POV-Ray : Newsgroups : povray.binaries.images : Film exposure simulation patch Server Time
4 Jun 2026 19:53:53 EDT (-0400)
  Film exposure simulation patch (Message 2 to 11 of 21)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Film exposure simulation patch
Date: 9 Nov 2002 12:31:53
Message: <3dcd4689@news.povray.org>
Can we have a few more demos scenes - I for one fond this very interesting!
PGP Public Key
Version: 6.0.416 / Virus Database: 232 - Release Date: 06/11/2002
Subject: RE: Film exposure simulation patch
Date: 9 Nov 2002 12:40:57
Message: <3dcd48a9@news.povray.org>
3DCD3221.F40A6CBA@luxlab.com...
> The patch simulates decrease of reactive chemicals in film
> emulsion during exposure. The areas that have received more
> light react less than other areas. Usefull for high contrast
> scenes as it brings up the dark areas and limit bright areas.
Very interesting and useful patch. Looks great.
Waiting to see more examples
Txemi Jendrix
http://www.txemijendrix.com
Date: 9 Nov 2002 14:18:39
Message: <3dcd5f8f$1@news.povray.org>
That sounds great. What about digi-cams? Are they inferior in this field?
Hugo
Date: 9 Nov 2002 14:32:32
Message: <3dcd62d0@news.povray.org>
Heh, I made a patch just similar to yours a couple months ago... My first
Povray modification :) You're using the 1-exp(-x) function, right?
Date: 9 Nov 2002 15:36:58
Message: <3DCD71E8.B1D36A7C@luxlab.com>
And you kept in the desk drawer?
It seems to be the simplest usable function for this purpose.
_____________
Kari Kivisalo
Date: 9 Nov 2002 15:48:15
Message: <3DCD748D.F97958E4@luxlab.com>
It seems that camera manufacturers aren't forthcoming about
the on-board image processing features. One transfer curve
I saw was definitely film-like which is kind of natural :)
_____________
Kari Kivisalo
Date: 9 Nov 2002 16:03:04
Message: <3dcd7808@news.povray.org>
I was quite fond of it and was of course going to publish it here, but then
Kevin Loney came up with his own patch just before I was about to do so.
Date: 9 Nov 2002 16:36:29
Message: <3DCD7FD9.ABC1C618@luxlab.com>
> then Kevin Loney came up with his own patch just before I was about to
> do so.
His patch was going in different direction so I decided to make
this one.
_____________
Kari Kivisalo
Date: 9 Nov 2002 19:32:13
Message: <chrishuff-667AA3.19315309112002@netplex.aussie.org>
In article <3dcd5f8f$1@news.povray.org>, "Hugo" <hua### [at] post3teledk>
Not really sure what you are asking...the CCD will have a different
response curve than film or the human eye. Some of them might do
filtering to end up with something closer to film, or just something
that looks better. The design of the CCD element probably matters as
well.
They can't really be inferior or superior to POV, since they have quite
different information. POV has essentially unbounded float triples with
the "real" light intensities, cameras have fixed point values with the
raw output of CCD elements, restricted to a certain range.
http://tag.povray.org/
Date: 10 Nov 2002 01:21:29
Message: <1959856.txouLzAQV6@3-e.net>
> I have combined aperture, film speed, and exposure time into
> one exposure variable which goes into global_settings. The images
> show the difference between normal and exposed image. I'll test
> it some more to see if it works nicely with anti-aliasing and
> focal blur.
I call it contrast masking, or dynamic range compression.
I used that method during development of black and white photos for an
exhibition I held about 15 years ago.
I used it for both the film and the paper with the film being a very high
resolution copy film with an ASA of about 12, a very high silver content
and almost invisible grain, even when 35mm frames were printed at 16X20
inches.
The subject matter was shot in full sunlight and included white marble and
black granite so you can imagine how massive the dynamic range was!
You place the developer saturated emulsion into a warm water bath (very
gently!) and then it continues to develop, but with the shadows held back
as they consume more of the locally available developer.
I think your patch will be very useful in some scenes.
Your connection failed because: need to wrap system in aluminum foil to fix
problem
