POV-Ray : Newsgroups : povray.binaries.images : rad vs. global illumination Server Time
17 Aug 2024 22:19:59 EDT (-0400)
  rad vs. global illumination (Message 1 to 6 of 6)
Subject: rad vs. global illumination
Date: 29 Aug 2001 16:04:17
Message: <3b8d4ac1@news.povray.org>
Hi all,
I want to show someting new on my old boring "warm_up".
The image was made with a 11 point lights to simulate global illumination at
that time.
Christoph Hormann recommended the use of radiosity repeatedly.
Eight days back Kari Kivisalo wrote 1 bounce radiosity would be as fast as
the use of point lights to simulate global illumination.
So I show 2 trials with different rad settings.
The first image was done with simple settings:
                pretrace_start 1
                pretrace_end   1
                count 30
                recursion_limit 2
                low_error_factor 0.5
                brightness 1.2
The result is similar to using shadowless fill lights, but it rendered
within 16 h (about 4 times faster than the original would have rendered with
AA0.3).
The second image was done with better settings:
                pretrace_start 0.08
                pretrace_end   0.005
                count 120
                recursion_limit 1
                low_error_factor 0.25
                brightness 1
Much better, but not as good as with faked "global illumination". Render
time was similar to the original (
http://www.irtc.org/ftp/pub/stills/2001-06-30/warm_up.jpg ).
I think, point ligths simulating global illumination can be sometimes better
than radiosity.
Comments?
Norbert
Download 'warm_upRada.jpg' (74 KB) Download 'warm_upRadb.jpg' (75 KB)
Preview of image 'warm_upRada.jpg'
Preview of image 'warm_upRadb.jpg'
Subject: Re: rad vs. global illumination
Date: 29 Aug 2001 16:35:40
Message: <3B8D52BC.4008579A@gmx.de>
> than radiosity.
> Comments?
I think it's not that simple, radiosity does not only compute the
influence of diffuse light from sky but also the radiative interaction of
all objects of the scene, something that gets totally lost with shadowless
lights.
Your rad settings seem to use default error_bound of 1.8 which is fairly
high, lowering it could help to bring more structure in the shadowed parts
of the scene.
And of course the finishes probably need to be adapted to the different
illumination for optimal results.
NTL it's nice to finally see this scene with radiosity.
Date: 29 Aug 2001 17:35:47
Message: <3b8d6033$1@news.povray.org>
"Christoph Hormann" <chr### [at] gmxde> schrieb im Newsbeitrag
news:3B8D52BC.4008579A@gmx.de...
> lights.
I used shadowing lights in my fake, but you are right, radiosity does much
more.
Pure global illumination is only helpful in some very special cases.
> of the scene.
I used error_bound 0.1 in the second image (forgot to mention).
of course
ready.
Norbert
Date: 29 Aug 2001 22:07:39
Message: <3b8d9feb$1@news.povray.org>
Radiosity lends itself better to architecture than to landscapes.  There
isn't even a benefit to the viewer by performing radiosity steps on things
like grass and leaves because the samples are so small.  All you really need
is to simulate the hemispherical source of the sky.  Now, if there were a
tree stump or large, man-made object in the scene, than radiosity could make
a difference...though in that case I would try rendering just that object
with the sky and saving the radiosity cache file, then load the file back in
with everything visible for the final render.  Never really tried it but
that should work.
Anyway, the original version of this scene looks the best IMO.
Date: 30 Aug 2001 04:46:21
Message: <3b8dfd5d@news.povray.org>
"Mike Hough" <Ama### [at] aolcom> wrote in message
news:3b8d9feb$1@news.povray.org...
Maybe but radiosity especially with poorer settings changes the colour of
the image considerably and enhances the atmosphere of the image.
Mick
Date: 31 Aug 2001 00:43:36
Message: <3b8f15f8@news.povray.org>
You're right, it does create a different look.  Kind of impressionist.  At
the time I was thinking of it in terms of photorealism and having radiosity
create a more accurate representation of the lighting rather than looking at
it in an artistic sense.
-Mike
