![](/i/fill.gif) |
have a look at the attached picture please.
That media you can see there is supposed to be white. In fact it is white,
when I remove the clouds from the scene, which are generated by Samuel
Benges layered planes code. I thought it could be just a shadow of the
clouds, but it remains dark, even if it is lit by a shadowless light_source
at the camera position or by radiosity.
I set max_trace_level up to 700 but it does not change anything. Some code
at the end of this post (hope it's okay to post it here, 'cause no one will
probably ever search for it again).
So, what is going on here? I hope it is not a to silly error of mine :-).
Thanks in advance,
Marc-Hendrik
My media-box:
box {<-6,0,-2>, <8, 3,0>
hollow on
pigment {rgbf 1}
interior{
media{
scattering{1,0.002}
density{ gradient y
color_map{
[0.4 rgbt 1]
[0.5 rgb 500]
[0.6 rgbt 1]
translate <2,-2.6,0>
rotate z*-15
turbulence 0.3
scale 6
translate <3,-0.5,0>
method 1
intervals 1
samples 10, 10
confidence 0.999999
variance 1.0/1024
The clouds by SamuelT (not much modified):
// Clouds from Samuel Benge
#declare Clouds=function "ridgedMF",<1,2.25,7,-1,1>
#declare Y=0;
#declare Ivals=5; //Number of cloud planes
#while(Y<1)
//plane{y,100+(Y*20) clipped_by{box{<-1000,0,-1000>,<1000,200,1000>}}
polygon{5,<-3000,-3000>,<-3000,3000>,<3000,3000>,<3000,-3000>,<-3000,-3000>
rotate x*90 translate y*100+(Y*20)
pigment{function Clouds(x,y,z)/3.8+noise3d(x/20,y/20,z/20)/3.5+(z/20)
scale<300,150,300> phase -.5
color_map{[.25 rgbf 1][.4 rgbt<1/1.5, 1/1.5, 1/1.5, .01>]}
finish{diffuse 1.5 ambient .25 }
hollow double_illuminate
#declare Y=Y+1/Ivals;
Download 's1.jpeg.jpg' (3 KB)
Preview of image 's1.jpeg.jpg'
![s1.jpeg.jpg](/povray.binaries.images/attachment/%3C39d66641%40news.povray.org%3E/s1.jpeg.jpg?preview=1)
![](/i/fill.gif) |
