POV-Ray : Newsgroups : povray.binaries.images : Heavy Egg (H.E.) update - 23kbu Server Time
19 Aug 2024 18:26:35 EDT (-0400)
  Heavy Egg (H.E.) update - 23kbu (Message 1 to 8 of 8)
Subject: Heavy Egg (H.E.) update - 23kbu
Date: 8 Nov 2000 20:31:15
Message: <3a09fe63@news.povray.org>
No rad, AA 0.5, motion_blur 19,1/64 and still a four hour render.
Check out that water! Kevin Ellis' iso function with my texture (material).
Grim
Download 'HE_iso.jpg' (23 KB)
Preview of image 'HE_iso.jpg'
Subject: Re: Heavy Egg (H.E.) update - 23kbu
Date: 8 Nov 2000 23:03:05
Message: <slrn90k7dr.g0e.steve@zero-pps.localdomain>
Wow that looks like real scrub land.
  3:26am  up 29 days,  5:48,  3 users,  load average: 1.00, 1.00, 1.00
Date: 8 Nov 2000 23:25:16
Message: <3A0A24CA.9B48959C@home.com>
Hmm despite the AA of 0.5 it still looks Aliased to me, also the ocean blurs a
lot in the background. This detracts from the realism of the water a lot! Maybe
it's just the Jpeg compression. I love the work on the plane!!
> Grim
Date: 9 Nov 2000 04:26:28
Message: <3a0a6dc4@news.povray.org>
That looks very nice. I was just wondering what you changed the texture
(material) to?
It's a shame you had to cut out the radiosity, it seems to make the water
look much better in my tests. But I suppose it can be faked by changing the
water (media) color.
Kev
http://web.libertysurf.co.uk/kevin.ellis/
Date: 9 Nov 2000 11:59:19
Message: <3a0ad7e7@news.povray.org>
I used a texture that animates fairly well. To get better results you will
need to modify the period and range of effect. You can see where I, too,
remarked out the reflection_blur. I attempted to animate your function, too,
but hit some weird noise in my first few attempts. Stil working on that.
Enjoy!
Grim
      pigment { color rgb <0,0,.001> }
      finish { diffuse .05 ambient 0 //reflection_blur .06
         reflection_max .35*<.62,.63,.67> reflection_min .35*<.41,.465,.485>
reflection_falloff .9
         reflection_exponent 1.7 specular 5 roughness 100 brilliance 3
metallic 1 }
      normal { wrinkles normal_map {
         [0 waves .05 scale <2500,1500,2500> translate -.5 rotate -45
frequency 25000 phase (sin(2*pi*clock)) ]
         [1 ripples .05 scale <2500,1500,2500> translate .5 rotate 45
frequency 25000 phase (cos(2*pi*clock)) ] }
         scale <.001,1,.001> scale <.02,50,.02>
         warp { turbulence .6 octaves 2 lambda 5 omega .2 }
         warp { turbulence -.6 octaves 2 lambda 5 omega .2 }
         turbulence .6 phase (sin(2*pi*clock)) scale 1000 }
translate -15*z }
         interior { ior 1.45 } hollow translate <0,-.5,5> }
Date: 10 Nov 2000 01:31:58
Message: <3a0b965e@news.povray.org>
"Thomas Lake" <tla### [at] homecom> wrote in message
news:3A0A24CA.9B48959C@home.com...
The higher you set aliasing, the better it looks. Trying to blur the motion
of the plane object, in its entirety (I finally merged the objects
correctly), *really* slowed down rendering, so I backed off the aliasing a
tad (with other changes).
>...also the ocean blurs a
Maybe
Noted, but I thought enough realism came through as it was. Upping the
aliasing helps a ton, but jpeg compression didn't help anything.
>...I love the work on the plane!!
Thanks! At this range most of the decals are turned off, though. So, there
is more detail then you can see in this image (rivets too, plus the new
cockpit coming along). Instilling motion blur on the overall object detracts
from detail, as well. Oops, I talk about that plane too much! Formation
break is taking most of my time, right now. It's quickly turning into three
separate animations, which will tell a story in sequence. That, or it'll
quickly consume all of my time and drive me insane (shutup Ken) :^)
Grim
Date: 10 Nov 2000 02:05:03
Message: <3A0B9E81.DFEB0DC2@pacbell.net>
GrimDude wrote:
> ...quickly consume all of my time and drive me insane (shutup Ken) :^)
Who me ?
Date: 10 Nov 2000 12:32:26
Message: <3a0c312a@news.povray.org>
Oops, your smiley face didn't come through there. ;) LOL
I found where I can speed this up significantly. At some point in the past I
determined reflection_blur worthwhile. I change my mind :) Maybe, I'll turn
it on later.
Just another form of insanity...
Grim
