![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Tom Melly
tom### [at] tomandlu co uk
http://www.tomandlu.co.uk
Download 'xmas.jpg' (29 KB)
Preview of image 'xmas.jpg'
![xmas.jpg](/povray.binaries.images/attachment/%3C3a45e73c%40news.povray.org%3E/xmas.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Very Povish and stylish, thanks Tom.
Steve email mailto:ste### [at] zeropps uklinux net
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
3:10pm up 6 days, 2:31, 2 users, load average: 1.02, 1.06, 1.02
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Very cool. Thanks. Ditto! :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Couple of things - the lettering is added in psp, and there's an odd
side-effect of the scattering media. The back wall that shows through the
shaft of light looks as though it has a nice medieval-style brick normal. It
doesn't. The media seems to work in layers and what you're seeing is the
staggered image of the stained glass at discrete intervals.
It's mp type 3 scattering media. Anyone come across this before?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3a469144@news.povray.org>, "Tom Melly" <tom### [at] tomandlu co uk>
You need to either use more samples or add jitter to the samples. Adding
jitter will break up the patterns, but will make things noisier.
Putting transparent, hollow planes or boxes in front and behind the beam
of light should also help, since it will force POV to make a new
interval at each surface. This actually might be the best workaround,
since it puts the additional samples right where you need them, but it
requires you to know where the light beam is..
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> doesn't.
I was just about to commend you for acheiving this...
Francois Labreque | Rimmer: "Let's go to red alert!"
flabreque | Kryten: "Are you sure, Sir? You realize it
@ | actually means changing the bulb!"
videotron.ca
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
he
l. It
e
You could try using mpov and the sample_spacing patch to help with this
problem... Otherwise, Chris Huff's suggestions are the way to go (or a
combination of the two).
* Abandon the search for truth, * mailto:ber### [at] iname com
* Settle for a good fantasy. * http://www.enst.fr/~jberger
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
How come your patch has never been added to MegaPOV? I really would like to
try it without having to compile it...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
e to
I'm not sure. I sent what I had at the time to Nathan just before he
released MegaPov 0.5 and he said he wouldn't include it in 0.5 because
he lacked the time to test it properly. Some of the code made it though
(because it came with a bugfix) but it's #ifdef-ed out. I suppose Nathan
forgot it when he released 0.6
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I took the samples up to 30 and, although still noticable if you know what
you are looking for, the artifacts are fainter (as shown in attachment).
Presumably, higher values would diminish them even more.
To be honest, I hadn't realised that the normal POV params applied to
megapov media methods 2 and 3.
Download 'part_xmas.jpg' (3 KB)
Preview of image 'part_xmas.jpg'
![part_xmas.jpg](/povray.binaries.images/attachment/%3C3a49cde0%40news.povray.org%3E/part_xmas.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
