POV-Ray : Newsgroups : povray.binaries.images : Rendering of Samurai Sword Server Time
1 Oct 2024 13:21:44 EDT (-0400)
  Rendering of Samurai Sword (Message 1 to 5 of 5)
Subject: Rendering of Samurai Sword
Date: 25 Aug 2000 00:43:20
Message: <39A5F958.9C47B47C@popampa.com>
Hi all,
Dose anyone out there have a rendering  or source code for a samurai
sword?
Need it for a tatto image I'm working on.
Thanks
Southern Cross Akitas (SCA)
Lois & Brian Bivolcic
Pampa, Tx
http://www.centramedia.com/bivolcic
Subject: Re: Rendering of Samurai Sword
Date: 25 Aug 2000 03:36:38
Message: <39a62206@news.povray.org>
Brian & Lois Bivolcic <biv### [at] popampacom> wrote in message
news:39A5F958.9C47B47C@popampa.com...
> Hi all,
> sword?
> Thanks
There a model on my website (http://www.rucus.ru.ac.za/~gail/code.htm)
The shape of the blade's not perfect, but it might do.
Gail
* gsh### [at] monotixcoza              * System.dat not found.         *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k  *
* If at first you don't succeed, call it version 1.0               *
Date: 29 Aug 2000 21:54:06
Message: <39AC69BA.83DFD341@ij.net>
Brian & Lois Bivolcic wrote:
> Hi all,
> sword?
	I have been wanting to do one for some time and your message reminded
me, reminded me to try a method I thought of. It is not going to work
directly for your needs. The bottom of the attached image will be the
hilt.
	It still needs a tip and the csg object should rotate a bit in
accordance with the curve. Eventually I will add the tip by
proportioning the same object. Looking at my decorative Sam sword the
tip is all "cone."
	It is memory intensive.
"Dissecting the Holocaust" by Germar Rudolph
Banned and burned in Germany. Read what the
German government does not want you to read.
	-- The Iron Webmaster, 45
Download 'us-ascii' (2 KB) Download 'sword.jpg' (4 KB)
Preview of image 'sword.jpg'
Date: 30 Aug 2000 01:43:34
Message: <39AC9F85.6FF18393@ij.net>
> > Hi all,
> > sword?
> hilt.
> tip is all "cone."
> #include "/home/matt/povray/includes/colors.inc"
> #include "/home/matt/povray/includes/shapes.inc"
> #include "/home/matt/povray/includes/textures.inc"
> #include "/home/matt/povray/includes/metals.inc"
> #include "/home/matt/povray/includes/woods.inc"
> global_settings
>   assumed_gamma 2.2
>   ambient_light rgb <1,1,1>
> #declare blade_part =  union {
> #declare radi = 0.5; // radius
> #declare sw = 1; // length of polished
> #declare rati =2.5; // length of edge as ratio of polished
> cylinder { <-sw ,0,0> <sw,0,0> radi texture {T_Chrome_5A}  // pigment {color White}
> rotate <0,0,0> translate <0,0,0>}
> cone { <0,0,0> radi <sw*rati,0,0> 0 texture {T_Chrome_5A} //pigment {color White}
> rotate<0,0,0> translate <sw,0,0> }
> sphere { <0,0,0> radi texture{T_Chrome_5A} //pigment {color White}
> scale <0.25,1,1>
> rotate<0,0,0> translate<-sw,0,0> }
> sphere { <0,0,0> radi texture {T_Chrome_5A} // pigment {color White}
> scale <0.25,1,1>
> rotate<0,0,0> translate<sw,0,0> }
> #declare blade = union {
> #declare i = 0 ;
> #while (i < 10000)
> object {blade_part translate <-(i*i)/5000000,0,i/50>} // x value controls curvature
> #declare i = i + 1 ;
> #end
> blade
> camera
>   location <0,3.5,0>*100
>   direction 1.5*z
>   right     4/3*x
>   look_at   <0.0, 0.0,  100.0>
> sky_sphere {
>         pigment { gradient y color_map { [0 color Blue] [1 color White] }
>         scale 2 translate -1 }
> light_source
>   0*x // light's position (translated below)
>   color red 1  green 1  blue 1
>   translate <30, 30, -30> *2000
> light_source
>   translate <-30, 30, -30> *200
>   shadowless
> plane { y, -2 pigment {color rgb <0.3, 0.7, 0.6> } }
	Next step it so make the basic union a circular sweep, clip and deform
to get rid of the memory load.
Q. "Do you realize I can defame you without penalty?"
A, "Do you realize I can let you?"
	-- The Iron Webmaster, 31
Date: 30 Aug 2000 16:58:15
Message: <7ljqqsgph2ork21g7t26aj9g59jcedhuua@4ax.com>
On Thu, 24 Aug 2000 23:43:05 -0500, Brian & Lois Bivolcic
<biv### [at] popampacom> wrote:
>Hi all,
>sword?
A good lot of katanas were posted here some time ago, look back into
the headers in this group.
Peter Popov ICQ : 15002700
