POV-Ray : Newsgroups : povray.binaries.images : Test Rendering : The Vases Improved Server Time
14 Mar 2026 00:07:35 EDT (-0400)
  Test Rendering : The Vases Improved (Message 11 to 18 of 18)
Subject: Re: Test Rendering : The Vases Improved
Date: 11 Aug 2000 11:35:18
Message: <39941C4E.C2C82AA1@inapg.inra.fr>
Fabian BRAU wrote:
> I already saw some attempt to create wood
> with hieghtfield, the result was more or less good but it took
> several weeks for the guy to get a "good" result so...
But does displacement mapping solves the problem of having a good displacement map
in the first place ?
For me the main problem in using isosurfaces for displacement mapping in Megapov
is that it is restricted to what isosurfaces can do. For instance, using it on CSG
is not straigthforward, if not impossible. The second problem is that it's not
fast. Otherwise it's not that complicated.
Below is a setup for a floor with displacement mapping in Megapov (equivalent to a
height field).
#declare hf=function{pigment{image_map{png "floorbump" interpolate 2} rotate
x*90}}
#declare rs=0.005;
isosurface{function{y - hf(x,y,z)*rs } contained_by{box{<-2,-1,-1>,<2,1,2>}}
threshold 0    rotate x*-90
        texture{pigment{image_map{png "floormap"}} finish{ambient 0 diffuse 0.8
specular 0.2 roughness 0.1} rotate x*90 }
And a picture here (uses official focal blur, official caustics, a big image map
for the texture and another big one for the displacement).
Download 'parquet.jpg' (30 KB)
Preview of image 'parquet.jpg'
Date: 11 Aug 2000 11:47:35
Message: <39942034.6E8B59D7@schunter.etc.tu-bs.de>
If i see it right your sample is similar to the heightfield solution.  The
obvious starting point would be to take the image map used for the texture and
try to get a reasonable corresponding heightfield/isosurface map using filter
functions.
heightfields should be a lot faster than isosurfaces in many cases, but of
course they are not that flexible.
Date: 11 Aug 2000 11:57:06
Message: <3994223D.6503C21A@umh.ac.be>
Exactly!! I forgot that we can use image map in iso surface :).
But yes this slow but feasible!
I will have a look!
Fabian.
> height field).
> x*90}}
> #declare rs=0.005;
Date: 11 Aug 2000 12:36:24
Message: <39942AA0.9A020D6A@inapg.inra.fr>
> functions.
Which exactly what I did here. The map was desaturated, and then I made a copy of it.
On
this one I painted the planks white, leaving only the gaps black. I gaussian-blurred
it
and then added this map to the previous map.
Heightfields are surely faster in the case of  flat objects. I rendered the previous
picture with a height field instead of an isosurface and it rendered 5 times faster
for
an identical output (no need to post it !).
Their main problem is that they are not tileable (unless you make copies of them and
stitch them together) while an isosurface can be of any size.
G.
Date: 11 Aug 2000 15:09:58
Message: <39944E49.182E57E7@skynet.be>
for
 And they consume much more memory, and have a finite resolution, while
isosurfaces can have infinite resolution (with precedural displacement).
 Happily, both exists !  Twice the fun !
Fabien.
Date: 11 Aug 2000 16:03:36
Message: <slrn8p8li6.2j3.steve@zero-pps.localdomain>
What's going on here?  The pots seem to come out of the picture like
one of them 3D glasses things.  Has a chillingly realistic feel to it
but something in there lookks very flat at the same time, gives me a
slight feeling of vertigo.
  6:14pm  up 27 days, 16:41,  2 users,  load average: 1.08, 1.02, 1.02
Date: 12 Aug 2000 00:07:35
Message: <chrishuff-F428CA.23084211082000@news.povray.org>
In article <3993ADDC.EA0B3F81@umh.ac.be>, Fabian BRAU
<Fab### [at] umhacbe> wrote:
> There is only image map in this scene :).
Yes, but the map is tiled over the vases, right? It isn't a single image
wrapped over the vase. So lighting can affect it as it normally would.
However, it looks like much of the "lighting" effect on the wood is part
of the image_map.
> Procedurial wood look always fake :).
Not always...I have seen some very convincing wood textures, some which
you really couldn't tell from real wood. And no offense, but even many
of the less convincing ones looked better than this. There is a very
noticeable discontinuity between the bases of the vases and the wood
texture.
Date: 17 Aug 2000 03:10:38
Message: <399B8FD7.B152FEB0@umh.ac.be>
No problem, I wait your art ...
