POV-Ray : Newsgroups : povray.binaries.images : orrery Server Time
3 Jun 2026 20:59:02 EDT (-0400)
  orrery (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: orrery
Date: 6 Apr 2003 16:31:18
Message: <3e908e96@news.povray.org>
Tim Nikias v2.0 wrote:
> The planets look very smooth to me. Perhaps a bumpmap
> would improve this. If you'll take a look at my v2.0 Gallery,
> I've used a bumpmap for the moon, which makes it appear
> much more planet-like, to me at least. Since you're trying
> to depict a model, some exhagerated bumps on the planets
> won't harm. For a "real" planet, the bumps wouldn't be that
> visible, I guess.
> Also, the moon, Mars and Saturn look slighty too "soft" to me,
> not a shiny little highlight, but more a spread out, sort of
> silk-highlight.
> Aside of that, very nice!
Thanks!
I'd hoped the sun, at least, would make the case for these
*not* being models, but I suspect that it's reflection in
the table spoils the effect somewhat. I'm not using an area
light but I believe that only affects shadows anyway.
As I'm aiming towards making the planets and sun look
as "real" as possible, to contrast them with the mechanism,
I need to move further in that direction. Maybe dust and/or
scratches on the hardware might help, but it's such a nice
table :-)
I'm much less happy with the room itself, admittedly I've
not spent as much time on it as on the orrery itself.
I would've gotten away with it too, if it wasn't for those pesky kids!
Subject: Re: orrery
Date: 6 Apr 2003 16:45:06
Message: <web.3e90912f526531d1b0d1d5010@news.povray.org>
My first impression was 'waaaw'
it has something wonderfull, it even makes me think of tomb raider in some
way. it actuates the same mood in me.
To be honest, i thought it was a shiny floor with the mechanic in the center
of the room. but when i took a closer look i saw it was a table.
mabye a larger view can fix this.
very nice overal image!! finish it :-)
Subject: Re: orrery
Date: 6 Apr 2003 16:49:41
Message: <3e9092e5@news.povray.org>
Will W wrote:
> I think this is great as is! But since you are asking for comments...
> Have you tried a lighter colored wood in the wainscotting? I'd like to see
> what it would look like with a wood of about the same tone as the picture
> frames (maybe keeping the chair rail the same as it is now).
Actually I'd thought darker, to kind of echo the portrait on the wall,
fading to black in the shadows.
> The wallpaper is too distracting for my taste. Partly I think it isn't
> flat enough: it seems to have depth of its own. Partly I think it's too
> busy and colorful-- it really deserves to be the centerpiece of its own
> picture-- here it seems to be trying to steal the show.
Yes, now you mention it. I'd thought of calling the picture "God's Orrery"
but that might have caused offence, maybe, esp with the connotations of
"Gods Drawing Room", "God's Wallpaper" etc :-)
Anyway that was the idea. I just don't know what to replace it with.
> Can something be done with the edges of the planets with dense
> atmospheres? That could make a nice distinction between the Moon and
> Earth.
Maybe, but in the planetary images I've looked at I don't see that
distinction.
> Is the Moon's appearance accurate for the face that we're seeing? I'm just
> curious about that.
well it's just an orthographic image_map onto a sphere, the main
problem then being keeping the sphere facing the camera. Of course
since the image is taken from Earth the moon is therefore facing the
wrong way, but I haven't found any Mercator projections of the moon
I could use for a uv_mapping.
> Again, I like this very much as is. But you did ask!
Thanks very much! It's only my 3rd real attempt with Pov.
> Will Woodhull
> Thornhenge, SW Oregon, USA
> willl.at.thornhenge.net
Subject: Re: orrery
Date: 6 Apr 2003 17:36:00
Message: <3e909dbf@news.povray.org>
Jouni Pousi wrote:
> What a wonderful image!
thank you :-)
> What was your technique for making the Sun?
Please find attached, then say light_source { ... looks_like Sun }
> I've
> made some experiments with using media for the sun, but I've never
> gotten anything that looks as good as that. On the other hand, the sun
> could be somewhat less bright and it might be good to make the grains
> more visible. Although this is propably a fake-color image, here's a
> good example of how grainy the sun is:
> http://www.phy.duke.edu/courses/313/table-images/soho-image-of-sun.jpg .
Yes, I guess I tried to go halfway between the false-color Soho type
images and the real thing.
> Also it might look good if you included some solar prominences like seen
> in the bottom left of the image (and share the code ;-) .
I'll make a try for some prominences, probably some fractal approach,
I remember seeing some fractal concrete that looked close in shape,
I need to look around a bit.
