![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Chris Huff wrote:
> It looks good, but judging from the scale of the water ripples and
> caustics, the structure is a very small scale model, maybe 5 feet long.
> Much smaller than expected, anyway...
I know, already thought about making the waves smaller, but feared that
the caustics would get too uniform.
> I'm not sure if it would make much of a difference in appearance, but
> the render time shouldn't be to bad if you don't use pigment functions.
At least the water line looks very straight so i will probably try it
sometime, but i suppose it would be indeed quite a bit slower, especially
for the radiosity calculations.
Christoph Hormann <chr### [at] gmx de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
J Charter wrote:
> Very cool!
Thanks!
> I too find the water pattern takes away. Looks like ridged
> multi-fractal I say to myself, but the recursive structure holds my interest
> bigtime.
It is indeed RMF, because of the sharp ridges it's usually better for more
turbulent water, so maybe i should change it.
> Seems like you're just a twist and a turn away from something very
> good indeed!
Sorry, not sure what you mean with that.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Peter Popov wrote:
> Yeah, about the only reason to leave the computer room is to check out
> something in the real world :)
That's the reason why I often wish to have a laptop - sadly those things
are quite expensive.
> Try adding some radiosity if you're not afraid by the render times.
Oh, i didn't mention it , but it actually uses radiosity, without i
suppose the render time would be just half of it.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3AC76B05.2FF7A4E6@gmx.de>, Christoph Hormann says...
> This took quite a lot of time to render (20 h for trace, 29 min for
> photons) and i'm still not really satisfied. Guess i will have to do some
> real world studies with a pot of water in the garden...
> Some grainy artefacts are visible on the upper parts of the arches on the
> left side of the picture. I'm not sure if they are caused by the photons
> or by something else.
> What i would really like to try is using an isosurface for the water
> instead of the normal, but i'm a bit afraid of the render time.
> Comments are welcome of course.
> Christoph
A very intriguing image! Reminds me of Escher, though he didn't use this
theme to do an infinity picture, IIRC. I like the effects of
reflections.
Regards, Sander
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Christoph Hormann wrote:
> > good indeed!
I not exactly sure either. Guess I had the current IRTC topic in mind.
I like that topic because I recall a fellow grad student who did sculptures
based on bunkers. They used bunker shapes
to suggest ideas ranging from our need for inner security to the unexpected
beauty of armaments. Your combination of what might be a
fortress structure with the use of recursive forms may lead to something
transendent. Guess that is what I was thinking but I hesitated to be so
specific.
-Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Sun, 01 Apr 2001 23:17:16 +0200, Christoph Hormann
Hmm... the lighting intensities seem radiositish indeed, but it's too
desaturated for a ocean-and-clear-blue-sky-and-bright-yellow-sun
picture. Maybe decrease (or increase? I can't grasp these things)
gray_threshold and/or use a more saturated yellow for the light source
and blue for the sky.
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm not sure about that, gray_threshold is 0.0 an the sky is quite blue as
you can see from the water. Of course i could make the sun more yellow.
OTOH especially in maritime environment, it can be quite hazy which would
weaken the colors.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> reflections.
Thanks,
when making this recursive macro I also had the impression that ir
reminded me of something I had seen before, but I did not consciously
think of Escher. Anyway there seem to be indeed some similarities.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Mon, 02 Apr 2001 18:22:19 +0200, Christoph Hormann
>weaken the colors.
Come to think of it, maybe the fractal structure *does* take enough
color from the surroundings, it's all the blue around it that tricks
te eye.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Cool! Fractals, architecture, photons, ridged surface - this pic has it all!
David Fontaine <dav### [at] faricy net> ICQ 55354965
My raytracing gallery: http://davidf.faricy.net/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
