POV-Ray : Newsgroups : povray.binaries.images : media fur Server Time
6 Jun 2026 15:50:36 EDT (-0400)
  media fur (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: media fur
Date: 7 Feb 2002 13:33:26
Message: <3c62c876@news.povray.org>
Since the render time is only a few minutes, I believe that this method is
worth the time in some cases. Your fur has a distinct look from other fur
methods.
The only problem I can see is on the csg items. If you used union, then
merge would probably correct the problem. If you are using merge already,
then the method has a definite flaw.
 -Shay
Simon Adameit <gom### [at] gmxde> wrote in message
news:3c62a06f@news.povray.org...
> I used an IOR of -1 together with scattering media type 5 to create this
fur
> effect but I can't jugde if it is worth the rendering time compared to a
fur
> texture, so what do you think?
Date: 7 Feb 2002 13:41:21
Message: <3c62ca51$1@news.povray.org>
> methods.
Sorry, but I can't see the problem. Could you please point me to it.
Date: 7 Feb 2002 13:52:55
Message: <3c62cd07@news.povray.org>
news:3c62ca51$1@news.povray.org...
On your rounded box and rounded cyl I can see the outine of the individual
CSG objects. Might just be an illusion or compression. I'm not sure. I
wonder if a superellipsoid would show the same effect.
 -Shay
Date: 7 Feb 2002 14:08:42
Message: <3c62d0ba$1@news.povray.org>
I've used merge so I think a superellipsoid would give the same effect.
Date: 7 Feb 2002 15:08:56
Message: <3C62DED0.19AB857A@namtar.qub.ac.uk>
Simon Adameit wrote:
> I used an IOR of -1 together with scattering media type 5 to create this fur
> effect but I can't jugde if it is worth the rendering time compared to a fur
It really is more velvet than fur; you can tell straightaway.
Incidentally, that edging effect on the rounded objects I think occurs
in real life too. Should check that...
Excellent stuff!
signature{
Date: 7 Feb 2002 15:13:51
Message: <3c62dfff@news.povray.org>
Hey, I didn't even know what fur means. I just saw that all the others were
calling this fur and thought that it would be the right word but now where
I've looked it up I agree with you that it really looks more like velvet and
not fur.
> Excellent stuff!
Thanks!
Date: 7 Feb 2002 17:26:00
Message: <3C62FE97.F02251B2@amc.uva.nl>
Looks great either as short haired fur or velvet.
I would never have thought of using a negative IOR.
To quote Vroomfondel on this: 'I think our brains must be
to highly trained, Majikthise'
But if the POV developers allows fysically impossible
values, who am I to complain.
    Andrel
Date: 7 Feb 2002 17:32:38
Message: <3C630072.638885C1@duratechindustries.net>
If I were you, I'd market your texture as -the- definitive velvet of Povray.
This is really a great texture!
Date: 8 Feb 2002 01:35:55
Message: <slrna66r8d.lr4.steve@zero-pps.localdomain>
It doesn't look like fur as such, but it's still exelent.  It's more like
velvet.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 8 Feb 2002 03:34:58
Message: <3c638db2@news.povray.org>
fur
If the rendering time is not above 5 minutes, I'd accept it.. Looks good,
but media is said to be too slow.
Hugo
