POV-Ray : Newsgroups : povray.binaries.images : No new images for 5 days? Server Time
30 Jul 2026 18:44:29 EDT (-0400)
  No new images for 5 days? (Message 18 to 27 of 27)
Subject: Re: No new images for 5 days?
Date: 2 Dec 2008 09:12:47
Message: <4935425f@news.povray.org>
> Been busy having a baby.  Born last Sunday :-)
Congratulations!  My wife has one in the oven right now, due in late
February.  :D
Date: 2 Dec 2008 11:13:09
Message: <49355e95$1@news.povray.org>
> February.  :D
This might be a slight surprise, but babies are not ment to be eaten nor
cooked. Take it out of the oven!
-Aero
Date: 3 Dec 2008 14:05:01
Message: <web.4936d804daef02f6f91b32f80@news.povray.org>
"TC" <do-not-reply@i-do get-enough-spam-already-2498.com> wrote:
> Hi, everybody!
> The last image I did see was Xplayer background. No new images for 5 days?
> What happened?
Here's one.
-Mike
Download 'ptv_carriagehouse_new0.png' (302 KB)
Preview of image 'ptv_carriagehouse_new0.png'
Date: 3 Dec 2008 20:35:05
Message: <493733c8@news.povray.org>
SharkD wrote:
> Here's one.
> -Mike
Damn, where's my spherical pano image viewer?!
Date: 4 Dec 2008 09:15:00
Message: <web.4937e515daef02f6d5b77e4a0@news.povray.org>
Nicolas Alvarez <nic### [at] gmailcom> wrote:
> SharkD wrote:
> > Here's one.
> > -Mike
I've a better idea - let's have the HDR light probe version! That looks like a
nice environment. :)
Date: 5 Dec 2008 05:20:01
Message: <web.4939002bdaef02f62f5b7da70@news.povray.org>
> > SharkD wrote:
> > > Here's one.
> > > -Mike
I'm not sure what you mean. Recently I learned that some of the panorama viewers
support HDR, but how do I create it in POV and then translate it to the viewer?
-Mike
Date: 5 Dec 2008 09:15:01
Message: <web.4939364ddaef02f6d5b77e4a0@news.povray.org>
"SharkD" <nomail@nomail> wrote:
> > > > Here's one.
You need to use MegaPOV for this; POV-Ray 3.6 doesn't support HDR images at all.
MegaPOV has a spherical camera and can output .hdr images, which can be used as
environment maps to illuminate a scene.
http://megapov.inetart.net/manual-1.2.1/megapov0121.html#hdr_write
and
http://megapov.inetart.net/manual-1.2.1/megapov0121.html#tutorials_hdri
Date: 5 Dec 2008 12:25:02
Message: <web.493963aadaef02f6fc815c730@news.povray.org>
> and
Thanks, I'll keep that in mind.
-Mike
Date: 6 Dec 2008 06:55:00
Message: <web.493a67cddaef02f6ba19b81b0@news.povray.org>
> and
Heh. I tried reading the tutorials you linked to and have to admit I have no
idea what is going on. Are you rendering an initial image and then wrapping it
around the scene in a sphere? Wouldn't this in effect limit the possible shapes
of the scene to something that can fit well inside a sphere? The scene I have
rendered is rectangular, and there are few or no objects of interest outside
this rectangle.
-Mike
Date: 6 Dec 2008 20:45:00
Message: <web.493b29e3daef02f6ea3236f00@news.povray.org>
> this rectangle.
The image you posted looks like a complete 360x360 degree spherical image. If
so, this could be wrapped on a large world-sphere and be used as an
environment. The spherical camera projection works the same way as the image
mapping, so it doesn't matter what your environment scene contains, it will map
to the sphere without distortion. (The top edge of the image is the zenith (+y),
the middle row is the equator and the bottom edge the nadir (-y). The left edge
meets the right edge at  a meridian that passes through the +x axis, by
default).
Using this environment map would allow you to render, say, a close-up of a
reflective object on a table, with reflections that would be indistinguishable
from actually having the environment scene around it. If the environment were
an hdr image, you could use radiosity and allow the environment-mapped sphere
to illuminate your subject, again, in a way that would be identical to having
the actual scene there.
The advantages of this technique are faster rendering (intersection tests and
lighting calculations on the environment objects are cut to simple intersection
tests with a single sphere), and you can share the environment map without
having to supply the complete environment scene.
Bill
