POV-Ray : Newsgroups : povray.binaries.images : Going Home Server Time
4 Aug 2026 20:05:57 EDT (-0400)
  Going Home (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Going Home
Date: 8 May 2004 11:19:43
Message: <409cfa8f$1@news.povray.org>
"stephen parkinson" <ste### [at] zmemw16demoncouk> wrote in message
news:409cb6b2$1@news.povray.org...
> Alf Peake wrote:
> > Wallpaper material.
> > However, the reflection seems brighter than the source?
You're right - I used an extra point light to get that o.t.t. look - it
probably was a bit much!
> is it me or is it out of line as well ?
Yup, I didn't notice this until I rendered it at a decent size, I'll post
the image without the excessive reflection when I have a few spare mins...
Dave.
Date: 9 May 2004 08:44:14
Message: <409e279e$1@news.povray.org>
Very nice.
Out of interest... how did you do the birds?
Andrew @ home.
Date: 9 May 2004 11:24:32
Message: <409e4d30$1@news.povray.org>
Dave Sproson wrote:
> Just another landscape...
> Dave.
Just another "Really NICE" landscape.
Dave Matthews
Date: 9 May 2004 14:42:12
Message: <409e7b84@news.povray.org>
"Andrew C on Mozilla" <voi### [at] devnull> wrote in message
news:409e279e$1@news.povray.org...
> Very nice.
Knocked them together (very quickly) in sPatch. I knew they were only going
to be seen from a distance, so they look _really_ terrible close to!
Dave
Date: 9 May 2004 14:52:33
Message: <409e7df1$1@news.povray.org>
...still better than the triangles I used. :-$
(As in, each "bird" was just a single jet-black triangle.)
But then, I'm rubbish, sadly...
Andrew @ home.
Date: 10 May 2004 04:35:08
Message: <409f3ebc@news.povray.org>
Oh, your so wrong!  This is not "just another landscape" this is a blummin
loverly poster-like quality to it.  Very Nice.
Date: 12 May 2004 17:42:53
Message: <nms4a051ckbvc9ecpnijacdpj9mba4l9cn@4ax.com>
On Sat, 08 May 2004 11:23:22 +0100, stephen parkinson
<ste### [at] zmemw16demoncouk> wrote:
>also sun seems oversized ?
If you are referring to technical realism, then not necessarily. The
Sun's apparent size depends on the camera's angular field of view.
FYI, the Sun's angular diameter can be calculated by dividing the
Sun's diameter by the Earth-Sun distance.   This works out, on
average, to 0.00929 radians, or about 0.53 degree.  So with the Sun
modeled accurately, if camera { angle 3 } is used, then the Sun
*would* look as big as in Dave's image.
If you are talking about artistic composition, it's therefore just a
matter of taste, and of what effect Dave wants to achieve.  The size
does seem a bit awkward to me; it looks as if the Sun is too big for
its reflection in the water, or conversly, the reflection is too
narrow for the size of the Sun.  The relative dimness of the Sun
(which is acknowledged) might also be contributing to the sense that
the Sun isn't quite right.
(This is one inaccuracy that shows up in a lot of astronomy paintings.
Up close, a star is too bright to look at--our Sun is an example of
this.  Yet, most artist renderings of stars show all the granulation
and other surface features, which are impossible to see without very
dark or narrowband filters.)
Whatever the size of the Sun however, i think it would have a better
"sunset" feel if it were flattened slightly into an oval, the way
sunsets appear IRL.  (This happens due to refraction through the
atmosphere; the atmosphere is much thicker towards the horizon than
overhead.)
------------------- Richard Callwood III --------------------
~  U.S. Virgin Islands    ~  USDA zone 11  ~  18.3N, 64.9W  ~
~  eastern Massachusetts  ~  USDA zone 6 (1992-95)          ~
--------------- http://cac.uvi.edu/staff/rc3/ ---------------
Date: 12 May 2004 18:46:48
Message: <40a2a958$1@news.povray.org>
Hash: SHA1
	Remember that we are inside the atmosphere which causes the apparent
size of the sun to change from what it would be viewed from the same
distance in space. In particular, the sun appears bigger when it's
near the horizon, which is the case here...
		Jerome
*      Jerome M. Berger      *
* mailto:jbe### [at] ifrancecom *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAoqlXqIYJdJhyixIRAuQNAKCnX1nIqmH9ckHYpLeIq/0YNUMPuwCgkdxl
4CJxQEceAaOP8ew01aPPCdI=
=J17U
-----END PGP SIGNATURE-----
Date: 13 May 2004 03:23:22
Message: <40a3226a$1@news.povray.org>
40a2a958$1@news.povray.org...
> Jerome
That's half true: light rays bend due to gradient air density and variable
ior but that flattens sun image rather than inflates.
Bigger sun near the horizon is mostly an illusion due to possible comparison
with known references.
Our brain believes that sun is on the  same skysphere as the sky which is
far at the horizon.
As angular size of the sun remains the same, our brain "thinks" it is bigger
Try  (not too long eh?) looking at the sun through a tube when it is low, so
you make abstraction of surrounding and you get rid of this illusion.
Marc
Date: 13 May 2004 14:55:21
Message: <nd17a0ta7v7gcjm23hsld083oqhm9lrvd1@4ax.com>
On Thu, 13 May 2004 09:25:07 +0200, "Marc Jacquier"
This is why the Sun appears oval at sunset.
>far at the horizon.
Marc is correct;  it's a psychological illusion, not an optical
effect.  Photographs prove this.  More information is available at:
 http://science.nasa.gov/headlines/y2002/24jun_moonillusion.htm
Better with the Moon!  The illusion is the same, but you get to keep
your eyesight.
I've also read that looking at the Moon upside-down will also kill the
effect.  This exercise came with the suggestion that you not try it
where other people can see you. ;-)
