POV-Ray : Newsgroups : povray.binaries.images : Lego castle by torchlight (123k) Server Time
19 Aug 2024 18:30:43 EDT (-0400)
  Lego castle by torchlight (123k) (Message 1 to 10 of 17)
Subject: Lego castle by torchlight (123k)
Date: 8 Nov 2000 22:58:01
Message: <3A0A2040.A4EE764B@faricy.net>
I'm fairly satisfied with this :)
Each torch is a column of three (for small "stick") or six (for large
"lantern") point lights with a yellowish tint. If you look closely (at
least on the PNG version) the banding is evident, but it blends pretty
well. Because of the number of lights (42) and the high aa (0.1, even
0.2 left nasty artifacts on the daylight version if you look closely) it
took a long time to render...
Render time 1d 07h 29m 04s (31:29:04)
Peak memory 55 873 443
This is a very black-level sensitive image, so if you can't make out
details in the dimly lit areas turn off the room lights or shield your
monitor, trust me it looks a lot better!
Download 'castle_699_2.jpg' (123 KB)
Preview of image 'castle_699_2.jpg'
Subject: Re: Lego castle by torchlight (123k)
Date: 8 Nov 2000 23:16:16
Message: <slrn90k95e.ga4.steve@zero-pps.localdomain>
Time to change the wallpaper, thanks David.
You whimp! That's less than a week:-)
  4:05am  up 29 days,  6:27,  3 users,  load average: 2.17, 1.56, 1.21
Date: 9 Nov 2000 00:05:18
Message: <3A0A31AE.944D4350@unforgettable.com>
That looks badass. My only complaint would be that the camera makes it
look a bit strange.
Not a problem on a Mac. ;)
-Xplo
Date: 9 Nov 2000 01:05:05
Message: <3A0A3E34.BCFBD663@faricy.net>
I hardly see how glare and black-level can be platform dependent...
Date: 9 Nov 2000 01:06:01
Message: <3A0A3E6D.C72ECFC0@faricy.net>
:)) The highest honor one can recieve!
;) Alright, I'll radiositize and photonize it (j/k)
Date: 9 Nov 2000 01:07:48
Message: <3A0A3ED5.25EB5E3C@faricy.net>
> That looks badass.
The banding?
> My only complaint would be that the camera makes it look a bit strange.
That's a matter of personal taste; I kinda like the ultra_wide_angle camera.
Date: 9 Nov 2000 08:08:17
Message: <chrishuff-35DD50.08082109112000@news.povray.org>
In article <3A0A3E34.BCFBD663@faricy.net>, David Fontaine
Macs have a different gamma(around 1.8), so the darker areas show up as
brighter on Macs. I could see nearly every detail in even the darkest
areas on my system(though it retains the dimly-lit look).
Christopher James Huff
Date: 9 Nov 2000 09:36:21
Message: <3A0AB665.4DC1558A@schunter.etc.tu-bs.de>
The lighting looks nice but not very lego-like(tm)
How about a second version with bright sky, radiosity, some reflection ?
Ok, you should then leave out the 42 light sources to get it rendered within one
week ;-)
Date: 9 Nov 2000 11:09:58
Message: <3A0ACC56.45D0EBC1@spiritone.com>
With this lighting I am reminded of a quake map. Very cool.
Josh
eng### [at] spiritonecom
Date: 9 Nov 2000 20:45:01
Message: <3A0B52CC.7ECC7DD3@online.no>
This image makes me want to construct with
Lego again !
But isn't there a tiny detail missing ?
The word "Lego" on every little "cylinder".
Nice idea to use a wide angled camera here.
This combined with the dim light spots
shows the Lego bricks(?) in a way that I
have never seen them before.
Tor Olav
mailto:tor### [at] hotmailcom
