removed book, added map, changed point light to an area light 9x9,
lowered light intensity by half, and added a "skylight" to diffuse the
area light.
Download 'test3a.jpg' (267 KB)
Download 'us-ascii' (4 KB)
Preview of image 'test3a.jpg'
sorry about the size. but any smaller the pots look all nasty with the jaggies
> area light.
> [Image]
> Parsing Options
> Input file: test3a.pov (compatible to version 3.1)
> Remove bounds........On Split unions........Off
> Library paths: C:\Program Files\POVRay\INCLUDE
> Output Options
> Image resolution 800 by 600 (rows 0 to -1, columns 0 to -1).
> Output file: test3a.bmp, 32 bpp (system format) with alpha
> Graphic display......On (type: 0, palette: 3, gamma: 2.2)
> Mosaic preview......Off
> Continued trace.....Off Allow interruption...On Pause when done.....Off
> Verbose messages....Off
> Tracing Options
> Quality: 9
> Bounding boxes.......On Bounding threshold: 3
> Light Buffer.........On Vista Buffer.........On Draw Vista Buffer...Off
> Antialiasing.........On (Method 2, Threshold 0.300, Depth 1, Jitter 0.30)
> Radiosity............On
> Animation Options
> Clock value.... 0.000 (Animation off)
> Redirecting Options
> All Streams to console..........On and file test3a.txt
> Debug Stream to console.........On
> Fatal Stream to console.........On
> Render Stream to console........On
> Statistics Stream to console....On
> Warning Stream to console.......On
> Warning: This rendering uses the following experimental features:
> radiosity.
> The design and implementation of these features is likely to
> change in future versions of POV-Ray. Full backward compatibility
> with the current implementation is NOT guaranteed.
> !!! This MegaPov version of radiosity differs from the official version !!!
> Scene contains 73584 frame level objects; 0 infinite.
> test3a.pov Statistics, Resolution 800 x 600
> Pixels: 480605 Samples: 699472 Smpls/Pxl: 1.46
> Rays: 4069291 Saved: 144081 Max Level: 10/10
> Ray->Shape Intersection Tests Succeeded Percentage
> Box 24512610 706769 2.88
> Triangle 201618282 19657305 9.75
> Bounding Box 1993501255 962709023 48.29
> Vista Buffer 38439781 29650610 77.14
> Calls to Noise: 5426784 Calls to DNoise: 22286870
> Shadow Ray Tests: 100532123 Succeeded: 16413937
> Reflected Rays: 664286
> Transmitted Rays: 2676
> Radiosity samples calculated: 32408 (1.26 percent)
> Radiosity samples reused: 2544854
> Smallest Alloc: 25 bytes Largest: 588696
> Peak memory used: 73039685 bytes
> Time For Parse: 0 hours 1 minutes 7.0 seconds (67 seconds)
> Time For Trace: 1 hours 29 minutes 12.0 seconds (5352 seconds)
> Total Time: 1 hours 30 minutes 19.0 seconds (5419 seconds)
> Total cache size: 14000
>area light.
267K of an image we've already seen about 5 times:-(
Steve email mailto:ste### [at] zeroppsuklinuxnet
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
11:24am up 15 days, 15:37, 3 users, load average: 1.00, 1.00, 1.00
