![](/i/fill.gif) |
I was a bit inspired by Episode II, so here's a quick model I did the other
night..It's supposed to look like Yodas saber, which I found some pictures
of on the net.
I got the media ideas for the blade by looking at a scene file (sabre.pov by
Kenyon Banks) I found in the newsgroups.
So far all the sabers are the same..likely to change if I get the time. The
background is some hubble picture I came across..
-Peter
Download 'lightsaber.yoda.jpg' (14 KB)
Preview of image 'lightsaber.yoda.jpg'
![lightsaber.yoda.jpg](/povray.binaries.images/attachment/%3C3d021e4b%40news.povray.org%3E/lightsaber.yoda.jpg?preview=1)
![](/i/fill.gif) |
![](/i/fill.gif) |
cool
how did u do the blade?
> of on the net.
> -Peter
![](/i/fill.gif) |
![](/i/fill.gif) |
> cool
Glad you like it!
One small cylinder in the middle filled with media (I_Blade2) and a large
cylinder also with media (I_Blade).
I'm not satified with it yet..I'd like the places where the lightsabers
cross to bercome white, not a blend of the two colors. But I haven't used
media much, so I don't have a clue on how to achive that.. something to do
with absorption?
Here's the messy code:
#declare Sta = 0.5; // just for testing
#declare CLR = <0.25,1,0.25>; // color
#declare I_Blade = media {
intervals 10 // number of intervals used for sampling [10]
samples 1,1 // minimum and maximum number of samples taken
per interval [1,1]
confidence 0.9 // statistic parameter higher->better quality
[0.9]
variance 1.0/128 // statistic parameter lower->better quality
[1.0/128]
ratio 0.9 // distribution between lit and unlit areas
[0.9]
emission 0.3 // emitting media, emit light of specified
color
method 3 // adaptive sampling
density {
cylindrical
turbulence 0.05
color_map{
[0 rgb CLR transmit 1]
[1 rgb CLR transmit 0.8]
#declare I_Blade2 = media {
per interval [1,1]
[0.9]
[1.0/128]
[0.9]
emission 0.5 // emitting media, emit light of specified color
density {
cylindrical
turbulence 0.05
color_map{
#declare Beam =
union{
merge{
cylinder {-y*1,y*70,1.8-Sta}
sphere {0,1.8-Sta scale <1,1.5,1> translate y*70}
interior{media{I_Blade}}
pigment {rgb CLR transmit 0.9-0.3+Sta }
finish {ambient 0.2}
hollow
merge{
cylinder {-y*1,y*70,0.5}
sphere {0,0.5 scale <1,1.5,1> translate y*70}
interior{media{I_Blade2}}
pigment {rgb CLR transmit 0.9}
finish {ambient 0.9}
hollow
object {Beam translate y*20.1}
![](/i/fill.gif) |
![](/i/fill.gif) |
> > transmit doesn't do a thing in media. You should use:
> Wanna bet? Try setting transmit to 1.5 or something...;)
Must be a POV-Ray 3.5 thing then, cause it doesn't do anything in MegaPov
0.7
cu!
ZK AKA SaD
http://www.povplace.be.tf
"Two hits: me hittin' you, you hittin' the floor."
![](/i/fill.gif) |
