![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I killed povray!!!
Can someone help me render a scene,
I am working on this abstract thing and i am trying to render it but its
taking forever.
Will someone with a fast processor or way of rendering help me...
Or maybe some help taking time off rendering...
I like the scene as is so anything that is not destructive to the way it
looks or renders would be great.
I would love it so much if it could be 1024-768 aa 0.3
Thanks Tonnes!!!!
Source
#declare Radiosity=on
global_settings {
assumed_gamma 1.0
//max_trace_level 25
#if (Radiosity)
radiosity {
pretrace_start 0.08 // start pretrace at this size
pretrace_end 0.04 // end pretrace at this size
count 35 // higher -> higher quality
(1..1600) [35]
nearest_count 5 // higher -> higher quality (1..10) [5]
error_bound 1.8 // higher -> smoother, less
accurate [1.8]
recursion_limit 3 // how much interreflections are
calculated (1..5+) [3]
low_error_factor .5 // reduce error_bound during last
pretrace step
gray_threshold 0.0 // increase for weakening colors
(0..1) [0]
minimum_reuse 0.015 // reuse of old radiosity samples
[0.015]
brightness 1 // brightness of radiosity effects
(0..1) [1]
adc_bailout 0.01/2
//normal on // take surface normals into
account [off]
//media on // take media into account [off]
//save_file "file_name" // save radiosity data
//load_file "file_name" // load saved radiosity data
//always_sample off // turn sampling in final trace off
[on]
//max_sample 1.0 // maximum brightness of samples
//-------------- Includes
#include "textures.inc"
#include "metals.inc"
//---------------------------- Variables for size and seed
#declare R = seed(12);
#declare num_spheres = 40;
#declare area=10;
#declare min_size = .15;
#declare max_size = .35;
#declare thing = sphere_sweep {
//linear_spline | b_spline | cubic_spline
cubic_spline
num_spheres,
#declare i = 0;
#declare start_pos = <rand(R)*area-(area/2), rand(R)*area-(area/2),
rand(R)*area-(area/2)>;
start_pos, rand(R)*(max_size - min_size)+min_size,
#while (i<num_spheres - 2)
#declare s_size = rand(R)*(max_size - min_size)+min_size;
rand(R)*area-(area/2)>, s_size,
#declare i = i + 1;
//no_shadow
object {thing texture {T_Chrome_2E }}
/*light_source {
0*x
color rgb <1,1,1>
translate <0, 10, -10>
light_source {
0*x // light's position (translated below)
color rgb 1.0 // light's color
area_light
<8, 0, 0> <0, 0, 8> // lights spread out across this distance (x * z)
4, 4 // total number of lights in grid (4x*4z = 16 lights)
adaptive 4 // 0,1,2,3...
jitter // adds random softening of light
circular // make the shape of the light circular
orient // orient light
translate <40, 80, -40> // <x y z> position of light
location <0,1.5,-8.5>
look_at <0, 0, 0>
//-------------------------------------------- Extra Scene objects
sky_sphere { pigment { White} }
// gradient y
// color_map {
// [0.0 rgb <0.6,0.7,1.0>]
// [0.7 rgb <0.0,0.1,0.8>]
plane {
y, -1.5
pigment { color rgb <0.7,0.5,0.5> }
plane {
y, -3.5
//pigment{White}
pigment { rgb <1,1,1 > }
finish {
ambient 0
diffuse 0
reflection .3
brilliance 0
specular 1
roughness 1
#declare thin = union {
torus {
0.8,
0.2
scale y*1
torus {
0.8,
0.2
scale z*2
rotate x*90
#declare thig2 = union {
object{thin scale 1 texture {T_Chrome_2D}//no_shadow
rotate z*0}
object{thin scale 1.2 texture {T_Chrome_2E}//no_shadow
rotate z*45}
object{thin scale 1.4 texture {T_Chrome_3A}//no_shadow
rotate z*90}
object{thin scale 1.6 texture {T_Chrome_4B}//no_shadow
rotate z*135}
object{thin scale 1.8 texture {T_Chrome_4C}// no_shadow
rotate z*180}
object{thin scale 2 texture {T_Chrome_2A}//no_shadow
rotate z*225}
object{thin scale 2.2 texture {T_Chrome_2B}//no_shadow
rotate z*270}
object{thin scale 2.4 texture {T_Chrome_2C}//no_shadow
rotate z*315}
object {thig2 }
//sphere { <0, -2.5, 5>, 1 pigment {Red}}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Also my image that i'm posting is the source, ty
Flaming Monarch wrote:
> I killed povray!!!
> taking forever.
> Thanks Tonnes!!!!
> Source
> global_settings {
> assumed_gamma 1.0
> #if (Radiosity)
> radiosity {
> (1..1600) [35]
> error_bound 1.8 // higher -> smoother, less accurate
> [1.8]
> pretrace step
> (0..1) [0]
> [0.015]
> (0..1) [1]
> adc_bailout 0.01/2
> //normal on // take surface normals into account
> [off]
> [on]
> #end
> #declare area=10;
> cubic_spline
> num_spheres,
> #declare i = 0;
> #declare i = i + 1;
> #end
> //no_shadow
> /*light_source {
> 0*x
> color rgb <1,1,1>
> light_source {
> area_light
> camera {
> look_at <0, 0, 0>
> // gradient y
> // color_map {
> plane {
> y, -1.5
> plane {
> y, -3.5
> //pigment{White}
> texture {
> finish {
> ambient 0
> diffuse 0
> reflection .3
> brilliance 0
> specular 1
> roughness 1
> torus {
> 0.8,
> 0.2
> scale y*1
> torus {
> 0.8,
> 0.2
> scale z*2
> rotate x*90
> rotate z*0}
> rotate z*45}
> rotate z*90}
> rotate z*135}
> rotate z*180}
> rotate z*225}
> rotate z*270}
> rotate z*315}
> object {thig2 }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>I killed povray!!!
