POV-Ray : Newsgroups : povray.binaries.images : HDRI, why? Server Time
4 Jun 2026 08:32:59 EDT (-0400)
  HDRI, why? (Message 11 to 12 of 12)
Subject: Re: HDRI, why?
Date: 4 Jan 2003 05:59:01
Message: <20030104115900.32235936.jaimevives@ignorancia.org>
On Sat, 04 Jan 2003 08:55:34 +1100
Daniel Matthews <dan#@3-e.net> wrote:
> That is very nice work, but where are the photons?
> Could you work a crystal ball into your test scene and show refraction
> and reflection working with the fake HDRI environment?
  I've not tried it yet, but I think it should work as with any other
scene with ambient light only. That is, only for very HQ rad settings.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 5 Jan 2003 20:33:47
Message: <cjameshuff-DA9B20.20234505012003@netplex.aussie.org>
In article <3e1560f2@news.povray.org>, "Hugo Asm" <hua### [at] post3teledk>
wrote:
> But with reflections, the docs says "POV-Ray uses a limited light model that
> cannot distinguish between objects which are simply brightly colored and
> objects which are extremely bright" therefore we have the
> reflection_exponent keyword... So that shouldn't work in favor of HDR, but
> I'm not fully certain about it.
The documentation is a bit inaccurate there (just wrong actually, colors
are only clipped at the last stage, after being calculated), reflection
handles values > 1 just fine, and nothing stops you from specifying
realistic values. The problem is that values elsewhere are usually
specified in the range [0, 1]. The reflection_exponent feature is a
simple hack that modifies the calculations unrealistically to compensate
for inaccurate settings.
There is nothing HDRI does that existing features couldn't do with
greater physical accuracy, it just does it with less render time and
scene/lighting setup. Instead of building and rendering a detailed and
painstakingly adjusted scene, you use an existing high dynamic range
image which has samples of the data you would have to compute, and
interpolate that data.
http://tag.povray.org/
