80d6dd25f0b0@news.povray.org>
> rendering.
I see what you mean. The artifacts were definitely lessened by aa, but they were
lessened much more by increasing the sampling :)
Well, I was basically just tweaking until it looked good. I don't really
understand what the subsurface:mm_per_unit ratio means, although the
scattering:absorption ratio of the subsurface values seems more intuitive (not
dissimilar to media).
I think the mm_per_unit value kind of makes sense - most everyday experience
with translucent stone objects is small statues/knick-knacks. For larger items
(metres and larger), I would expect the translucency to be much more subtle, or
even invisible, due to the greater path lengths.
I think word-of-god elucidation is required :)
Date: 2 Mar 2011 08:22:37
Message: <4d6e449d$1@news.povray.org>
>> rendering.
OK, that saves me some experimenting.
I agree that the subsurface values seems more intuitive.
I think that I'll wait until RC4, where the syntax will change, before
playing any more.
Regards
Date: 2 Mar 2011 12:40:29
Message: <4d6e810d@news.povray.org>
> mm_per_unit = 80
Using your setting of mm_per_unit  80 and subsurface {samples 500, 100 }
I think that this one turns out nice. It took five and a half hours to
after my laptop overheated)
Regards
Download 'lucy10_01c_.jpg' (183 KB)
Preview of image 'lucy10_01c_.jpg'
Date: 2 Mar 2011 12:50:07
Message: <4d6e834f$1@news.povray.org>
>> mm_per_unit = 80
I thought you were gonna wait for RC4
Now go have a cup of tea and let the ole laptop cool down for a bit ;-)
Date: 2 Mar 2011 12:51:57
Message: <4d6e83bd@news.povray.org>
> Now go have a cup of tea and let the ole laptop cool down for a bit;-)
LOL
It was already rendering when I wrote that.
A cup of tea sounds good though.
Regards
Date: 2 Mar 2011 14:40:01
Message: <web.4d6e9cddd81bd80d86ff1d480@news.povray.org>
> On 24/02/2011 9:30 AM, Bill Pragnell wrote:
> >> I had the same problem with Lucy, using MeshLab. Somehow I could not get it
> >> >  converted.
> > What seemed to be the issue? I also converted Lucy (I think with Meshlab +
> > Poseray) a couple of years ago and had no problems. I did lower the triangle
> > count a bit, since the file size was vast and I knew most of it would be
> > sub-pixel in the scene I was making...
> MeshLab fails with an error message saying that the application has
> requested the Runtime to terminate in an unusual way.
> PoseRay might do it. But slowly, slowly!
> After about 10 minutes loading the PLY file the % completed bar is at
> about 2%.
> Regards
>      Stephen
Wow, I'm having deja vu; I converted Lucy with MeshLab and rendered a few SSLT
versions right after the feature first appeared about a year and half ago:
http://news.povray.org/web.4a9f2cce63e55f164726e92b0@news.povray.org
And uploaded the inc file to my web site, the link is here:
http://news.povray.org/web.4aa18ba663e55f164726e92b0@news.povray.org
I'm going to have to try that dragon now though...
Cheers,
Rob
www.McGregorFineArt.com
Date: 2 Mar 2011 15:20:00
Message: <web.4d6ea60ad81bd80da7b682960@news.povray.org>
> LOL
You could boil the water on your cpu heatsink ;-)
Date: 2 Mar 2011 16:19:35
Message: <4d6eb467$1@news.povray.org>
OK what am I doing wrong? I've used mesh objects before so I'm not
blazing any new territory here. I see the parse (tokens) of the object
then the render ... get an empty scene except my ground plane and light
source (zoomed way back looked u/d ... scaled too) don't see nuttin' ...
I should be able to (after including the Lucy file I downloaded from
your site and do:
object { Lucy_Statue pigment {rgb 1}}
btw stats just show 2 objects (plane and light_source)
shucks ... I wanted to play too ;-)
Date: 2 Mar 2011 17:16:12
Message: <4d6ec1ac$1@news.povray.org>
On 02/03/2011 8:18 PM, Bill Pragnell wrote:
> You could boil the water on your cpu heatsink;-)
I could burn the heal of my hands on my laptop. (No kidding)
Regards
