POV-Ray : Newsgroups : povray.binaries.images : My dorm room... Server Time
5 Jun 2026 16:47:44 EDT (-0400)
  My dorm room... (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: My dorm room...
Date: 3 Jun 2002 00:20:31
Message: <3cfaee8f$1@news.povray.org>
>     count 1600
Don't you just hate that upper limit? =)
 - Slime
[ http://www.slimeland.com/ ]
Date: 3 Jun 2002 00:30:49
Message: <3cfaf0f9$1@news.povray.org>
How hard would it be change it?  As easy as changing "1600" to "1000000" in
the source and then recompiling?
Date: 3 Jun 2002 03:00:24
Message: <3cfb1408@news.povray.org>
in
Perhaps, but I bet the limit is there because that's the size of an internal
array, and if you just blindly changed it, it'd eat up a ton of memory.
That's my guess at least.
 - Slime
Date: 3 Jun 2002 04:23:00
Message: <3cfb2764@news.povray.org>
Skip Talbot <sta### [at] uiucedu> wrote:
> ...but it's never this clean.  I just made a quick model for the
> purposes of planning out some decorations for next year and did some
> radiosity experiments with it.  If it looks a bit distorted it's
> because of the camera angle (120 degrees) wanted to get the bunk,
> desk, and window in the same shot.
remove the back walls and put the camera far away :)
PGP Public Key
Date: 3 Jun 2002 05:36:22
Message: <3cfb3896@news.povray.org>
"Skip Talbot" <sta### [at] uiucedu> wrote in message
news:3cfac9be@news.povray.org...
> Well, I took a tape measure to every major detail around the room so the
> actual model is very precise.  The wood textures are straight out of
> woods.inc but they are fairly close.
> POV's radiosity lighting is fantastic BTW.  My roommate used to stay up
> doing homework and I let him keep the overhead light on.  I was able to
> sleep in the bottom bunk because the overhead's only illuminated half of
the
> bottom bunk... just like in the rendering.  The shadows produced by the
> window light are very close to real life as well.  There are no
conventional
> light sources in this scene.
Are the wooden parts of the bed really like that? I'd expect the "lines"
ending up being parallel with the long side, at least that's the usual way
they cut the trees.
Otherwise nice image, but there's always something that says it's not real.
Don't know what though.
Date: 3 Jun 2002 14:33:00
Message: <3cfbb65c@news.povray.org>
> Won't work well with radiosity.  But maybe no_image will do the trick.
Don't remove the back walls; instead, set the texture of the walls (which i
assume are nothing more than a hollow box) to be transparent, and then set
the *inner* texture of them to be solid, and you can see right through them
from the outside. Theoretically, at least.
 - Slime
Date: 3 Jun 2002 16:16:54
Message: <3cfbceb6$1@news.povray.org>
No, the wood grain on the bed is not really like that.  I just slapped a
woods.inc texture on it without scaling or rotating it.  In real life the
grain is much more subtle, it just has the same basic color.  Many smaller
details are left out too, which probably explains the lack of realism you
sense.
Skip
Date: 4 Jun 2002 14:17:23
Message: <3cfd0433@news.povray.org>
Doesn't seem to work that way...
At least, not when I tried:
difference {
    box { <-5,-5,-5>,<5,5,5> pigment { Clear } }
    box { <-2,-2,-2>,<2,2,2> pigment { Orange transmit .5 } }
sphere { <0,0,0>,.5 pigment { Red } }
Of course, I may have no clue what I'm doing...
"Slime" <slm### [at] slimelandcom> wrote in message
news:3cfbb65c@news.povray.org...
i
them
>  - Slime
Date: 4 Jun 2002 14:48:32
Message: <nSDiJdA1sQ$8Ew1f@econym.demon.co.uk>
>difference {
The syntax is
   texture {pigment {Clear}}
   interior_texture {pigment {Orange}}
Interior_texture is not supported in POV 3.1. You need POV 3.5 or
MegaPOV.
Mike Williams
Gentleman of Leisure
Date: 5 Jun 2002 00:10:06
Message: <3cfd8f1e@news.povray.org>
> >difference {
Mike's way illustrates what I meant. However, you'll probably want to make
the box "hollow" to keep from getting a "camera is inside a non-hollow
object" warning.
 - Slime