> I'm not sure if the orrery is supposed to contain all the planets, but
> Mercury is the first planet in the solar system, not Venus. As far as I
> know, Mercury would have been well known when orreries were made. And
> Jupiter is the fifth in the solar system, not Saturn. On the other hand
> the rings of Saturn are absolutely wonderfully implemented, and it would
> be a shame to remove Saturn from the image. Also, the relative sizes of
> the planets seem a bit off - the radius of Mars is just 0.54 times the
> radius of Earth, and Venus about 0.95.
An Orrery would contain all the planets, if you look closely at the
central pillar you'll see spare bands for Mercury, Jupiter, Uranus,
Neptune and even Pluto; I was thinking of running rods in various
directions out of frame (Mercury would be behind the sun) to hint
at their presence, but it might get cluttered, also there's all
the moons of Saturn to consider...
I really just wanted to get a selection of the most interesting
planets in the picture, and Jupiter lost out to Saturn :-)
As for scale, I'd tried lots of approaches: log, sqrt and cube roots
of the actual distances and diameters, none of them worked very well.
In the end I just settled for "X is bigger than Y" and left it at that.
> The color of the athmosphere of Venus doesn't seem quite right, either.
> While Venus does look almost when viewed through a telescope, I'm not so
> sure if the actual color of the athmosphere would be as white when
> viewed from space. Here's an image:
> http://perso.wanadoo.fr/youpie/systsol/venus1.jpg . I couldn't find info
> on whether or not that image has fake colour, so you propably should ask
> someone else about that. :-)
hmm, maybe it is true colour, I'd always thought of it as a blue-ish
white though, and that has a better contrast with the other planets.
> The wooden paneling in the back wall has a very similiar colour to the
> table, and because of that, the table "blends" with the wall. Also, the
> frames of the pictures in the backround seem quite flat. Have you
> considered adding glass panels in front of the pictures? The reflections
> might look quite nice (but admittedly slow down render times). Also, how
> about dimming the general lighting and allowing the Sun to light most of
> the image? That might give the image some more athmosphere.
Yes, thanks for pointing that out, I'm least happy about the room itself.
I'll experiment.
> Hopefully I'm not too "harsh" in my critizism. ;-)
Not at all, thank you for your suggestions.
Download 'us-ascii' (2 KB)
Subject: Re: orrery
Date: 6 Apr 2003 17:39:52
Message: <3e909ea7@news.povray.org>
> center of the room. but when i took a closer look i saw it was a table.
maybe, but every unit I pull back the camera looses some definition
on the planets, there are some very difficult compromises to be made.
Thanks! I'll try.
Subject: Re: orrery
Date: 6 Apr 2003 17:51:06
Message: <3e90a14a@news.povray.org>
oh, and global_settings { max_trace_level 10 }
though 10 may be too high, it was just my first guess.
Subject: Re: orrery
Date: 6 Apr 2003 18:55:09
Message: <3e90b04d$1@news.povray.org>
Look here for some maps which you can
just map onto a sphere using spherical
mapping (map_type 2):
http://www.jht.cjb.net/
That could help for the moon. For the earth,
look here:
http://earthobservatory.nasa.gov/Newsroom/BlueMarble/
Tim
Tim Nikias v2.0
Email: Tim### [at] gmxde
see
> > Earth.
> distinction.
just
> > curious about that.
> > Will Woodhull
Subject: Re: orrery
Date: 6 Apr 2003 21:45:58
Message: <3e90d856@news.povray.org>
"Bill Hails" <bil### [at] europeyahoo-inccom> wrote in message
news:3e9092e5@news.povray.org...
<snip>
<snip>
> ..... I'd thought of calling the picture "God's Orrery"
Ah! That triggered a distant memory from an art course long ago and far
away... and a search on "orrery" and "god" brought me to the original
painting. Nice allusion. Can you find a camera angle that would show all of
Wright's work? I didn't recognize it with its top cropped off.
Will Woodhull
Subject: Re: orrery
Date: 6 Apr 2003 23:19:04
Message: <3E90F165.5090408@alphalink.com.au>
Bill Hails wrote:
> Arthur Flint wrote:
>>I like the concept, but just a question: how do they pass each other?
> Only just :-), see attached figure.
Don't let the kids play with it, you just know they're going to swing
our moon into Mars.
Subject: Re: orrery
Date: 7 Apr 2003 04:17:11
Message: <3e913406@news.povray.org>
That certainly is better for the moon, thanks very much.
By a strange coincidence that's the site where I got the
earth maps from, I just hadn't looked around.
> look here:
Wow, that's some resolution :-)
> Regards,
> Tim
> Tim Nikias v2.0
> Homepage: http://www.digitaltwilight.de/no_lights
