Thanks, I'll get this one into here (shows for Outlook too as I recall). I
did one of these myself a while back, except not of POV-Ray.
There's also a large size for those or something. I had done it before
installing Windows XP so I'll have to just try this out again to see if it
still works. I forget what the other stuff about it was for that larger
size or whatever that was all about.
bob h
> the picture somewhere on your HD, then go to Start>Run> and type "regedit"
> (w/o quotes). Double-click on "HKEY_CURRENT_USER", then "Microsoft",
Yes, this is fun. I replaced the IE logo some years ago by a PoV-rendered
rotating earth :-)
regards
SY
> I already installed it :) I think that the animation was not looped very
> smoothly, but it's a nice tweak :)
Hi Fernando, what about a cylic cloth movie to replace the IE logo? :)
regards
SY
"Jürgen Scharfy" <sch### [at] surfeu at> wrote in message
news:3c96f072@news.povray.org...
> rotating earth :-)
> regards
> SY
I use a spinning diamond on a black background. No photons yet :-)
Ey cool!
Will you add photons? And post it in here?
Which model did you use? Self-made or some existing?
regards
SY
Thanks for the instructions, I am going to make something cool for myself
soon.
-Shay
Mahalis <don### [at] fakey com> wrote in message
news:3c9699ef$1@news.povray.org...
Subject: Re: Internet Explorer iconny-thingie!
Date: 19 Mar 2002 11:54:51
Message: <3c976d5b@news.povray.org>
Or a rotoscopic fern? :)
Tschuss!
Fernando.
I used the model in "brilliant.inc" by Jerome Grimbert (posted here about a
year ago).
Rock22.bmp and Rock38.bmp are static images (yes, just plain black
rectangles).
Spin22.bmp and Spin38.bmp are the small and large "busy" animations.
Given the size of the images I don't see photons happening anytime soon, but
if somebody else posts a new and improved version I will be happy to give it
a try :-)
Enjoy.
news:3c975081$1@news.povray.org...
> Ey cool!
> regards
> SY
Download 'rock22.bmp.dat' (2 KB)
Download 'rock38.bmp.dat' (5 KB)
Download 'spin22.bmp.dat' (94 KB)
Download 'spin38.bmp.dat' (276 KB)
Very cool. How do you put in the large ones?
-Shay
Spock <spo### [at] nospam com> wrote in message news:3c97737b@news.povray.org...
*lol*
I guess then I'd start dreaming from it at some point!
But the diamond was really a good idea. Especially since I posted one
lately, too.
> Tschuss!
Tschuess und vielen Dank!
regards
SY
Thanks a lot!
But: Phew! The thing almost blew up my dial-in line :-)
I think ZIPping wouldn't be a bad idea?
but
it
> a try :-)
> Enjoy.
Thanks.
I'll try mine over night. :-)
regards
SY
Date: 19 Mar 2002 15:22:09
Message: <3c979df1$1@news.povray.org>
Reminds me of a question- I located the windows shutdown screen and
"safe to turn off" screen in Win'98, but can't find the startup splash logo
file... anybody know where it's squirreled away?
Cheers!
Chip Shults
logo
In Win95 it was in logo.sys in the root of the boot drive. (e.g.
C:\logo.sys)
Might have changed in 98.
regards
SY
Date: 19 Mar 2002 15:47:15
Message: <3c97a3d3@news.povray.org>
Yeah, they moved it to something else. No luck finding it yet.
Cheers!
Chip Shults
Strange. I am pretty sure that the filename is still logo.sys Most likely a
hidden file. Try dir /ah in the dos box in the root of your boot drive.
Additionally I remember something that Win98 is able to use some "backup" if
it fails to find logo.sys in the root. Have you tried to place your BMP
there, named logo.sys?
regards
SY
Date: 19 Mar 2002 16:08:26
Message: <3c97a8ca$1@news.povray.org>
I did a search through all files, hidden and otherwise with no luck.
