POV-Ray : Newsgroups : povray.binaries.images : On Europa - on_europa.jpg (0/1) Server Time
6 Jun 2026 00:27:50 EDT (-0400)
  On Europa - on_europa.jpg (0/1) (Message 11 to 14 of 14)
Subject: Re: On Europa - on_europa.jpg (1/1) - on_europa2.jpg (0/1)
Date: 18 Apr 2002 20:03:08
Message: <3cbeb636.86309413@news.povray.org>
The higher res tip was a good one Shay. The first height field image
was only 600x600px by 8 bit. This new one is 2000x2000 by 24 bit.
Thanks!
--Blane
On Wed, 17 Apr 2002 16:28:19 -0500, "Shay" <sah### [at] simcopartscom> wrote:
>Nice pic, but the jagged look on the near vertical edges of your
>height-field really distract. Consider using a higher resolution
>height-field or using the new height-field macros to improve this.
> -Shay
>Blane Bizzaro <bla### [at] bizzarocreationscom> wrote in message
>news:3cb### [at] mailpovrayorg...
Date: 19 Apr 2002 02:02:40
Message: <3cbf0ac7.107962223@news.povray.org>
> -Shay
Date: 19 Apr 2002 13:57:05
Message: <3cc05a71@news.povray.org>
The higher res idea worked out pretty good. Thanks for the tip!
--Blane
Shay <sah### [at] simcopartscom> wrote in message
news:3cbec869$1@news.povray.org...
> I haven't tried them myself, but I think that the heightfield macros in
3.5
> will return a better result than the height_field command. I'm not sure
> where they are located, but you could use the search function to find them
> in the docs.
>  -Shay
> news:3cbd57ab.334778495@news.povray.org...
Download 'on_europa2.JPG' (102 KB)
Preview of image 'on_europa2.JPG'
Date: 19 Apr 2002 16:11:47
Message: <Xns91F5A4C257C11csbhccse@204.213.191.226>
"Blane Bizzaro" <bla### [at] bizzarocreationscom> wrote in
news:3cc05a71@news.povray.org:
I think the lighting is still a little wacky.  You might want to try going
down to one light to the extreme left or right of the scene components
(well off the screen) and using radiosity to backfill the shadows.
The contrast with the starfield is also way too low; the stars and plane of
the galaxy should be much dimmer.
I would be interested in seeing the source, BTW.
