POV-Ray : Newsgroups : povray.binaries.images : ten Server Time
17 Nov 2025 02:17:41 EST (-0500)
  ten (Message 1 to 4 of 4)
Subject: ten
Date: 16 May 2001 22:01:28
Message: <3B0330D4.707BB4BE@x.x>
This is the number ten in pure set notation, shown as nested boxes.  So
you can see what is happening more clearly, I also included five done
the same way and a two d version of ten that I did a while back in a
paint program.
Download 'tenbox.jpg' (43 KB) Download 'fivbox.jpg' (38 KB) Download 'kromoten.jpg' (64 KB) Download 'psr.pov.txt' (10 KB)
Preview of image 'tenbox.jpg'
Preview of image 'fivbox.jpg'
Preview of image 'kromoten.jpg'
Subject: Re: ten
Date: 16 May 2001 22:24:34
Message: <3b033662$1@news.povray.org>
I lost count at 8 I think.  Or rather I don't know what the heck I'm seeing.
Nice try to show it though.
Bob H.
Subject: Re: ten
Date: 16 May 2001 23:25:46
Message: <3b0344ba$1@news.povray.org>
x@x.x wrote in message <3B0330D4.707BB4BE@x.x>...
>paint program.
I think I follow this. . . at the least the 2d version. Starting with a single
small box and progressing first right and then down, repeat everything that came
before and enclose in another box to express it as a set, right?
Then just perform the process 10 times and finish with a single box to maintain
consistent set notation.
The 3 versions are harder to follow -- can't tell if you're going up,down left,
right or what. The 2d version would make an interesting texture pattern. BTW I'm
no math expert but I think this more like 'factorial' set notation.
Batronyx ^"^
bat### [at] cadronhsacom
http://www.batronyx.com
Bhuddist monk to hotdog vendor:
     "Make me one with everything."
Subject: Re: ten
Date: 17 May 2001 03:29:00
Message: <3b037aff.34396155@news.povray.org>
On Wed, 16 May 2001 22:32:02 -0500, "Batronyx"
Yes.  The smallest box is the empty set i.e. zero.  Then you get the
set containing zero (one), then the set containing zero and one (two)
etc.  The traced version shows zero, then one next to it, then two
below them, then three behind all of those, four beside, five below,
six behind etc.  The complete figure has zero through nine, all
surrounded by a box to make ten.
IIRC, this is the von Neumann definition of the ordinal numbers.  I
read about this several years ago in a book by Rudy Rucker.  He had a
cartoon of a person thinking nested "thought balloons" to illustrate
the concept.  I remembered that and decided to play with the idea.
The code would be much cleaner and more efficient if I had used
recursion and/or a static lookup table.  For such a trivial thing cut
and paste coding seemed adequate.
BTW, I posted that from a place in which I prefer not to leave
personal info.  Hence the x@x.x.
Jerry Anning
cle### [at] dholorg
