On Thu, 25 Apr 2002 00:24:02 -0400, Bill DeWitt wrote:
> "Tim Nikias" <tim### [at] gmxde> wrote in message
> news:3CC70DE3.C9D07958@gmx.de...
>> Here's the original trace, not reduced in size. No focal-blur-AA,
>> because that's time-intensive and makes it look nicer, not
>> better.
> If you say so.
> I think this looks nice but I can't help but think that not having stair
> stepping on the shoots would help. But the larger resolution allows some of
> the detail that you worked so hard on show up.
> There is still the unfortunate areas of the glass that looks like
> coincident surfaces or something.
I agree with Bill here, and think that the glass problem may also go away
with some AA.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/ * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\( ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~ -/__\\__\\__\\__\\__\\*//* Steve */
To you both:
Yeah, some AA would definetely look good.
Ther are no coincident surfaces, inside the vase,
the rays is refracted and reflected so often, that
even a setting of 256 max_trace_level doesn't
help, because the ray probably just travels long
enough inside the vase to get darkened by fade_power...
But it isn't so obvious with some focal blur, looks more
like some curious refraction.
But all you guys have to wait for a AA version, it takes
SOOO much longer, and I cannot afford doing intensive
traces before I'm actually on a version where I can say
finished...
> >> better.
> > If you say so.
> with some AA.
Tim Nikias
Email: Tim### [at] gmxde
Not really. When using focal-blur, the sharp
edges of the shadows aren't visible. And since
its a studio-setting, too much area-light would
destroy the look.
Steve wrote:
> On Wed, 24 Apr 2002 18:54:02 +0200, Tim Nikias wrote:
> > So, here is the last and final Gerbera-Composition. Any more
> > suggestions? Comments?
> > If there's nothing to change (no additions anymore),
> > this is going to be it.
> > I tweaked the amount of smaller petals (from 500 to a more
> > realistic 120) and the look of the larger outside petals (to
> > match a real-life gerbera).
> You need area lights boy.
> %HAV-A-NICEDAY email mailto:ste### [at] zeroppsuklinuxnet
> Steve web http://www.zeropps.uklinux.net/
> or http://start.at/zero-pps
> 11:07am up 6 days, 7:47, 1 user, load average: 1.26, 1.23, 1.13
Tim Nikias
Try lower adc_bailout (if you haven't already)
-tgq
Holy cats-- that's beauteous. Rocks the Casbah. Great job.
DZ
I'll try, but I'm thinking it all has to do either
with the incoming ray being in such a strange
angle to the glass, that its just bouncing around
in the glass.
Ohterwise, it could also be related to the
smooth-triangles/mesh bug which cannot
be fixed in Povray 3.5 (the bug which also
affects heightfields and their correct tracing).
I'll see what I can do, but it doesn't look to bad actually.
> -tgq
Tim Nikias
If you want to mail the vase to me within the next three hours, I can take a
look this evening and see if I can spot the problem.
-Shay
Tim Nikias <tim### [at] gmxde> wrote in message
news:3CC85619.15FEFEB2@gmx.de...
I was running through my code and trying to prepare a
vase for you to look at. But, you'd be overloaded with
the "unknown". Tons of Macros of which I haven't
yet written good comments and descriptions, declarations
all around the place, though not in random order,
hard to describe.
I'll send a version without all but the vase, and
all the required includes I've written, but if you cannot
find through the mess, I won't complain. ;-)
In any case, thanks for your offer!
> -Shay
Tim Nikias
news:3CC8596C.6C6145F5@gmx.de...
Awesome. If you don't make the mail to me by 5:00 US Central standard time
(2:47 here now), I will email you my home email addy. I will look and see if
I can't find what's causing the appearance of a sharp edge along the top as
well.
-Shay
I've taken care of the sharp edge (two meshes,
the inside and outside: inside based on outside,
that sharp edge was due to the same coords
for that area), so a new connection was made
using my cubic-bezier-splines-algorithm for
every two coords...
Like I said, mesh-modelling-macros...
And just sent it on its way.
> well.
> -Shay
Tim Nikias