Nothing for logo.sys anywhere. I will try putting it in the C://Windows
directory and see if it does any good.
Cheers!
Chip Shults
Date: 19 Mar 2002 16:18:56
Message: <3c97ab40$1@news.povray.org>
Just for those who haven't taken this walk, two of the three "splash" or
logo files are in C://Windows and named "logow.sys" and "logos.sys". The
logow file is the "Windows is now shutting down..." file, and the logos file
is the "it is now safe to turn off your computer" file. That one is almost
never seen if your computer shuts itself down, so there is little joy in
changing it.
The format is simple- although they are "sys" files in extension, they
are in fact BMP images. The format is simple- width 320, height 400, stored
as 8 bit optimized color. The files will be 127K in size on the windows
directory listing, the actual sizes are 129,080 bytes each.
Create your artwork in POVray or whatever in a 640x400 format (which I
added to my quick render settings) and once done, resample it to 320x400.
That's pretty easy to do in most art programs, or you can actually set
POVray to do it, I am sure.
Once done, save in that 8 bit BMP format and copy to the proper
directory. Using the DOS prompt, rename the original "logow.sys" file to
something like "logow.bak" and leave it alone. Then rename your bitmap
image to "logow.sys" also in DOS to get the file extensions right.
Then, when you shut down your machine, you will see your little artwork
instead of the typical stuff.
Cheers!
Chip Shults
Make the key "BrandBitmap" instead of "BrandBitmap".
"Shay" <sah### [at] simcoparts com> wrote in message
news:3c977556@news.povray.org...
> -Shay
Save your bmp as a 256-color image in C:\logo.sys. If it doesn't exist (as
you seem to be saying), save it as logo.sys anyway. Win98 has it hidden in
some DLL, but it's really much easier to have it take whatever's in logo.sys
than change what it has.
"Sir Charles W. Shults III" <aic### [at] cfl rr com> wrote in message
news:3c97a8ca$1@news.povray.org...
> Cheers!
> Chip Shults
> My robotics, space and CGI web page - http://home.cfl.rr.com/aichip
Date: 19 Mar 2002 20:40:18
Message: <3c97e882$1@news.povray.org>
That doesn't work. I tried that on a whim, but nothing happened.
Cheers!
Chip Shults
On Tue, 19 Mar 2002 20:40:17 -0500, "Sir Charles W. Shults III"
It worked on my Win98 (first release) when I messed with it at the time...
(and later removed the splashscreen altogether simply by putting a 0-byte
file called logo.sys in C:\ )
just make sure that you save the logo.sys to the root of your C:\ , and
not in the windows folder like the other splash screens...
Marc van den Dikkenberg
The PowerBasic Archives -- http://www.xlsior.org
Date: 20 Mar 2002 02:30:35
Message: <3c983a9b@news.povray.org>
How did you "concatenated" the bitmaps? I suppose there must be an easy way
to do this...
Thanks,
Fernando.
You also can turn off the spash screen by editing msdos.sys, setting logo=0
regards
SY
Date: 20 Mar 2002 09:49:19
Message: <3c98a16f$1@news.povray.org>
My mistake- root directory! I put it there and it works. Thanks for
the help and patience, everyone.
Cheers!
Chip Shults
Mind numbing hours of cut and paste in paint shop pro?
"Fernando Gonzalez del Cueto" <fgd### [at] hotmail com> wrote in message
news:3c983a9b@news.povray.org...
way
> to do this...
> Thanks,
> Fernando.
I use ImageJoiner.
For this one, I just used good old Paint (Alt>E>F, double-click image, move,
Alt>E>F, double-click image, move...) but soon afterwards I wrote a little
program that'll put the images together for u.
way
> to do this...
> Thanks,
> Fernando.
Where could I find that? It sounds better than writing my own prg to do it
"Tony[B]" <ben### [at] catholic org> wrote in message
news:3c98fc5c@news.povray.org...
> I use ImageJoiner.
I could e-mail it to you. I don't recall where I found it. It would be a
~290kb ZIP'd Windows binary.
