POV-Ray : Newsgroups : povray.binaries.images : Procedural clouds Server Time
18 Aug 2024 22:28:41 EDT (-0400)
  Procedural clouds (Message 1 to 10 of 10)
Subject: Procedural clouds
Date: 14 Mar 2001 13:57:14
Message: <3AAFBF12.BF398D9D@aetec.ee>
Hi!
I've experimented a little bit with procedural clouds (written with
shader) and here is most promising result. Basically it is one plane
with shader. Shader is quite messy right now, but basically it performs
marching from intersection point toward light source and uses "advanced
calculation" to calculate cloud's color. So the shadowing of clouds is
totally fake, but with little  more tinkering it could be possible to
make this fake quite believable. But right now every attempt leads to
worse output, so I have to take time off.
Good part of such approach is that it renders quite fast: 512x384 aa0.3
on 2m28sec (350 MHz P2)
Download 'cloudover.jpg' (61 KB)
Preview of image 'cloudover.jpg'
Subject: Re: Procedural clouds
Date: 14 Mar 2001 14:16:13
Message: <3aafc37d@news.povray.org>
Vahur Krouverk <vah### [at] aetecee> wrote in message
news:3AAFBF12.BF398D9D@aetec.ee...
> Hi!
Not bad!
I recently implemented a real-time clouds simulation at work (I work in the
games industry), so confidentiality probably prevents me from saying too
much :-(. But I recommend you have a look here:
http://www.eml.hiroshima-u.ac.jp/~doba/pub_doba.html
What I did was based entirely on the second paper there, called "A Simple,
Efficient Method for Realistic Animation of Clouds". It's just about
possible in real time (though we'll probably drop it because it's a bit
expensive) but if you're pre-rendering you could get ridiculously realistic
clouds :)
I hope this is of some help.
Tek
"There's definitely, definitely, definitely no logic... to human
behaviour." - Bjork
http://www.evilsuperbrain.com
Date: 14 Mar 2001 16:54:27
Message: <3aafe893@news.povray.org>
Hey, cool. Keep up the good work. You're getting there. :) C'mon, we all
want fast clouds... :)
Date: 15 Mar 2001 02:44:06
Message: <3AB072ED.131DB499@aetec.ee>
Tekno Frannansa wrote:
> Not bad!
> clouds :)
Thanks for input. I believe that I looked at this paper, when I browsed
siggraph materials at ACM site. I've seen other papers there as well,
which use various approaches for cloud rendering. Perhaps if I have more
time, then I'll try them. But this attempt is based on Katsu's (Katsuaki
Hiramitsu's) approach. At least I believe that it is similar technique,
for he doesn't want to publish shader for this stunning picture (
http://www.edit.ne.jp/~katsu/image/cloud.jpg ), but he was kind enough
to give some hints about used method. So, time providing, I try to hack
it further to get more pleasing results.
Date: 15 Mar 2001 13:11:57
Message: <3AB105FF.DB8E4950@aetec.ee>
Hi!
Here is take 2. Unfortunately I don't have time right now to develop (or
more correctly: hack) it further (I will be off 2 weeks on the mountains
for heliboarding trip :-), so I made source code available in my
homepage ( http://www.aetec.ee/fv/vkhomep.nsf/pages/shdrex/ ).
If someone obtains better results with this approach, then it would be
good to see them.
Previous version suffered severly from noise plateau effect, as I forget
to set version to unofficial. This picture is more pleasing hopefully...
Download 'cloud2.jpg' (40 KB)
Preview of image 'cloud2.jpg'
Date: 15 Mar 2001 16:38:04
Message: <Xns9065E67C872EAseed7@povray.org>
in <3AB105FF.DB8E4950@aetec.ee> Vahur Krouverk wrote:
>--------------267C7910C11B2C7BA34DD473
>Hi!
>Here is take 2.
The structure of clouds is definatly there, but it lacks depth.
>(or more correctly: hack) it further (I will be off 2 weeks on the
>mountains for heliboarding trip :-),
"Hals und Beinbruch"
Ingo
Date: 15 Mar 2001 20:29:37
Message: <3AB16BC7.282C2DDE@videotron.ca>
> Hi!
Why, you "/$%?*(()?%$())%@#!!!
Francois Labreque | And a four year old carelessly banging on a toy
    flabreque     | piano is not only 'music', it's probably the last
        @         | moment of 'artistic purity' they'll ever enjoy
   videotron.ca   | before outside influences start corrupting their
                  | expression.    - Chris R.
Date: 16 Mar 2001 04:39:10
Message: <3AB1DF66.E23ECDDB@aetec.ee>
Right, perhaps this is better?  (source is in my homepage)
Download 'cloud4.jpg' (24 KB)
Preview of image 'cloud4.jpg'
Date: 16 Mar 2001 09:08:03
Message: <3ab21e43@news.povray.org>
That's French for "Have a great time, you lucky fellow!". ;)
Date: 16 Mar 2001 16:57:06
Message: <3AB28B9A.7A5D9009@faricy.net>
The shading effect is great, but what I think contributes some to the harsh
two-dimensionality is the edges. I haven't had a look at the source yet, but
is there a way you can make them blend into the sky a bit?
