![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You cheated, you used shaving foam instead.
Steve email mailto:ste### [at] zeropps uklinux net
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
11:44pm up 48 days, 2:07, 2 users, load average: 1.00, 1.01, 1.00
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The snow looks thicker than it probably should, but it is very very cool. It
needs icicles. Also, it looks like the snow fell straight down, does your
method allow you to defind a wind direction that would place the snow to one
side of everything?
Josh
Christoph Hormann wrote:
> Just thought it's about time to start the winter season, the first
> christmas trees are also being grown, so here is some fresh snow...
> It's written new from scratch in about 1-2 hours, i wonder if there is
> already a good snow macro available, but i don't remember anything.
> The construction is quite simple, blob compontents positioned by trace
> (47000 in total) so a lot of things are not yet very realistic.
> Christoph
> Christoph Hormann <chr### [at] gmx de>
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
> [Image]
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3A22FAC1.6BADE805@spiritone.com>, eng### [at] spiritone com
We had a snow that looked exactly like this a couple days ago...all you
need is a damp snow that is constantly drifting straight down, with
little wind and no sun.
Very funny...
> It needs icicles.
Isosurfaces!
> Also, it looks like the snow fell straight down, does your method
> side of everything?
I think he just used the trace() function going straight down from the
sky. Slanting the direction you give trace() should give you something
like that effect.
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Remco de Korte wrote:
> I like this very much!
> I can see some imperfections but it's promising to say the least.
> Remco
Thank You.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I think foam would probably need a bit less 'heavy' texture.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Chris Huff wrote:
> There are some regular patterns from the fact that you used a grid to
> position the components...maybe a random placement would be better.
I don't think completely random would be good, but some 'jitter' could
probably help.
> You
> could also use eval_pattern() or eval_pigment() to control the density
> of the snow, make it look more uneven on the flat areas.
That's a good idea, thanks.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> side of everything?
Just changing the direction would not be that good, because the snow
should much depend on tho slope, so you would have to take the normal
vector into account (right now it isn't used). Usually the snow on the
wind side of objects is thinner and less regular.
icicles would be nice, but they would involve pretty much calculation to
be placed properly.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Chris Huff wrote:
> > It needs icicles.
> Isosurfaces!
Or maybe blobs would also do for that.
> > side of everything?
> like that effect.
As i said in the reply to Josh, that alone would not be that good, at
least variation of the blob component size according to the normal of the
objects would be necessary.
I also think at some places like the 'N' in 'Snow' some 'surrounding
observation' would be necessary to avoid the snow overlapping with the
objects too much (right now i only use one 'trace' per component). Maybe
some components with negative strength could also help there.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Christoph,
That looks very good, I always wondered whether something like that was
possible in pov. Would you mind posting the code?
> Christoph
> [Image]
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3A22E208.5E5690EF@gmx.de>, Christoph Hormann
It wasn't designed as a general-purpose macro, but there was aa good
example of making it snow posted to comp.g.r.r a year or so ago. I used
it on the image at http://www.hoboes.com/jerry/Gallery/Christmas.shtml
It's very christmas-card like, so might not be what you want. But I can
dig up the code if you want.
Jerry
"Give a man a fish and you feed him for a day. Teach him to fish, and you've
depleted the lake."--It Isn't Murder If They're Yankees
(http://www.hoboes.com/jerry/Murder/)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
