POV-Ray : Newsgroups : povray.binaries.images : Lighthouse new version Server Time
4 Aug 2026 20:17:47 EDT (-0400)
  Lighthouse new version (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Lighthouse new version
Date: 15 May 2004 12:48:08
Message: <40a649c8$1@news.povray.org>
40a6436a$1@news.povray.org...
> Big improvement, a lot more realistic. Your water is great.
>Time to  concentrate on the ground.
It's in the *to do* next items :)
Marc
Date: 15 May 2004 13:04:19
Message: <40a64d93@news.povray.org>
That's the best sea I've seen anywhere - well done.
Mick
"Marc Jacquier" <jac### [at] wanadoofr> wrote in message
news:40a6394e@news.povray.org...
> For the foam I gave up  the object pattern trick because it is boolean and
> not good at close-up
> I tweaked a function based on the same image as the isosurface terrain.
> This function fills the crackle pattern at hi values and let it empty at
low
> values.
> As usual comments are welcome :-)
> Marc
Date: 15 May 2004 13:17:54
Message: <40a650c2@news.povray.org>
    Hi Marc, that's excellent! Great sea. I would have a go at adding
just a little hint of 'off-yellow', or 'cream' colour, if you will, to
*some* of your surf.
   ~Steve~
> Marc
Date: 15 May 2004 13:20:27
Message: <40a6515b$1@news.povray.org>
I also like the translucency of the waves just behind the surf. Spot
on!   :)
 ~Steve~
Date: 15 May 2004 13:36:04
Message: <40a65504@news.povray.org>
news: 40a64d93@news.povray.org...
Me flush
thanks Master
Marc
Date: 15 May 2004 13:44:55
Message: <40a65717@news.povray.org>
40a650c2@news.povray.org...
Thanks
Good idea for the cream color at thickened zones of the foam (I think it
happens only when seawater is carrying plankton, though)
Marc
Date: 15 May 2004 15:55:47
Message: <40a675c3$1@news.povray.org>
40a6515b$1@news.povray.org...
> on!   :)
Hours in front of waves  waiting for the take off :)
Marc
Date: 15 May 2004 17:28:43
Message: <40a68b8b$1@news.povray.org>
> This function fills the crackle pattern at hi values and let it empty at low
> values.
> Marc
curiousity, how tall is a lighthouse typically ?
how tal are the walls around the field ?
do the two and the view angle look correct ?
stephen
Date: 15 May 2004 18:00:51
Message: <40a69313@news.povray.org>
> Me flush
> thanks Master
Are you cheating? Is the sea a photo?
Not the foam - that is obviously CG - but the sea looks suspiciously like a
photo of some sort.
Hugo
Date: 15 May 2004 18:23:49
Message: <40A69829.1050909@hotmail.com>
> values.
> Marc
Your image has some shocking realism present in it. The grass, though,
could use some improvement(IMO).
Is that ocean an isosurface? A height_field of that size might take up a
huge amount of memory...
Good work~
-Sam Benge
