POV-Ray : Newsgroups : povray.binaries.images : Not a Rolex [WIP] Server Time
13 Aug 2026 05:50:10 EDT (-0400)
  Not a Rolex [WIP] (Message 13 to 22 of 22)
Subject: Re: Not a Rolex [WIP]
Date: 7 Apr 2002 23:27:50
Message: <3cb10e36@news.povray.org>
> Thats similar to what I want but I'm having good luck so far with my HF. I
> have a lot more control over it than I would with the isosurface (in the
> sense that I know my way around photoshop but isosurface math is a bit
over
> my head :)
It's actually borrowed from functions.inc (f_crackle) with a little
inversing ;-).  The shape of the container defines the shape ;-) I could
probably re-write it to allow you to change the crackle pattern like a
pigment/normal/density/....  I'm happy to post source.
__________________
 RAY
Date: 7 Apr 2002 23:33:28
Message: <3cb10f88@news.povray.org>
Ok, here is my try at HF broken glass:
Corey
Download 'brass.png' (109 KB)
Preview of image 'brass.png'
Date: 8 Apr 2002 00:26:58
Message: <3cb11c12@news.povray.org>
"Patrick Dugan" <pat### [at] netinsnet> wrote in message
news:3cb1080d@news.povray.org...
> I've made quite a number of watches myself.  Take a look at this address:
WOW! Thats a LOT of watches!
> http://showcase.netins.net/web/patrickd/imagesby.html
> I haven't made any with broken glass to speak of.  One pocket watch was
made
> with a single crack in it though.
> Hands are usually pretty easy to me.  I usually construct them out of
> primitives (cylinders, triangles, etc.)
so for example was
http://showcase.netins.net/web/patrickd/povray/elginpocket.jpg made witha
cylinder, 2 spheres, and a cone then flattened by scaling the y axis very
small? I might try something like that, thanks for the examples and the idea
Corey
Date: 8 Apr 2002 00:27:23
Message: <3cb11c2b@news.povray.org>
"Corey Woodworth" <cdw### [at] mpinetnet> wrote in message
news:3cb0bd95@news.povray.org...
>I'd like to
> make the whole thing look older though. Some corrosion and maybe even
broken
> glass
      Nice! For an old effect on the dial, you might want to add one or
two very thin light blue lines. Quite often an old watch of this style
will have a cracked and/or chipped ceramic dial usually radiating from
the centre.
Here's a good example:
http://www.watchmanmike.fsnet.co.uk/images/DSC0032.jpg
   ~Steve~
> Corey
Date: 8 Apr 2002 00:36:09
Message: <3cb11e39@news.povray.org>
"25ct" <25c### [at] lineonenet> wrote in message news:3cb11c2b@news.povray.org...
> >I'd like to
> broken
> > glass
> the centre.
Cool I'll give it a shot. So the dials are ceramic! That'll help me when
I get around to texturing that. :)
Hmm, maybe its my eyes, but I can't find the blue lines.
Corey
>    ~Steve~
Date: 8 Apr 2002 00:54:00
Message: <3cb12268@news.povray.org>
news:3cb11e39@news.povray.org...
when
     Note that not all pocket watches have ceramic dials. Some have nice
engine-turned gold or brass dials.
      There's only one crack on this dial. It's from the centre to just
before the II (2). The line looks black/dark in this image, but in real
life I've only ever seen blue.
   ~Steve~
> Corey
> >    ~Steve~
Date: 8 Apr 2002 00:54:02
Message: <3cb1226a@news.povray.org>
address:
     Blimey Patrick, where have you been hiding?
     You've got some mean looking watches on your 'site. Bookmarked for
inspiration.
     ~Steve~
Date: 8 Apr 2002 05:41:57
Message: <3CB165E1.40009@my.email.address>
Also note how the 4 is written. This is used on most clock faces, that
use Roman numerals, instead of the normal IV.
As for the hands: just use CSG. That's what I would do - actually have
done: http://home4.inet.tele.dk/ibras/ur.htm
/Ib
Date: 8 Apr 2002 11:28:40
Message: <3cb1b728$1@news.povray.org>
news:3cb0dfcd$1@news.povray.org...
> > Would a visual tool that created 2D splines for use in lathes, sors,
> prisms
> > be helpful? I am in the progress of playing around with such a tool,
> written
> > in VB, but am not sure if there would be much interest besides my own
> sense
> > of accomplishment.
> That'd be awesome. I'm use to dealing with bezier curves in PS. If it
could
> speed up the process of making them!
Why don't you try spatch or hamapatch (
http://www.geocities.com/hamapatch )?. They export bicubic patches directly
to povray.
Also you can try transational sweep in Moray, that's the way I managed to
make the clock I have in my site (in the objects section).
Bye
Txemi Jendrix
tji### [at] euskalnetnet
http://www.geocities.com/txemijendrix
Date: 8 Apr 2002 12:43:42
Message: <3cb1c8be@news.povray.org>
For the hands. I would suggest plotting several splines to form an
interesting hand shape and then using sphere_sweep to draw the hand.
sphere_sweep is best suited to this purpose, but you can use cylinders or my
cheap_sweep when possible to speed up render time. Anyway, after you have a
nice curvy hand shape, flatten it and you've got your hand.
For the broken glass. I would use trace against a semi-circle to make
several mesh pieces that will fit together like a puzzle to form your
crystal. You can then manipulate the pieces however you wish.
 -Shay
Corey Woodworth <cdw### [at] mpinetnet> wrote in message