Tony, please email it to me, as well. I wrote the author without a response (yet). You
might also try DTA229, although my current
machine is too fast for it (I think a K6-2 was the last system that would run it).
I wrote a Visual Basic routine that would use this type of animation 'strip' as a
screen saver. It's been awhile, but I'll see if I
can hunt up the source (there is a simple example included with Visual Studio), if
anyone is interested.
Grim
Don't know if it's mentioned elsewhere in this thread, but the first frame
in the animation is used for the static image *only*, which means that the
first frame is skipped over when the animated sequence loops.
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Feb 16)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring: http://webring.povray.co.uk
Wahoo! Now I finally know how to get rid of AOL's "gift that keeps on
giving". I had AOL Version 6.0 for about a month, then switched to a cable
modem. I found out after uninstalling AOL that you can't really EVER
completely uninstall AOL. The Internet Explorer spinning logo had been
permanently replaced by AOL's "eye in the pyramid" logo. It just keeps
watching me. Somebody - make it stop!!!! AAAHHHHHH......
Now if I can just figure out how to stop "Outlook Express provided by
America Online" from appearing in OE's title bar. And how do you get AOL's
uninstall program to uninstall itself? Jeez, I hate AOL!
Cris
"Mahalis" <don### [at] fakey com> wrote in message
> Step right up, ladies and gentlemen, here it is, I know you've always
wanted
> a browser that incorporates POV-Ray in some form or other, for just 12
> payments of $0.00, you can get this amazing...
> Sorry.
> I was just looking at a very good "tweaking" website I found recently, and
I
> saw something that would let you change the Internet Explorer logo that is
> shown at the top-right of the window, you know, the spinning thingie? Save
> "Internet Explorer", "Toolbar".
> Right-click in the right pane of the window, select New>String Value and
> name it "SmBrandBitmap" (again w/o quotes). Then, once you've entered the
> name, double-click your "SmBrandBitmap" and, in the dialog box that
appears,
> type the path to whereever you've saved the file. Open IE, and voila!
> there's your little pov logo.
> Of course, for non-IE or -Windows users, this information is completely
> useless, but oh well.
> Comments? Questions? Criticism (most likely ;-)?
> //Mahalis
> camera{location<0,0.25,-2> look_at 0.5*y} #declare
T=texture{pigment{crackle
> scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
> rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
> c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
> merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
> cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
> cylinder{0.5*y,0,0.1} texture{T}}
Ummm, huh?
news:3c97c04a$1@news.povray.org...
> > -Shay
Oh! Thanks! Very useful information. I thought I had done something wrong!
Sry. I meant
"BrandBitmap" instead of "SmBrandBitmap".
"Cris Williams" <wil### [at] udri udayton edu> wrote in message
news:3c9a1c2f$1@news.povray.org...
> Ummm, huh?
> > > -Shay
Run Regedit again. Select HKEY_CURRENT_USER\Software\Microsoft\Outlook
Express\
Delete (or modify) th key "WindowTitle".
news:3c9a1898$1@news.povray.org...
cable
AOL's
> Cris
> wanted
> > Sorry.
and
> I
is
Save
"regedit"
the
> appears,
> > //Mahalis
Are you sure? I had noticed that *some* frame seemed to be skipped, but I
couldn't figure out which one it was.. I'll go check.
"Rune" <run### [at] mobilixnet dk> wrote in message
news:3c99da56@news.povray.org...
> Rune
> 3D images and anims, include files, tutorials and more:
If you really want to 'freak out' do a search of the registry for any occurence of
AOL.
Grim
"Mahalis" wrote:
> Are you sure?
Quite sure.
> but I couldn't figure out which one it was.. I'll go check.
I also think there's a limitation of 50 frames or something like that, but I
haven't tested that.
Rune
Sweet! Thank you!
news:3c9a6423@news.povray.org...
