![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
light_source{<0,100,-50> color rgb 10}
background{blue 1}
#declare r0=2;
#declare r1=1;
#declare AMBIENT_VARIABLE=0;
#while(AMBIENT_VARIABLE<1.1)
parametric {
function { cos(u)*(r0+r1*cos(v)) }
function { sin(u)*(r0+r1*cos(v)) }
function { r1*sin(v) }
<0,0>, <2*pi,pi>
contained_by { sphere{0, 4.1} }
max_gradient .14
accuracy 0.001 // 0.0001
precompute 10 x,y,z
texture{pigment {rgb 1}
finish{ambient AMBIENT_VARIABLE}
translate 12*z+x*(-4+8*AMBIENT_VARIABLE)
#declare AMBIENT_VARIABLE=AMBIENT_VARIABLE+1;
Download 'torri.JPG' (5 KB)
Preview of image 'torri.JPG'
![torri.JPG](/povray.binaries.images/attachment/%3C3d7e34e8%241%40news.povray.org%3E/torri.JPG?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The only strangeness I see is that the black torus shouldn't be completely
black, since there's a light source, and its diffuse isn't set to zero.
Otherwise, everything looks correct.
But I don't know what direction we're looking at it from, since you haven't
included the whole scene.
In the future, you should mention what the problem *is*... or did you do
that in a different group somewhere?
- Slime
[ http://www.slimeland.com/ ]
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I thought it was a texture problem, where diffuse==0.
The whole scene file is included.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Two torii: parametric texture problem?
Date: 10 Sep 2002 17:04:49
Message: <3d7e5e71@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Greg M. Johnson" <gregj:-)565### [at] aol com> wrote in message
news:3d7e41ba$1@news.povray.org...
Camera is default, unused in script. Yes, that would seem to be so, the
diffuse isn't right or even the black torus would be white with a light
source color of 10.
Ah, now that I've rendered it I see it works okay here. I get a lit and
shadowed object on left side. I don't know what is wrong with that then.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> okay here. I get a lit and shadowed object
> with that then.
With two different PC's I get the left torus to be black. Could you post
what you see?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Here it is, small but obvious enough. Only thing I had changed from the
first time I tried rendering is the light source color is only 1 instead of
10.
Farewell,
Download '00.jpg' (4 KB)
Preview of image '00.jpg'
![00.jpg](/povray.binaries.images/attachment/%3C3d7eb801%40news.povray.org%3E/00.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Tue, 10 Sep 2002 14:06:38 -0400, "Greg M. Johnson" <gregj:-)565### [at] aol com>
There can be some bug in parametric code. Try change container to:
contained_by { box{-4.1 4.1} }
in your scene. The image looks different. Left object is now partially white.
I have partially pointed what can cause bugs in parametric object in
http://news.povray.org/saqrmuoi41v5iqkclmmggtk06n8t32s789%404ax.com
Read also thread http://news.povray.org/povray.general/26669/ .
BTW: Looking at your script I have a note. Do you one you waste memory a lot ?
IIRC parametric object is internally optimized to share precomputed data
between instances. So you can save memory changing your object definition this
way:
#declare Parametric_Example=parametric {
<0,0>, <2*pi,pi>
max_gradient .14
precompute 10 x,y,z
object {
Parametric_Example
texture{
pigment {rgb 1}
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
