The image shows 2 fewer hues than the dispersion_samples value.
The first image shows the setup I used for testing. The wall near the
camera casts a shadow on the screen for contrast.
The second image is the actual test. The numbers 3 through 10 are the
values of dispersion_samples for the pair of prisms above each. The
prisms in the top row cast a narrow slit of photons onto the screen right
below the numbers. The prisms in the lower row refract the white line
near the bottom.
I'm using version 3.6.2 (32-bit), but I've noticed the problem in earlier
versions. My OS is Windows XP 2002 Media Center Edition SP3.
<Insert witty .sig here>
Download 'dispersion_samples-ov.png' (28 KB)
Download 'dispersion_samples.png' (53 KB)
Preview of image 'dispersion_samples-ov.png'
![dispersion_samples-ov.png](/povray.binaries.images/attachment/%3Cop.uvxtzhvb6b35ac%40your-727a0a4e7c.vipowernet.net%3E/dispersion_samples-ov.png?preview=1)
Preview of image 'dispersion_samples.png'
![dispersion_samples.png](/povray.binaries.images/attachment/%3Cop.uvxtzhvb6b35ac%40your-727a0a4e7c.vipowernet.net%3E/dispersion_samples.png?preview=1)
