POV-Ray : Newsgroups : povray.binaries.images : New Stairs Macro Server Time
31 May 2026 13:07:36 EDT (-0400)
  New Stairs Macro (Message 1 to 4 of 4)
Subject: New Stairs Macro
Date: 12 May 2006 08:27:43
Message: <44647f3f@news.povray.org>
I've just finished a new free stairs macro for POV-Ray which is designed to
enable you to add a staircase to a POV-Ray scene with the minimum of fuss.
It can be downloaded, along with documentation from
http://www.geocities.com/povstairs/.
The staircase can be controlled by setting a few simple variables, but
everything has a default setting, so that you can generate a staircase
straight away.
To get a straight flight of stairs you just need to specify the coordinates
of the bottom and top of the flight of stairs and POV-Stairs will do the
rest (You can of course easily override the default width and whether it's
carpeted etc.). You can also specify a sequence of positions and POV-Stairs
will create multiple flights of stairs joined by landings.
Here are three examples.
Chris B.
Download 'banner1.jpg' (28 KB) Download 'example5.jpg' (19 KB) Download 'staircaseexample3z.jpg' (147 KB)
Preview of image 'banner1.jpg'
Preview of image 'example5.jpg'
Preview of image 'staircaseexample3z.jpg'
Subject: Re: New Stairs Macro
Date: 12 May 2006 10:47:13
Message: <44649ff1@news.povray.org>
"Chris B" <c_b### [at] btconnectcomnospam> schreef in bericht
news:44647f3f@news.povray.org...
> Hi,
to
This is excellent, Chris!!!
I can think of many, many usages..... :-)
Date: 12 May 2006 10:51:58
Message: <4464a10e@news.povray.org>
Well done, Chris.
Things such as this are of great use for all of us.
I would like to ask you a few questions about your macro:
- Is the reeling flexible in its style (old-fashioned wooden style, new
glass-chrome style, etc.)?
- Just for creation of straight stairways or for round stairways, too?
- How many units are one meter (one unit equals to one meter)?
Greetings,
Sven
"Chris B" <c_b### [at] btconnectcomnospam> schrieb im Newsbeitrag
> Hi,
> to enable you to add a staircase to a POV-Ray scene with the minimum of
> fuss.
> straight away.
> coordinates of the bottom and top of the flight of stairs and POV-Stairs
> will do the rest (You can of course easily override the default width and
> whether it's carpeted etc.). You can also specify a sequence of positions
> and POV-Stairs will create multiple flights of stairs joined by landings.
> Regards,
> Chris B.
Date: 12 May 2006 11:40:32
Message: <4464ac70$1@news.povray.org>
"Sven Littkowski" <sve### [at] jamaica-focuscom> wrote in message
news:4464a10e@news.povray.org...
> Well done, Chris.
> Greetings,
> Sven
Hi Sven,
The components of the bannister rail can all be redefined (and the rest of
the stair components too), so you can replace the newel post shape by
declaring an object called SCNewelPost before calling the StairCase() macro.
You can therefore make each component more or less any shape you want. The
textures of the components are set separately, so by setting
SCNewelPostTexture for the newel post, you can make it out of glass, chrome
or anything you like.
There is an example for each object in the 02variables.html document.
Unfortunately I see the web site is hitting it's download limit, so it may
take a few attempts to get hold of the full documentation which is over 1MB
with all the sample graphics.
I've put a temporary copy of the macros and the documentation (but without
most of the graphics) at the following location in case anyone is getting
problems and is impatient to get started :
http://www.geocities.com/povperson/povstairsanddocnographics.zip
This macro only does chains of straight runs, but I did do a spiral
staircase a long time ago and I think that it should work just as well with
these components. I'll see if I can find it.
Yes, 1 unit represents 1 metre.
Chris B.
