POV-Ray : Newsgroups : povray.binaries.images : illusion checkers [~40KB Jpg] Server Time
4 Jun 2026 21:01:33 EDT (-0400)
  illusion checkers [~40KB Jpg] (Message 11 to 16 of 16)
Subject: Re: illusion checkers [~40KB Jpg]
Date: 29 Sep 2002 20:20:53
Message: <3d9798e5$1@news.povray.org>
hughes, b. wrote:
> http://persci.mit.edu/gallery.html
The one here is easier to tell that they're the same, just kinda look
at it with your eyes a bit out of focus and not looking AT the squares.
Tim Cook
Version: 3.12
Date: 29 Sep 2002 22:19:19
Message: <3d97b4a7@news.povray.org>
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3d9798e5$1@news.povray.org...
I can't see them as the same until I block nearly all else except a shadowed
one and one in direct light, some of the surrounding checkers can still be
seen partially though. I tried as you suggested, covered one eye and focused
on my other hand nearer to me and off to the side enough to see the image.
Still the illusion. Tried that with the three different ones. Probably a lot
to do with how perception works for different individuals I'd guess.
Date: 29 Sep 2002 22:36:32
Message: <3D97B8B6.AD713092@onwijs.com>
Colour is relative ;)
Remco
Date: 30 Sep 2002 01:15:23
Message: <3d97ddeb$1@news.povray.org>
Probably has something to do with the fact that my vision sucks, and I
can do some pretty weird stuff with my eyes.
Tim Cook
Version: 3.12
Date: 30 Sep 2002 16:17:24
Message: <3d98b154@news.povray.org>
Could you please post the source.  I would like to make a 1024x768 version of it.
Thanks,
Bret
> Someone posted this illusion at a camera board and so I just had to try
> it using POV-Ray. I don't know what the other was made with, the person
> didn't say where they got it from.
> I found that I couldn't get perfect uniformity when using radiosity but
> without it the render didn't look good. It's close enough to get the
> effect. To check against your sense of vision you'll need to either cut
> and paste parts together or use a color picking eyedropper thing which
> many paint programs have and compare values.
> Hope it looks as good to you as I thought it was. Couple hours to make,
> 30 minutes for final render.
Composed with Newz Crawler 1.3 http://www.newzcrawler.com/
Date: 1 Oct 2002 00:39:12
Message: <3d9926f0@news.povray.org>
"Bret" <bre### [at] macolinocom> wrote in message news:3d98b154@news.povray.org...
of it.
Is done, can be found at povray.binaries.scene-files. I almost forgot to get
the originators name added to the scene file so I had to cancel the first
posting, hopefully only the final one is seen there.
I should say that the rendering took 30 minutes (guess I did before) on my
800MHz notebook, at 512X384 using AA of 0.2 depth 2 and method 2. A four
fold increase shouldn't take too long if your computer is up to it. Rather
plain, ordinary image file for a day long render though.  :-)
