POV-Ray : Newsgroups : povray.binaries.images : need an opinion Server Time
5 Jun 2026 16:44:29 EDT (-0400)
  need an opinion (Message 11 to 13 of 13)
Subject: Re: need an opinion
Date: 25 May 2002 16:05:19
Message: <3cefee7f$1@news.povray.org>
>I would consider adding a safety railing around the hole in the center
>of the deck. I probably wouldn't use square posts to support this
>railing. I would probably construct the whole assembly from high
>quality POV-Ray pipe, and fasten it to the deck with pipe flanges.
There is actually going to be a Octangonal picnic bench in the middle, so
the safety railing is kind of impractical. I like the pipe idea, but doing
the whole support structure in pipe would I think, ruin the kind of setting
I'm aiming for, but I do like the idea of using pipes to support the
midpoint of the longer pipe. As for the pipe flanges, I just havn't got
around to it yet, but it's one of the finer details I plan on adding later.
As for the supports under the deck, your right, they do seem a bt small to
support the weight, I'll have to fiz that.
thanks
Kevin
#macro _(r)#if(r<12)#local i=asc(substr("oqshilacefg",r,1))-97;
disc{<mod(i,7)-3,div(i,7)-1,6>,z,.4pigment{rgb 10}}_(r+1)
#end#end _(1)//KL
Date: 25 May 2002 18:48:05
Message: <6RPwPDth3tZP8NIr8O4Iy66RZ=vb@4ax.com>
On Sat, 25 May 2002 07:51:33 -0400, "Bill DeWitt"
<bde### [at] cflrrcom> wrote:
>    The guard rail is perfect tripping height and the corner posts are
>thinker than you can really get square posts anymore, but otherwise it
>doesn't seem disproportional.
I think you are assuming the corner supports are made from wood, in
which case your statement would make perfect sense, and I would be in
total agreement with it. However, what if those white columns are
actually meant to be reinforced concrete? He can have a "post" as
large and sturdy as he wants, in that case.
Later,
Glen
7no### [at] ezwvcom     (Remove the numeral "7")
Date: 25 May 2002 19:39:10
Message: <3cf0209e$1@news.povray.org>
Bill is right, there going to be wood, however considering those posts are
going to be POV brand wood, I can get them in any shape and size. Not only
that but POV brand wood dosen't fade in the sun.
Kevin
#end#end _(1)//KL
