POV-Ray : Newsgroups : povray.binaries.images : On Europa - on_europa.jpg (0/1) Server Time
6 Jun 2026 00:27:51 EDT (-0400)
  On Europa - on_europa.jpg (0/1) (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: On Europa - on_europa.jpg (1/1)
Date: 17 Apr 2002 22:42:05
Message: <3CBE32ED.E154EA6E@scifi-fantasy.com>
(From the 'everything I need to know about astronomy, I learned
from popular media' section...)
"Regardless of viewing location, the great red spot is ALWAYS
visible when looking at Jupiter."
Tim Cook
Version: 3.12
Date: 18 Apr 2002 02:08:57
Message: <3cbe62f9$1@news.povray.org>
news: 3CBE32ED.E154EA6E@scifi-fantasy.com...
LOL, how do you explain that strange behaviour?
When it's facing oposite side it's invisible indeed.
Jupiter's mass isn't huge enough to wrap space frame that way.
Marc
Subject: Re: On Europa - on_europa.jpg (0/1)
Date: 18 Apr 2002 05:31:07
Message: <3cbe925b$1@news.povray.org>
> Thank you "SY" at news.povray.org for the following post...
> "// Mean distance of the sun from Jupiter: 800E+6 km = 8000000E+2
> units
> // Sun's diameter is approx 1.4E6km = 1.4E4 = 14000 units
> // use an area light to simulate the sun
> light_source { <0,0,-8000000> color rgb <1,1,0.85>
>                area_light x*14000, y*14000,3,3 adaptive 1 jitter
>                rotate y*-30 }
> file://light_source { <5000000,0,-8000000> color rgb <1,1,0.85>  }
You are welcome.
If you need some more data, please let me know...
regards
SY
Date: 18 Apr 2002 05:36:54
Message: <3cbe93b6@news.povray.org>
Very nice scene.
One remark: (beside the HF artefacts) the lighting is IMO inconsistent.
Jupiter is lit from sun "behind" the camera. But looking on the small knob
of europa's surface to the lower left it seems to be lit from Jupiter which
is in FRONT of the cam. Although Jupiter IS bright, the major lighting
should come from the sun.
Jupiter is a picture. What about placing the texture-only jupiter of the the
"jupiter" post in p.b.s-f ? Then you could animate each colour band on it's
own...
good job
regards
SY
Date: 18 Apr 2002 05:37:38
Message: <3cbe93e2$1@news.povray.org>
> Marc
due to Jupiter's rotation it is only a matter of time *gg*
regards
SY
Date: 18 Apr 2002 09:21:45
Message: <3cbec869$1@news.povray.org>
I haven't tried them myself, but I think that the heightfield macros in 3.5
will return a better result than the height_field command. I'm not sure
where they are located, but you could use the search function to find them
in the docs.
 -Shay
Blane Bizzaro <bla### [at] bizzarocreationscom> wrote in message
news:3cbd57ab.334778495@news.povray.org...
Subject: Re: On Europa - on_europa.jpg (1/1) - on_europa2.jpg (0/1)
Date: 18 Apr 2002 20:03:08
Message: <3cbeb636.86309413@news.povray.org>
The higher res tip was a good one Shay. The first height field image
was only 600x600px by 8 bit. This new one is 2000x2000 by 24 bit.
Thanks!
--Blane
On Wed, 17 Apr 2002 16:28:19 -0500, "Shay" <sah### [at] simcopartscom> wrote:
>Nice pic, but the jagged look on the near vertical edges of your
>height-field really distract. Consider using a higher resolution
>height-field or using the new height-field macros to improve this.
> -Shay
>news:3cb### [at] mailpovrayorg...
Date: 19 Apr 2002 02:02:40
Message: <3cbf0ac7.107962223@news.povray.org>
> -Shay
Date: 19 Apr 2002 13:57:05
Message: <3cc05a71@news.povray.org>
The higher res idea worked out pretty good. Thanks for the tip!
--Blane
Shay <sah### [at] simcopartscom> wrote in message
news:3cbec869$1@news.povray.org...
3.5
> in the docs.
>  -Shay
Download 'on_europa2.JPG' (102 KB)
Preview of image 'on_europa2.JPG'
Date: 19 Apr 2002 16:11:47
Message: <Xns91F5A4C257C11csbhccse@204.213.191.226>
"Blane Bizzaro" <bla### [at] bizzarocreationscom> wrote in
news:3cc05a71@news.povray.org:
I think the lighting is still a little wacky.  You might want to try going
down to one light to the extreme left or right of the scene components
(well off the screen) and using radiosity to backfill the shadows.
The contrast with the starfield is also way too low; the stars and plane of
the galaxy should be much dimmer.
I would be interested in seeing the source, BTW.
