POV-Ray : Newsgroups : povray.binaries.images : A nice tiling macro Server Time
18 Aug 2024 16:22:31 EDT (-0400)
  A nice tiling macro (Message 1 to 7 of 7)
Subject: A nice tiling macro
Date: 19 Apr 2001 15:43:34
Message: <3ADF405C.22C3478@erols.com>
ICQ: 46085459
Download 'tile.jpg' (192 KB)
Preview of image 'tile.jpg'
Subject: Re: A nice tiling macro
Date: 19 Apr 2001 16:08:19
Message: <3ADF45B4.1867DBCE@gmx.de>
Separate objects or pattern with repeat warps etc?
Date: 19 Apr 2001 16:42:08
Message: <3ADF4E63.2C502498@erols.com>
Pattern only.
John
// The macro code
#macro OctoTile(OctA,OctB,Square,Fill,W)
#local tS= texture { Square Matrix((x+z)/2,y,(z-x)/2,<0,0,0>) }
#if(W<=0)
  #local tC= texture { checker texture { OctA }, texture { OctB }
  #local iA=.5-sqrt(.125);
  #local iB=sqrt(.125);
  #local iC=1-sqrt(.125);
  #local iD=.5+sqrt(.125);
  #local tA= texture { gradient x texture_map {
    [iA tS][iA tC][iD tC][iD tS] } }
  #local tB= texture { gradient x texture_map {
    [iB tC][iB tS][iC tS][iC tC] } }
  gradient z Matrix ( x-z,y,x+z,<0,0,0>) texture_map {
  [iA tA][iA tC][iB tC][iB tB][iC tB][iC tC][iD tC][iD tA] }
#else
  #local tC= texture { checker texture { OctA }, texture { OctB } }
  #local tX= texture { gradient x texture_map {
    [W/2 Fill][W/2 tC][1-W/2 tC][1-W/2 Fill] } }
  #local tZ= texture { gradient z texture_map {
    [W/2 Fill][W/2 tX][1-W/2 tX][1-W/2 Fill] }
  #local tF= texture { Fill Matrix((x+z)/2,y,(z-x)/2,<0,0,0>) }
  #local iA=.5-sqrt(.125)*(1+W);
  #local iB=.5-sqrt(.125)*(1-W);
  #local iC=.5+sqrt(.125)*(1-W);
  #local iD=.5+sqrt(.125)*(1+W);
  #local tA=texture { gradient x texture_map {
    [iA tS][iA tF][iB tF][iB tZ][iC tZ][iC tF][iD tF][iD tS] } }
  #local iE=sqrt(.125)*(1-W);
  #local iF=sqrt(.125)*(1+W);
  #local iG=1-sqrt(.125)*(1+W);
  #local iH=1-sqrt(.125)*(1-W);
  #local tB=texture { gradient x texture_map {
    [iE tZ][iE tF][iF tF][iF tS][iG tS][iG tF][iH tF][iH tZ] } }
  #local tC=texture { gradient x texture_map {
    [iB tF][iB tZ][iC tZ][iC tF] } }
  #local tD=texture { gradient x texture_map {
    [iE tZ][iE tF][iH tF][iH tZ] } }
  #local sDummy=0;
  gradient z Matrix(x-z,y,x+z,<0,0,0>) texture_map {
  [iA tA][iA tC][iB tC][iB tZ][iE tZ][iE tD][iF tD][iF tB]
  [iG tB][iG tD][iH tD][iH tZ][iC tZ][iC tC][iD tC][iD tA] }
// to use it
plane { y,0
    OctoTile(OctText1,OctText2,SquareText,FillText,FillWidth)
Date: 19 Apr 2001 16:53:48
Message: <slrn9duk2t.pl.ron.parker@fwi.com>
>Pattern only.
Clearly great minds do think alike.  Y'all should go over to p.t.scene-files
and check out the interesting tiling macros I've been posting there, if you
haven't already.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 20 Apr 2001 03:45:52
Message: <MPG.154a07a733259fcc989748@NEWS.POVRAY.ORG>
In article <slr### [at] fwicom>, Ron Parker says...
> haven't already.
I am becoming increasingly unhappy, not only because I can't do things
like these, but also because I don't understand how they work. :((
But these 'things' are very nice indeed! Lucky you!
Regards,  Sander
Date: 20 Apr 2001 09:34:09
Message: <slrn9e0emi.1cb.ron.parker@fwi.com>
I could give a try to explaining one of the simpler ones, if there's
popular demand.  I won't try to explain 3, though.  That requires large
amounts of caffeine.
Date: 20 Apr 2001 11:07:32
Message: <3ae050b4@news.povray.org>
Yeah, it's kinda ugly.  I see how it works.  It's much like some of my
complex textures, layers upon layers of stuff to break up and sort and
reorganize.
The basic system (like 1), is pretty easy to understand, as it's the same
basic mechanizm as a kalaidescope.
Geoff
