POV-Ray : Newsgroups : povray.binaries.images : Megapov MCP sample (77k) Server Time
26 Mar 2026 21:56:10 EDT (-0400)
  Megapov MCP sample (77k) (Message 11 to 15 of 15)
Subject: Re: Megapov MCP sample (77k)
Date: 4 Mar 2001 16:31:58
Message: <Xns905AE56C0E6ECseed7@povray.org>
in <3AA2B1D7.1530E613@gmx.de> Christoph Hormann wrote:
>> I think it makes sense in this case...actually, "blurred_pattern"
>> seems even better. Just plain "blur" seems kind of ambiguous...it
>> doesn't seem as apparent that the *pattern* is what is being
>> blurred.
>All right, since English is not my native language i will not argue
>that.
Should it be a pattern at all? Why not as a method of 'transformation'
like turbulence, maybe even within a warp statement.
pigment{
    	wood
    	warp{ blurr .... }
Ingo
Date: 4 Mar 2001 16:37:25
Message: <chrishuff-C97D7C.16342804032001@news.povray.org>
In article <3AA2B1D7.1530E613@gmx.de>, Christoph Hormann
> > blurred.
> All right, since English is not my native language i will not argue that.
I just added it to my code, and realized it takes a pigment, not a
pattern...why is that? It kind of messes up my logic for the name...it
should be "blurred_pigment_pattern". ;-)
I think my first modification will be to change it to use a
pattern...that might speed it up slightly. I can't think of any benefit
to using a pigment...
> > Alright...I just downloaded the source code, and will probably
> > integrate your stuff into MegaPOV+. (it will be the last thing
> > added, though, in case you release a new version before I complete
> > MP+)
> Will that be based on Megapov 0.7 ?
Yes.
> Integrating your particle system patch I also saw that some other things
> were not yet included in Megapov like the curvature pattern.  What's the
> reason?
They aren't finished, some of them just don't work.
> > Now *that* has some potential for confusion...
> Yeah :-)
> While the 'shadows' in the object pattern with visibility are infinitely
> long, the value raises to 1 at the length of the distance vector in the
> visibility pattern.
So the value tends toward 0 as the object gets nearer, and the effect of
an object gets stronger with distance? That doesn't seem right...an
object should have less influence with distance.
Christopher James Huff
Date: 4 Mar 2001 16:49:07
Message: <3AA2B84F.351234C7@gmx.de>
It can be declared, furthermore: just laziness.
Probably better the other way round, in both patterns.  The idea in the
object pattern was shadow -> 0, but that's not that important.
Date: 4 Mar 2001 16:52:11
Message: <3AA2B90B.8851890C@gmx.de>
> pigment{
>         wood
>         warp{ blurr .... }
Since it is no transformation in fact, i'm not sure if that's possible.
Values get changed, in block patterns like checker even totally new values
occur.
Date: 4 Mar 2001 16:56:21
Message: <chrishuff-89DEE8.16532404032001@news.povray.org>
In article <Xns### [at] povrayorg>, ing### [at] homenl (ingo)
This is how my patch worked...however, block patterns, which have a
fixed number of flat areas, might not work as expected when the blurring
returns "in-between" values.
