![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Cubic splines in megapatch, order of points matters?
Date: 26 Sep 2000 21:08:34
Message: <39d14892@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm wondering why these two curves are different. They are splines
rftpt & lftpt .
They both have essentially the same points, but one dips at a different
time than the other. I end up losing all of my "cubicness".
#version unofficial MegaPov 0.4;
#include "skies.inc"
camera {location <25,-17, 0> look_at <0,-17, 0>
angle 60}
light_source { <-15, 30, -25> color red 1 green 1 blue 1 }
light_source { < 15, 30, -25> color red 1 green 1 blue 1 }
light_source { < -1, 1, 10> color red 1 green 1 blue 1 }
light_source { < 0, 1, 0> color red 1 green 1 blue 1 }
#declare texy=texture {
finish {
ambient 0.3
diffuse 0.8
phong 1
normal {
bumps 0.4
sine_wave
scale 0.08
pigment { color Red }
#init_3d_spline {"My_Spline",closed
#declare c=0;
#while (c<1.001)
,<2*sin(15*c),c*3,2*cos(15*c)>
#declare c=c+0.05;
//translate <0,-4.3,-1>
#declare lftpt=
spline {
//linear_spline
cubic_spline
0.00, <0,-17,-7>
0.50, <0,-17, 7>
0.75, <0,-10,-0>
1.00, <0,-17,-7>
#declare rftpt=
spline {
//linear_spline
cubic_spline
0.00, <0,-17, 7>
0.25, <0,-10,-0>
0.50, <0,-17,-7>
1.00, <0,-17, 7>
#declare c=0;
#while (c<1)
sphere { rftpt(c),0.2 texture {texy}}
sphere { lftpt(c),0.2 texture {texy}}
#declare c=c+0.008;
Download '5.jpg' (9 KB)
Preview of image '5.jpg'
![5.jpg](/povray.binaries.images/attachment/%3C39d14892%40news.povray.org%3E/5.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Cubic splines in megapatch, order of points matters?
Date: 27 Sep 2000 07:53:57
Message: <39D1DFD2.545BE184@erols.com>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> rftpt & lftpt .
> different time than the other. I end up losing all of my "cubicness".
The order of the points in a spline matters no matter what software
you're using.
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
But do you get my point?
a,a,b,a gives very different results from a,b,a,a
Shouldn't any a-b-a be the same?
> > rftpt & lftpt .
> you're using.
> Regards,
> John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 27 Sep 2000 11:13:26
Message: <39d20e96@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Greg M. Johnson wrote in message <39D1E46B.CDB2D1A6@my-dejanews.com>...
Not with cubic splines in general, as it requires FOUR control points to
determine the location of any point on the curve. a-b-a does not give
sufficient information to determine a cubic spline curve. As to what is
happening to your curve, check the documentation:
*Cubic splines can be calculated in the range between the second and last
but one argument. In the remaining parts linear splines are used.
This means that when you shift the control points, different types of
splines are being used between the same point locations, and thus different
appearances. Thus you are actually only losing part of your "cubicness"
...the "cubicness" between the second and third points...when you change the
order number on your points (but gaining "cubicness" on the new second and
new third points). I hope my explanation is clear enough to help......
Quadhall
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 27 Sep 2000 11:26:46
Message: <39d211b6@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Might be an idea to compare a,b,a,c with c,a,b,a.
I would suspect the a,b,a curve should be identical in both cases.
It might have been a typo, but I am pointing a suspicious finger at the
duplicate "a" in your sequence and suggesting you introduce a new point "c"
to test this theory. Sorry I don't have a better way of expressing this.
I hope it works.
"Quadhall" <tre### [at] ww-interlink net> wrote in message
news:39d20e96@news.povray.org...
different
the
> Quadhall
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, I didn't read the phrase :
"Cubic splines can be calculated in the range between the second and last but
one argument. In the remaining parts linear splines are used."
So this spline is only half a loaf solution. I will restudy Chris's work and a
file that Jerry gave me. Thanks all anyway.
> I hope it works.
> different
> the
> > Quadhall
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 27 Sep 2000 22:42:37
Message: <39D2B112.EBA9626A@erols.com>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The points you specify do not form this pattern.
ICQ: 46085459
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
