![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
When learning instrument flying and the first few night flights you learn to
always have at least two (I like three) flashlights handy. There's a company
in California that makes cockpit lights for some situations before you have
to resort to the flight kit for a flashlight. The version I've modelled here
allows the pilot to save his night vision by using variable voltage and a
red filter, as well as adjusting for a flood or spot light effect.
I just think they're cool just like everything else about airplanes!
- Grim
Download 'CockpitLight.jpg' (56 KB)
Preview of image 'CockpitLight.jpg'
![CockpitLight.jpg](/povray.binaries.images/attachment/%3C41b9f1e7%40news.povray.org%3E/CockpitLight.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
GrimDude wrote:
Looks like the POV export on whatever program you are using chewed up
your mesh. Looks like a cool flashlight if it were cleaned up.
-Shay
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Shay" <sah### [at] simcoparts com> wrote in message
news:41ba1ab2$1@news.povray.org...
> GrimDude wrote:
> Looks like the POV export on whatever program you are using chewed up your
> -Shay
Thanks, Shay (I think). Where do you see this as being chewed up?
(Link to manufacturer's website)
http://www.soderberg.aero/images/pdf/S1210.pdf
- Grim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> chewed up?
see attached picture
-Shay
Download 'chewed.jpg' (4 KB)
Preview of image 'chewed.jpg'
![chewed.jpg](/povray.binaries.images/attachment/%3C41ba2473%241%40news.povray.org%3E/chewed.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Fascinating gizmo - I've learnt something!
For the imge quality, it wouldn't hurt to make the inner bore a smoother
circle (looks like a polygon with about 10 degree steps). Antialiasing won't
hurt the edges either.
DLM
"GrimDude" <a36### [at] bellsouth net> wrote in message
news:41ba2096$1@news.povray.org...
>> -Shay
> - Grim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Oh, I saw that as a mistake in 'error_bound.' With AutoCAD the mesh can be
smoothed further by increasing the 'isolines' variable, which is really
easy. I rendered this again with the new value for e_b and a doubling of the
mesh density. I tested it with the same e_b value and a mesh four times as
dense and the same effect could be seen, though reduced in severity.
Thanks for pointing that out.
- Grim
Download 'CockpitLight2.jpg' (4 KB)
Preview of image 'CockpitLight2.jpg'
![CockpitLight2.jpg](/povray.binaries.images/attachment/%3C41ba3340%241%40news.povray.org%3E/CockpitLight2.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> - Grim
You have done a good job modeling. Do the ones you use have a detachable
base and power cord?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Mr. Art" <pfl### [at] stx rr com> wrote in message
news:41ba86d3@news.povray.org...
Thanks. The base can be relocated, or interchanged. The power cord is
soldered to the bulb socket, so it can't really be removed except to service
the light. I didn't model the cord, because it's a simple matter to create
one should I ever use this in a cockpit scene (and you know I will). I will
probably use the older method of a stiff-cord (sort of like one of Doctor
Octopus' mechanical arms), if and when I do.
In AutoCAD the cord would be created with a circle swept (extruded) along a
helix path and then unioned with other sweeps as needed. I'm sure there's
probably a way to do that in Pov that would save on resources by comparison.
- Grim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
