POV-Ray : Newsgroups : povray.binaries.images : Energy drink Server Time
30 Jul 2026 21:04:03 EDT (-0400)
  Energy drink (Message 11 to 13 of 13)
Subject: Re: Energy drink
Date: 12 Aug 2008 17:48:35
Message: <48a20532@news.povray.org>
Mike Williams wrote:
> It looks like you might be attempting to difference the
> can with a union of blobs each of which have a single
> element.
Yes, you're right.
> That doesn't gain you the advantage of the blob
> trick. What you have to do is difference the can with a
> single blob object that has lots of components.
> blob { threshold 1
>     cylinder { <0,0.6,0><2,0.6,2>, 0.03, 10000 }
>       rotate <0,RotY1,0>
>       translate <0,PosY1,0>
>       rotate <0,RotY2,0>
>       translate <0,PosY2,0>
>       rotate <0,RotY3,0>
>       translate <0,PosY3,0>
I assume you mean this (see the position of brackets):
blob { threshold 1
      rotate <0,RotY1,0>
      translate <0,PosY1,0> }
      rotate <0,RotY2,0>
      translate <0,PosY2,0> }
      rotate <0,RotY3,0>
      translate <0,PosY3,0> }
Anyway, I changed the structure to single blob version and
got render time of... 1 hour 6 minutes! It's shorter time
with the previous run, but still very much the same as with
the original code, so at this time blobs didn't speed up
things. That is tragical, because I already had strong
faith in faster rendering. :=)
   Larp
Date: 13 Aug 2008 00:14:38
Message: <P2D4$IBo+loIFwIB@econym.demon.co.uk>
The scene below takes 2 seconds to render on my machine. I can imagine
that fancy lighting and focal blur would slow it down, but not by that
much.
How fast is your scene without the holes?
camera {location  <0, 2, -10> look_at <0,1,0> angle 40}
light_source { <0, 0, 0> color rgb 1  translate <-30, 30, -30>}
#declare CAN = difference {
   cylinder { <0, 0, 0>, <0, 3, 0>, 1 }
   cylinder { <0, -0.1, 0>, <0, 3.1, 0>, 0.97 }
#declare R1 = seed(123);
#declare HOLES = blob { threshold 1
   #declare N=0;
   #while (N<1000)
     sphere { <0.985,0.6,0>, 0.03, 10000
       rotate <0,rand(R1)*360,0>
       translate <0,rand(R1)*2,0> }
     #declare N=N+1;
difference {
   object {CAN}
   object {HOLES}
   pigment {rgb 1}
Mike Williams
Gentleman of Leisure
Date: 13 Aug 2008 15:44:48
Message: <48a339b0@news.povray.org>
> can imagine that fancy lighting and focal blur would slow
> it down, but not by that much.
Rendering without holes or focal blur took 6 minutes 3
seconds.
The can is defined in separate include file which is quite
complex cocktail of lathes, prisms, tori, sphere sweeps
etc. - in overall 444 rows. I'm not surprised rendering
takes some time. Still I'm somehow happy with the results,
even to render something like this 29 hours is not sane at
all...
   Larp
