POV-Ray : Newsgroups : povray.binaries.images : Tip for all POV fans... Server Time
19 Aug 2024 06:19:39 EDT (-0400)
  Tip for all POV fans... (Message 1 to 10 of 11)
Subject: Tip for all POV fans...
Date: 18 Jan 2001 16:42:06
Message: <3A6763EB.FE4B0B75@wxs.nl>
Just a tip :-)
My experience is that rendering pictures in 16:9 format can add to the
"impact" a picture makes. This can be simply done by changing the camera
object where the aspect ratio is normaly 5/4. Just change it to 16/9 and
change the rendering size to 16:9 or a multiple of that: 160:90,
320:180, 640:360, etc.
Between words: widescreen motion pictures use 2.35:1 I never used it
however. Maybe someone can posts some examples here.
Subject: Re: Tip for all POV fans...
Date: 18 Jan 2001 18:35:00
Message: <3A677E79.B3DAA190@209software.com>
Just for fun, here are some common 16:9 w/h values
 16x9 image formats
 Landscape     Portrait
 Width  Height Width Height
 160    90     160   284
 320    180    320   569
 512    288    512   910
 640    360    640   1138
 800    450    800   1422
 1024   576    1024  1820
 1280   720    1280  2276
Bryan Valencia
Software Services - Making Windows Scream
http://www.209software.com
mailto:bry### [at] 209softwarecom
Download 'us-ascii' (2 KB)
Date: 18 Jan 2001 18:48:55
Message: <3A6781BD.12C61A71@209software.com>
Ok, 1 step further... heres Quickres169.ini
Bryan Valencia
Download 'quickres169.ini.txt' (3 KB)
Date: 19 Jan 2001 19:01:10
Message: <3A68D400.F3192FCF@faricy.net>
"A. Jans-Beken" wrote:
> Just a tip :-)
Yep. Actually I think 16:9 is wide, 2.35:1 is "cinema". Or at least in the
Goldeneye video options. :)
The default is actually 4:3, not 5:4.
Other good ratios are tau (~1.618:1), the golden ratio, 2.5:1, panoramic?,
and 4:5.
Gilles Tran has some great renders at 2.5:1,
http://www.mediaport.net/Artichaud/Tran/gtran.en.html
I have a render in tau, a render in 5:4 (vertical 4:5), and the mc escher
gallery is square, http://davidf.faricy.net/raygall.html
Date: 19 Jan 2001 20:56:03
Message: <3A68EF97.F15DA488@videotron.ca>
> and 4:5.
I thought the golden ratio was ~1.618:1 ....
Unless I'm not reading the above sentence properly.
Francois Labreque | In the future, performance will be measured
    flabreque     | by the size of your pipe.
        @         |             - Dogbert, on networking
   videotron.ca
Date: 19 Jan 2001 23:13:04
Message: <3A690EE6.4C4474A6@faricy.net>
> > and 4:5.
Yes it is. I should have made the commas after ratio and panoramic semicolons
probably. Not like they teach this kind of stuff in school anymore. ;-)
Date: 20 Jan 2001 02:13:38
Message: <3A693ADC.39F66000@tiac.net>
I think you mean 4:3, technically speaking 4:3 is considered
widescreen as eary filmaking was done in that ratio. Citizen Kane
was done that way.
Phil
Date: 20 Jan 2001 05:59:53
Message: <3a696fa9@news.povray.org>
A. Jans-Beken <jan### [at] wxsnl> wrote in message
news:3A6763EB.FE4B0B75@wxs.nl...
> Just a tip :-)
Some of my posts are 2.35:1.
If you want an interesting read about Widescreen Cinema, a bloke named John
Belton wrote a book of that name, full of tales of odd film formats with
even odder names - Magnascope, Veriscope, Anamorphoscope, Cinerama,
CinemaScope, CinemaScope 55, Todd-AO, Viventoscope, Polyvision, Grandeur,
Natural Vision, Realife, Imax, Omnimax, Circarama, Ultra Panavision,
VistaVision, Panavision, and WarnerSuperScope (which never got past the
drawing board - which is a shame as it's such a great name!).
And then there's letterboxing, pan-and-scan (or pan-and-scandal), anamorphic
lenses/projection, curved screens...
I feel a headache coming on.
Date: 24 Jan 2001 12:48:03
Message: <3a6f1553$1@news.povray.org>
A. Jans-Beken,
Can you repost that quickres file?
Thanks,
C.J. - POV User
news:3A68D400.F3192FCF@faricy.net...
> > Just a tip :-)
> and 4:5.
Date: 24 Jan 2001 13:33:21
Message: <3A6F20C6.9764CDE@209software.com>
Ok, BUT I have 1 warning:
Whenever I get a raytrace that comes out really well, I like to make it my
wallpaper.  It does not work for 16:9 images.  well, not 'stretched' anyways.
Here is my std 16:9 Camera.  Add it to your Insert Menu.
// std 16:9 Camera (for landscapes)
camera{
  location  <0, 0, -10>
  direction 1.5*z
  right     16/9*x
  look_at   <0.0, 0.0,  0.0>
"C.J." wrote:
> A. Jans-Beken,
Bryan Valencia
