![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://davidf.faricy.net/image.php?pic=blackseasbarracuda3.jpg
The render time seems to have magically dropped for some reason...
After brightening the radiosity to make the ship show up better, I
didn't like the big bright splotch on that one sail, so I dimmed the
light from the sun, forgetting it would affect the clouds (slaps head)!
I used light_groups to get it all how I want it. I finally added
load_file to the radiosity too so I can rerender it faster, but that's
not what made it magically speed up, since this was the render I saved
the rad data from...
BTW, all renders on my site are now shown with a black background when
you click on them. :)
___ ______________________________________________
| \ |_ website: http://davidf.faricy.net/
|_/avid |ontaine email: <dav### [at] faricy net>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
All I got was a black page with a "back to the gallery" link showing.
Ken Tyler
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Me too.
Tim Nikias
Email: Tim### [at] gmx de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Really? That's not good. It works fine on my computer, in both
Netscape and IE. There's always the image itself:
http://davidf.faricy.net/renders/blackseasbarracuda3.jpg
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
For some reason it was not getting the pic var then. I know the php
script works, so it must be something with how the URL is handled.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> I finally added load_file to the radiosity too so I can rerender
> it faster, but that's not what made it magically speed up, since
> this was the render I saved the rad data from...
That's pretty strange. You rendered this picture in a two-pass and it took
less time than earlier? Well.... How do you load the rad file? Because if
you replace the rad settings with a "load" then you don't get the same
radiosity.. I.e. the radiosity applied is not the same as when you use a
one-pass.. The saved file does not contain all information about how it
should be treated when applied to the scene.
Hugo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
David:
The whole gallery appears to be broken. Very nice images from the
thumbnails, BTW. Please fix so we can view!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It works fine for me, and so does the rest of the gallery. I use
Netscape 6.2, but since it is php it should be browser independent.
/Ib
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
As the other posters said, there is no image. I looked into the HTML
source generated by your PHP code, and found the reason: You are using
backslashes in the path to the image:
<img src=".\renders\blackseasbarracuda3.jpg">
but PHP (to be more exact, the underlying webserver) requires forward
slashes as path separators. The character sequence \r is actually a
single ASCII character (13 => Carriage return), the same is true for \b
(which is 8 => Bell). Just change this and it will work.
Timon Christl <me### [at] christltimon de>
"Hungarian Notation is the tactical nuclear weapon of source code
obfuscation techniques" -- Unknown
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
David Fontaine <dav### [at] faricy net> wrote in
news:3D2### [at] faricy net:
Opera 6.03 crashes every time after opening this link
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
