POV-Ray : Newsgroups : povray.binaries.images : Marc Champagne's diamonds again (150 Kb) Server Time
3 Jun 2026 21:19:56 EDT (-0400)
  Marc Champagne's diamonds again (150 Kb) (Message 11 to 15 of 15)
Subject: Re: Marc Champagne's diamonds again (150 Kb)
Date: 31 Mar 2003 12:19:33
Message: <3e8878a5@news.povray.org>
Very cool, you need to lower the specular value a little (to 0.4?), there
are too many washed out whites... You can also try decreasing the roughness
by an order of magnitude.
Date: 31 Mar 2003 23:34:22
Message: <Xns934FEF79DC8D8POVMIKA@204.213.191.226>
"Freddy D." <Fde### [at] SPAMSUCKSwanadoofr> wrote in
news:3e86e630$1@news.povray.org:
> With a little bit of imagination, i can read 'P O V' in this pic...
> .. or is it I need coffee ?...
> Nice ones... wish i had that in my hands...
> FD
You know that the placement of the diamonds had nothing to do with
'P O V', maybe my mind has been conditioned to do so without my
consent....
(MIKA) Marc Champagne
marcch.AT.videotron.DOT.ca
Montreal, CANADA
Date: 6 Apr 2003 07:52:54
Message: <3e901516@news.povray.org>
Could you tell us the source?
thx
news:3e864f0d@news.povray.org...
> Pixels:          480800   Samples:         2783912   Smpls/Pxl: 5.79
> Rays:         358123620   Saved:          27967161   Max Level: 100/100
> Ray->Shape Intersection          Tests       Succeeded  Percentage
> Box                         2106014929      1509283441     71.67
> CSG Intersection            1459857629       815358445     55.85
> Plane                     131387186610     70139956210     53.38
> Bounding Object             1470411157      1459857629     99.28
> Bounding Box                4941704909      2308259605     46.71
> Light Buffer                4312153575      2730173605     63.31
> Vista Buffer                  10129503         7138130     70.47
> Calls to Noise:          229477140   Calls to DNoise:             10
> Shadow Ray Tests:       1745650454   Succeeded:            568607435
> Reflected Rays:          288949856   Total Internal:       193644483
> Refracted Rays:           66384846
> Transmitted Rays:               14
> Number of photons shot:           4992
> Surface photons stored:         128759
> Priority queue insert:     51590024944
> Priority queue remove:     23904966790
> Gather function called:      288832354
> Smallest Alloc:                 10 bytes   Largest:           327688
> Peak memory used:          3481630 bytes
> Time For Photon:   0 hours  0 minutes  16.0 seconds (16 seconds)
> Time For Trace:   68 hours 50 minutes  36.0 seconds (247836 seconds)
>      Total Time:   68 hours 50 minutes  52.0 seconds (247852 seconds)
> This is what I
> changed:
> #declare   PhotonCount = 29000;
> added :
>    light_source { < -7 , 10 , 20 > , rgb < 1,0,0> }
>    light_source { <  2 , 10 , 10 > , rgb < 0,1,0> }
>    light_source { < 14 , 10 ,  0 > , rgb < 0,0,1> }
> changed:
>    box          { <-15,-1,-15>, <15,0,15>
>                  texture { Glass3 }
>                  texture { Brass_Valley }
> //                 pigment { rgb <.3,.4,.5> }
> //                 finish  { ambient .3 diffuse .4 }
>                   #if ( Photons ) photons { target 1 refraction off
> reflection off } #end
> Cheers
> Ger
Date: 6 Apr 2003 08:04:22
Message: <3e9017c6@news.povray.org>
> thx
Source is in p.t.s-f "Mika Diamond"
Ger
Date: 21 Dec 2003 15:10:01
Message: <web.3fe5fdf4fe081d8e930cb8dc0@news.povray.org>
Hey ger,
Ultimate beauties !!!
Jus wish i cud also do that sometime in near future .
Great work !!