I don't want to sound rude, but this isn't the group you are looking for.
For newbie questions, please use povray.newusers. If you want to post a
scene, please use povray.binaries.scene-files or povray.text.scene-files.
Please read the FAQ, too.
Anyway, the "problems" with your scene:
-"Complex" objects
-Lots of reflective surfaces
-Radiosity
-Area lights
Any of these makes a scene render slow. If you combine two of these, your
render will be somewhere between very slow and extremely slow. If you
combine more than two, you are probably hopeless.
(This might be a case of RTFM as well, I'm pretty sure that the docs have
some info on how these functions affect render time.)
Gergely
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Flaming Monarch <fla### [at] gates com> wrote in
news:3efe264b$1@news.povray.org:
> I killed povray!!!
> its taking forever.
> it looks or renders would be great.
I let my PC render your image during the night. It is finished now.
(4 hours @ 2 GHz Athlon)
How do you me to send it to you ?
E.g.:
.jpg -> By email
.jpg -> Posted to povray.binaries.images
.png or .bmp -> Uploaded temporarily to my home page server
Tor Olav
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks dude, Email me at
Fla### [at] fentrax com
>>I killed povray!!!
>>its taking forever.
> E.g.:
> .jpg -> By email
> Tor Olav
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Just for curiosity, I rendered it last night @ 1280X1024. I thought that
others might want to see it too. So here's the details followed by the
image...
I rendered it on a P4 2.7GH[512K Cache 533MHZ] @ 1024MB RDRAM
Statistics for test3.pov, Resolution 1280 x 1024
Pixels: 1312689 Samples: 3065041 Smpls/Pxl: 2.33
Rays: 12091612 Saved: 29036 Max Level: 5/5
Ray->Shape Intersection Tests Succeeded Percentage
Plane 59562867 5475468 9.19
Sphere Sweep 129703511 50443719 38.89
Torus 44692530 16088791 36.00
Torus Bound 44692530 18582480 41.58
Bounding Box 525172097 179772564 34.23
Vista Buffer 38184506 30319591 79.40
Roots tested: 4817612387 eliminated: 7407854
Calls to Noise: 0 Calls to DNoise: 10
Shadow Ray Tests: 142451087 Succeeded: 47275155
Reflected Rays: 8855638
Radiosity samples calculated: 5305 (0.08 percent)
Radiosity samples reused: 6822597
Smallest Alloc: 25 bytes Largest: 25644
Peak memory used: 1068595 bytes
Time For Trace: 5 hours 55 minutes 7.0 seconds (21307 seconds)
Total Time: 5 hours 55 minutes 7.0 seconds (21307 seconds)
CPU time used: kernel 0.78 seconds, user 21301.53 seconds, total 21302.31
seconds
Render averaged 61.53 PPS over 1310720 pixels
This file was encoded with the new yEnc encoding scheme, designed to save
bandwidth by dramatically reducing the 30%+ overhead incurred by UU and Base64.
For more info, see http://www.yenc.org/
Download '=ybegin line=128 size=101656 name=test3.jpg.dat' (103 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Martin Belair <bad### [at] hotmail DOT com> wrote in
> save bandwidth by dramatically reducing the 30%+ overhead incurred by
> UU and Base64. For more info, see http://www.yenc.org/
Oh yes.... The attachement is yEnc encoded. If you can't decode it, and have
enough request, I can re-send it the old fashion way....
Ciao!
Mart
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Cool, Ty for the help, but I dont think that the image attached very
well. its all weird like when u open an image in notepad.
> image...
> seconds
> =yend size=101704 crc32=0d72f868
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ah ok then plz old way ty,
> Ciao!
> Mart
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
So what do you think of it artisticaly?
> I killed povray!!!
> taking forever.
> Thanks Tonnes!!!!
> Source
> global_settings {
> assumed_gamma 1.0
> #if (Radiosity)
> radiosity {
> (1..1600) [35]
> [1.8]
> pretrace step
> (0..1) [0]
> [0.015]
> (0..1) [1]
> adc_bailout 0.01/2
> [off]
> [on]
> #end
> #declare area=10;
> cubic_spline
> num_spheres,
> #declare i = 0;
> #declare i = i + 1;
> #end
> //no_shadow
> /*light_source {
> 0*x
> color rgb <1,1,1>
> light_source {
> area_light
> camera {
> look_at <0, 0, 0>
> // gradient y
> // color_map {
> plane {
> y, -1.5
> plane {
> y, -3.5
> //pigment{White}
> texture {
> finish {
> ambient 0
> diffuse 0
> reflection .3
> brilliance 0
> specular 1
> roughness 1
> torus {
> 0.8,
> 0.2
> scale y*1
> torus {
> 0.8,
> 0.2
> scale z*2
> rotate x*90
> rotate z*0}
> rotate z*45}
> rotate z*90}
> rotate z*135}
> rotate z*180}
> rotate z*225}
> rotate z*270}
> rotate z*315}
> object {thig2 }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
