POV-Ray : Newsgroups : povray.binaries.images : Trying to get softer shadows Server Time
27 Jun 2026 15:12:37 EDT (-0400)
  Trying to get softer shadows (Message 1 to 7 of 7)
Subject: Trying to get softer shadows
Date: 10 Oct 2001 21:42:28
Message: <3bc4f904@news.povray.org>
Hi there,
How can I get the shadows in this image softer?   Right now I have three
point lights, will area lights do the trick?  Is there a simpler solution?
Thanks!
Download 'cube.jpg' (45 KB)
Preview of image 'cube.jpg'
Subject: Re: Trying to get softer shadows
Date: 10 Oct 2001 22:55:50
Message: <3bc509b6.3183908@news.povray.org>
On Wed, 10 Oct 2001 21:42:13 -0400, "Arie L. Stavchansky"
Perhaps you might simply delete your three point lights and add an
area light then re-render and take a peek at your results. Let us know
how that works out for you.
Mitch
Date: 11 Oct 2001 02:45:28
Message: <3bc54008@news.povray.org>
An area light is the best option for that scene but if you were to want a
larger light source the area light shadow trick starts to break down.  An
alternative that creates more realistic soft light|shadow is radiosity,
though it's considerably slower.  Here's a short example (add +qr to the
command line).  The sky sphere serves as the light source...the light in the
scene is used for the specular highlight only.
global_settings{
  radiosity{
    pretrace_start 0.01
    pretrace_end 0.01
    count 100
    recursion_limit 1
    nearest_count 4
    error_bound 0.3
    brightness 1
    normal on
sky_sphere {
gradient y
color_map {
[0 color <.2, .3, .4>]
[.9 color <.2, .3, .4>]
[1 color 5*White]
scale 2
translate -1*y
rotate -90*x
rotate 30*x rotate 45*y
camera {location <1, 5, -7> look_at 1*y angle 40}
light_source {<0, 0, -1000> color .0001*White
sphere {<0, 1, 0>, 1
pigment {color White}
finish {phong 100000 phong_size 120 diffuse .7}
normal {bumps 1 scale .3}
plane {y, 0
finish {diffuse .7}
Date: 13 Oct 2001 09:46:46
Message: <3bc845c6@news.povray.org>
Thanks guys,
I tried area_lighting and that still didn't give me what I wanted.  I have
been taking a look around in the group and the stuff that is being done with
radiosity is really what I wanted.  By the way, some of your folks are truly
inbelievable--the work in this group is impecible.  Anyways,  attached is a
new version of my scene with radiosity.  The only problem I have with this
is the size of the specular on my spheres.  How can I reduce this?
Currently, there are no light sources in the scene.  If I add some
everything just becomes brighter.  Any suggestions?
Thanks for all your help,
Arie
"Mike Hough" <Ama### [at] aolcom> wrote in message
news:3bc54008@news.povray.org...
the
> global_settings{
>   radiosity{
>     pretrace_start 0.01
>     pretrace_end 0.01
>     count 100
>     recursion_limit 1
>     nearest_count 4
>     error_bound 0.3
>     brightness 1
>     normal on
> sky_sphere {
> pigment {
> gradient y
> color_map {
> [1 color 5*White]
> scale 2
> translate -1*y
> rotate -90*x
> plane {y, 0
> finish {diffuse .7}
Download 'sphereCube.jpg' (74 KB)
Preview of image 'sphereCube.jpg'
Date: 13 Oct 2001 14:30:38
Message: <3bc8884e$1@news.povray.org>
The specular highlight on the spheres is probably the reflection of the
bright spot on the sky sphere.  It can be made smaller by changing the color
map component [.9 color <.2, .3, .4>] to something like [.98 color <.2, .3,
.4>].  There are still some artifacts in the shadow that could probably be
reduced by increasing the count or reducing the error bound.  Excessive
brightness can be reduced by lowering the radiosity brightness when you add
a light source.
Date: 13 Oct 2001 15:12:45
Message: <3bc8922d$1@news.povray.org>
"Arie L. Stavchansky" <ari### [at] bellatlanticnet> escreveu na mensagem
news:3bc845c6@news.povray.org...
This second picture you posted seems to feature one area_light, but
*without*  the "jitter" keyword. If you render this exact same scene with
"jitter", I believe you will get your soft shadows.
Ruy
Date: 20 Oct 2001 23:00:43
Message: <3bd23a5b@news.povray.org>
For some reason the shadows aren't getting any softer even when I adjust
some of the settings you have mentioned.  The "curves" of the shadows are
not soft.
What I am truly looking for is the softness found in Ruy's tetrahedron macro
image.  Ruy, you got any tips?
Thanks for everybody's help.
Arie
news:3bc8884e$1@news.povray.org...
color
.3,
add
> a light source.