> Express\
Oh sure, thanks GrimeDude! Just keep twisting the knife! :-)
"GrimDude" <vos### [at] gulf net> wrote in message
news:3c9a6576$1@news.povray.org...
occurence of AOL.
> Grim
No problem. I don't like AOL myself ;-)
news:3c9a7597$1@news.povray.org...
> Sweet! Thank you!
> > Express\
Hmm, over here it seems that the first *four* images are skipped over after
the first time it goes around.
Anders
light_source{6#local D=#macro B(E)#macro A(D)#declare E=(E-#declare
C=mod(E D);C)/D;C#end#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(
C>2)}torus{1..2clipped_by{box{-2y}}rotate<1 0C>*90translate<D+1A(2)
*2+1#else}cylinder{0(C-v=1).2translate<D+C*A(2)A(4)#end-2 13>finish
{specular 1}pigment{rgb x}#end#end#end-8;1B(445000298)B(519053970)B
(483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)}
Ditto. Weird.
Same here.
news:3c9c970d@news.povray.org...
> Ditto. Weird.
Are you sure it's the first *four* frames? If it's always the same number,
then it would be simple to compensate.
"Anders K." <and### [at] prostar d2g com> wrote in message
news:3c9bf8ac$1@news.povray.org...
frame
the
after
> Anders
In fact I just looked it up on Google. The following is from
http://www.mvps.org/serenitymacros/ie5.html :
[HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main]
"Window Title"="IE5"
"SmallBitmap"="c:\\windows\\desktop\\smallbitmap.bmp"
"BigBitmap"="c:\\windows\\desktop\\bigbitmap.bmp"
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar]
"BackBitmapIE5"="c:\\windows\\desktop\\toolbarbitmap.bmp"
;Line below commented out. Use instead of above line with IE4
;"BackBitmap"="c:\\windows\\desktop\\toolbarbitmap.bmp"
"SmBrandBitmap"="c:\\windows\\desktop\\smbitbrand.bmp"
"BrandBitmap"="c:\\windows\\desktop\\bitbrand.bmp"
BackBitmapIE5 can be any bitmap. The only requirement is that it is light in
colour so you can read the toolbar. Size is unimportant as it will be tiled
to fit. Try clouds.bmp from the Windows directory or make your own with
Paint on the Start Programs Accessories menu. I've supplied a streched and
cropped version (1280 (streched by 2) x 100 (streched by 2 then cropped to
100px) of clouds.bmp renamed to ToolbarBitmap.bmp.
SmallBitmap and SmBrandBitmap are used when the menu bar only or a toolbar
without text labels is the top toolbar. BigBitmap and BrandBitmap is used
when another bigger toolbar is the top toolbar.
SmallBitmap is a 22 x 22 pixel bitmap and BigBitmap is a 38 x 38 pixel
bitmap and are used when Internet Explorer isn't doing anything. I've
provided a red square with a black border of each bitmap as a template for
you to modify.
SmBrandBitmap (22 pixels wide) and BrandBitmap (38 pixels wide) are the
animated bitmaps. There height is dependant on the number of frames in the
bitmap, Height=No of frames x width, so 10 frames in SmBitmapBrand is 220
pixels and in BitmapBrand would be 380 pixels.
Each BrandBitmap is a series of either 22 x 22 or 38 x 38 bitmaps joined
together vertically. I've supplied a sample bitmap of 6 frames for each to
be used as a template for making your own. These are just coloured squares
with a black border.
The first 4 frames are played once when Internet Explorer begins to browse
and the remaining frames loop over until the browse operation is complete.
If SmallBitmap or BigBitmap are absent then the first frame of the branding
bitmap is used as the static branding.
Anders
Thanks! Now I can get this to work!
news:3c9ce08f$1@news.povray.org...
number,
in
tiled
> you to modify.
branding
> Anders
Thanks dude! Works like a charm now! :)
Live and learn...
David Fontaine <dav### [at] faricy net> ICQ 55354965
My raytracing gallery: http://davidf.faricy.net/
